POV-Ray : Newsgroups : povray.off-topic : Progress on the fractal front Server Time
16 May 2026 12:16:43 EDT (-0400)
  Progress on the fractal front (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Progress on the fractal front
Date: 29 Sep 2008 05:43:23
Message: <48E0A387.1070305@hotmail.com>
On 29-Sep-08 10:29, Stephen wrote:
> On Mon, 29 Sep 2008 09:03:32 +0100, Invisible <voi### [at] devnull> wrote:
>> The fun part - apparently - is getting FractInt to actually run any
>> more. Being an old MS-DOS program that manually frobnicates the video
>> hardware in advanced ways, it doesn't tend to run very happily under
>> Windoze. (Indeed, you might have more luck with the Linux port...)
> Winfract?
For some reason I read that as "Winfarct?". That would even have made
sense as a description of the what happens when you manipulate the video
directly under windoze.
Date: 29 Sep 2008 05:56:44
Message: <48e0a65c@news.povray.org>
Stephen wrote:
>> If you check the other newsgroup, Warp posted a lovely little Haskell
>> program that prints out the Mandelbrot set in ASCII art. ;-)
> Sorry, what other newsgroup?
I was actually kidding.
(But if you have a look at the Haskell groups on this news server...)
Date: 29 Sep 2008 06:20:19
Message: <nsa1e41kemn7nkrtd2sr6uofer08sok4vc@4ax.com>
>> Winfract?
Is it my accent? ;)
Too true :)
And Winfract does not do colour cycling :(
Regards
Date: 29 Sep 2008 06:23:56
Message: <p1b1e4pbe61a4i6qvggguasr8nuktmeudu@4ax.com>
You got me :) but I've seen a Mandelbrot in ASCII art.
Lordy, there is a lot there :)
Regards
Date: 29 Sep 2008 06:27:28
Message: <48e0ad90$1@news.povray.org>
And there is, in fact, a Haskell program from Warp that generates one.
(He's learning Haskell, apparently.) Obviously, being a beginner's
program, it's not really useful for much other than learning about
Haskell - so my suggestion to use it instead of FractInt was the part I
was joking about.
There is indeed a lot there - and much of it is from a Finnish guy, but
I'm fairly sure there's no Lordy in there. ;-)
Date: 29 Sep 2008 12:28:55
Message: <48e10247$1@news.povray.org>
stbenge wrote:
> Last week I decided to try my hand at making a fractal program, to test
> some ideas. I may have come up with a new variation of the Mandelbrot.
Pretty.  JPG is probably not the way to go with fractal images, tho. :-)
Date: 29 Sep 2008 16:22:27
Message: <48e13903@news.povray.org>
Invisible wrote:
>   x = real(z);
>   y = imag(z);
>   z = {x*x - y*y, 2*x*y};
> off the top of my head...
I checked around and found ChaosPro(free), which allows one to build
expressions like the one you placed above. It uses a C-like syntax which
is just fine with me :) You can built your own functions. For instance,
I made new min() and max() functions to manipulate complex numbers. Now
if I can just replicate the same fractal I posted here with the program
:/ I came up with something which looks like it superficially, but upon
closer examination, looks like a cheap knock off. Less detail... I must
be doing something wrong. (like staying up till three working on
fractals ;))
It pisses me off that MS dropped DOS. Now all I can do is run this lousy
DOS-box. It supports some games, but not any programs I have made to run
under DOS SVG modes >:(
Date: 29 Sep 2008 16:25:33
Message: <48e139bd$1@news.povray.org>
stbenge wrote:
> I must
> fractals ;)
Er... yuh-huh. ;-)
I'd say "use a virtual machine", except that'll be... a tad... slow.
http://blog.orphi.me.uk/
Date: 29 Sep 2008 16:26:43
Message: <48e13a03@news.povray.org>
Darren New wrote:
>> test some ideas. I may have come up with a new variation of the
>> Mandelbrot.
Not if I want to preserve the detail and color intensity... but I have
dialup over here, so posting PNGs might have been prohibitive. That's
life in the sticks :/
Subject: yay
Date: 29 Sep 2008 21:15:00
Message: <48e17d94$1@news.povray.org>
stbenge wrote:
> http://i447.photobucket.com/albums/qq199/stbenge/complex1q.jpg
After hacking and slashing my way through ChaosPro's syntax and coloring
methods, I have finally recreated one of my fractals:
http://i447.photobucket.com/albums/qq199/stbenge/complex1qCP.jpg
It's exactly the same fractal! Up until a little while ago all my
attempts looked like cheap toy replicas of the real thing, and I was
beginning to wonder about the quality of ChaosPro. I still need to work
on the coloring method, to make it more smooth, but this is some
progress :) I can now convert all my fractals over to CP and render them
with AA, changed resolutions, etc.
Well I'm excited anyway, even if nobody else is :)
Sam
