POV-Ray : Newsgroups : povray.off-topic : Coolest thing EVER! Server Time
17 May 2026 07:40:55 EDT (-0400)
  Coolest thing EVER! (Message 3 to 12 of 112)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Coolest thing EVER!
Date: 31 Aug 2008 11:06:50
Message: <48bab38a$1@news.povray.org>
Orchid XP v8 wrote:
> OK, so I realise I'm probably about 20 years behind everybody else, but
> seriously... this is THE coolest thing I've seen this year! I would
> never have believed it was physically possible - and certainly not
> without spending hours setting it up. I can't get over how EASY this was!
	You're not that far behind. I only recently set up VirtualBox on my
Linux so that I could run Windows. Works like a charm - I was really
surprised.
It is kisstomary to cuss the bride.
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Date: 31 Aug 2008 12:14:45
Message: <48bac375@news.povray.org>
"Orchid XP v8" <voi### [at] devnull> wrote in message
news:48baa0c0@news.povray.org...
Virtual machines are soooo useful. I've been using them for some time to
test out beta software that I don't want breaking my machine, or to try out
things that I know are going to break stuff (hence the name of the VPC in
the picture)
Download 'lovevirtualpc.png' (131 KB)
Preview of image 'lovevirtualpc.png'
Date: 31 Aug 2008 12:27:29
Message: <48bac671$1@news.povray.org>
> out things that I know are going to break stuff (hence the name of the
> VPC in the picture)
My PC at work is barely powerful enough to run *one* OS, let alone two.
It _would_ be quite useful for test purposes though. (Aside from the
small matter that most of the things I want a test machine for relate to
specific hardware issues, which obviously a virtual machine doesn't help
with...)
However, the idea of being able to just plug in a USB stick and click an
icon and instantly have a complete Linux environment set up exactly the
way I want it is... pretty neat, actually. It's like I can just put my
life on a USB stick, keep it in my pocket, and never again find myself
sat at a PC that lacks a development environment. Haskell EVERYWHERE! >:-D
Only trouble is... it would have to be a pretty damned big USB stick.
DSL is nice, but rather minimal. (Shocker.) KNOPPIX is 700 MB
compressed, and decompresses to something like 4 GB...
http://blog.orphi.me.uk/
Date: 31 Aug 2008 12:30:31
Message: <pmhlb49pho3518hld68ob2f0h600na7nk4@4ax.com>
On Sun, 31 Aug 2008 18:16:57 +0200, "Gail" <gail (at) sql in the wild (dot) co
[dot] za> wrote:
A new email address, Gail!
Have you started your new job yet?
Regards
Date: 31 Aug 2008 12:52:20
Message: <48bacc44@news.povray.org>
"Stephen" <mcavoysAT@aolDOTcom> wrote in message
news:pmhlb49pho3518hld68ob2f0h600na7nk4@4ax.com...
> (dot) co
That's actually the email address related to my blog
(http://sqlinthewild.co.za) not a work address.
I have started the job. Going slowly at the moment. Should be picking up in
a week or two. Lots of clients are currently 'considering what they want'
Date: 31 Aug 2008 12:53:23
Message: <48bacc83$1@news.povray.org>
Also - virtual machines are SOOOO SLOOOOOW... :-/
Date: 31 Aug 2008 12:55:20
Message: <48baccf8@news.povray.org>
news:48bac671$1@news.povray.org...
>> VPC in the picture)
> My PC at work is barely powerful enough to run *one* OS, let alone two. It
That's one of the main reasons I went for a quad core with lots of memory
when I upgraded. So that I could have a couple of virtuals running and still
have the base machine usable.
For example, this afternoon, I was doing performance testing on SQL 2008 on
the base machine while I had a virtual running that was doing a 2005-2008
upgrade
You might have problems with IO speed if you do that. USB is a lot slower
than SATA.
Date: 31 Aug 2008 12:57:39
Message: <48bacd83@news.povray.org>
news:48bacc83$1@news.povray.org...
They can be. Depends how much resources you give them though.
Date: 31 Aug 2008 12:59:42
Message: <48bacdfe$1@news.povray.org>
>> two. It _would_ be quite useful for test purposes though.
> memory when I upgraded.
I can see how that would be the case. ;-)
>> an icon and instantly have a complete Linux environment set up exactly
>> the way I want it is... pretty neat, actually.
> slower than SATA.
Depends what you want to do. Running Damn Small Linux from a USB drive
is probably *faster* than running it from a CD-ROM due to the vastly
superior seek time. (CD-ROM drives typically have a horrible seek time!)
Also, DSL is based on KNOPPIX and uses a cloop compressed filesystem
image, so there's less data to shift (but more CPU load).
If I get bored enough maybe I'll benchmark it. But either way, it's a
trivial matter to copy a folder off the USB drive and onto a spare
folder on the local HD, run it for a while, and then just delete it when
you're done. That's about the easiest install/uninstall procedure
imaginable! ;-)
Date: 31 Aug 2008 13:01:05
Message: <48bace51$1@news.povray.org>
> VPC in the picture)
I use them at work, while one real server can easily hold up the work of
3 smaller servers, and having only one hardware makes less heat, uses
less power, costs less money and takes up less space.
Eero "Aero" Ahonen
    http://www.zbxt.net
