POV-Ray : Newsgroups : povray.off-topic : Linux & drivers Server Time
23 Dec 2025 06:45:05 EST (-0500)
  Linux & drivers (Message 1 to 10 of 43)
Subject: Linux & drivers
Date: 4 Sep 2008 10:07:42
Message: <48bfebae$1@news.povray.org>
While building my new PC I ran into an interesting problem trying to
boot a live Linux CD - at least all of the ones I tried.
Many motherboards are using the Marvell IDE controller - which is
currently not supported by most Linux distributions.
So while it starts booting fine, when it hands off to the kernel
everything comes to a screeching halt because it cannot find the CD.
I found pendrivelinux.com that helped me with w very quick boot from USB
solution.
Funny enough, it was the Knoppix screen shot that Andrew posted that I
had been seeing for the past few days.
And all I wanted - fdisk
<sigh>
Tom
Subject: Re: Linux & drivers
Date: 4 Sep 2008 11:12:18
Message: <48bffad2@news.povray.org>
Interesting...
My motherboard uses the nVidia nForce 4 chipset, and as a result many
Linux live CDs can't see any of the SATA drives. However, they all find
the PATA ones just fine.
(I remember seeing "Marvell" and thinking "oo, that's what I have". But
it isn't. I have a Marvell NIC. The IDE controller is nVidia.)
I discovered that many if not most live CDs can be coaxed into seeing
the drives by manually executing a modprobe command. (No, I have no idea
which one... and it wouldn't help you anyway.)
http://blog.orphi.me.uk/
Date: 4 Sep 2008 11:24:44
Message: <48bffdbc$1@news.povray.org>
> Interesting...
That's what I ran across - I just didn't have the energy to dig into
which one.
I guess I should learn it sometime as this PC is going to have this
issue for a while and I plan on doing some fun Linux things with it.
Tom
Date: 4 Sep 2008 11:34:38
Message: <48c0000e$1@news.povray.org>
>> idea which one... and it wouldn't help you anyway.)
> which one.
IIRC, most live CDs failed to find either my harddrives or my NIC. To
fix it, you have to say something like
   modprobe nv_forcedeth
   modprobe nv_sata
and then they both work again. I figured this out by searching several
billion manpages, discovering where kernal modules (such as device
drivers) are stored, and then listing the contents of the folder and
looking for anything that sounded like it might work.
Hard to fix? No. User-friendly? No!
I still have no idea what "force deth" actually means...
Date: 4 Sep 2008 12:04:40
Message: <48c00718$1@news.povray.org>
>> which one.
>   modprobe nv_sata
I find that I can get into Linux fairly easily and remember quite a bit,
but when i step back from the guts for a while I have to figure things
out again.  Granted it all seems familiar and doesn't take as long, but
it's hard to remember exactly what everything does when you mess with it
once in a while.
Date: 4 Sep 2008 13:10:18
Message: <op.ugyvbgqh7bxctx@e6600>
It makes more sense as "forced eth", even though the idea of a module that
forces death is somewhat amusing...
Apparently, the ambiguity is at least partially intentional.
FE
Date: 4 Sep 2008 13:43:50
Message: <48c01e56@news.povray.org>
> once in a while.
I know what you mean...
At one time I installed Gentoo Linux. (As in, that Linux that doesn't
come with an installer and has to be manually compiled from source and
installed piece by piece.) Now I have _no clue_ how I did it.
Date: 4 Sep 2008 13:56:22
Message: <48c02146$1@news.povray.org>
What does fdisk give you that diskpart doesn't?
Date: 4 Sep 2008 15:28:06
Message: <48c036c6$1@news.povray.org>
Weird, my HP system here has that same chipset on it, and the live discs
do OK with it - SATA drive works beautifully with openSUSE 11.0 running
on it, too.
Jim
Date: 4 Sep 2008 15:40:01
Message: <48c03991@news.povray.org>
I usually do a Linux From Scratch for most things.
While I do the automated build, it at least keeps me in touch with the
roots of what is going on.
