POV-Ray : Newsgroups : povray.off-topic : Strange GPU Server Time
5 Apr 2026 11:19:17 EDT (-0400)
  Strange GPU (Message 25 to 34 of 34)
Subject: Re: Strange GPU
Date: 19 Aug 2008 02:30:58
Message: <48aa68a2$1@news.povray.org>
> Where is that temperature measured though?
I don't know. I assume it's an on-die heat sensor. AFAIK, most modern
CPUs have them, so that they can turn up the fan speed or go into lower
power states if the die temperature gets too high...
http://blog.orphi.me.uk/
Date: 23 Aug 2008 09:26:01
Message: <48b00fe9$1@news.povray.org>
>>> Apparently the nVidia control panel no longer tells you your GPU
>>> temperature; you have to download and install an additional tool.
>>> Anyway, having just stopped using the GPU, the temperature was
>> Try showing the temperature in parallel with running the GPU (eg 3D
>> game in a window), IIRC when I did those sorts of tests before, the
>> GPU temperature dropped rapidly very quickly (eg 10-15 degrees in just
>> a second after exiting a game).
OK, I was just playing TF2 and noticed a few stray polygons. (I.e., the
driver update hasn't fixed this.) When I quit the game, I opened up the
Next time I play TF2, I must remember to open the monitor *first*. ;-)
I wonder why it gets so much hotter running a real game (which is
optimised to run smoothly) than running a stress test (which is designed
to use up as much GPU resources as possible)...
Date: 25 Aug 2008 02:59:41
Message: <48b2585d$1@news.povray.org>
Can't you play TF2 in windowed mode?  Or download some game demo that can be
played in windowed mode.
I guess the stress test wasn't written very well, or without the knowledge
of your particular card.  Lots of things in the GPU can be the bottleneck, a
well-written stress test should work this out and adjust the test details so
that every part is almost at maximum throughput.  If it's not very well
written, then - for example - the vertex shader might be loaded at 100%
while the pixel shader and texture lookup units are sitting idle for 90% of
the time.
BTW what is the CPU load during the stress test and TF2?  Maybe that is
affecting the GPU temperatures?
Date: 25 Aug 2008 13:15:28
Message: <48b2e8b0@news.povray.org>
> can be played in windowed mode.
I guess I could - but it would be very hard to play it and enjoy it.
FWIW, last time I played, I did remember to start up the monitor. I've
Which sounds pretty damned hot to me, but hey...
>> designed to use up as much GPU resources as possible)...
> knowledge of your particular card.
Given that it's an nVidia GPU running a stress test written by nVidia,
you'd think so. ;-)
AMD Athlon64 X2 4200+ socket 939.
(When I built the system, everybody said that socket 939 was going to be
the future. Now it appears that actually it's AM2... oh well!)
Date: 25 Aug 2008 19:22:28
Message: <48b33eb4@news.povray.org>
That's the CPU model; and the load while playing the game? :)
Date: 26 Aug 2008 03:36:31
Message: <48b3b27f@news.povray.org>
I meant just so you could see the temperatures while playing.
Date: 26 Aug 2008 03:57:53
Message: <48b3b781$1@news.povray.org>
Yes, and a lot of people were p***ed off about that...
...Chambers
Date: 26 Aug 2008 04:21:05
Message: <48b3bcf1@news.povray.org>
Chambers wrote:
>> be the future. Now it appears that actually it's AM2... oh well!)
AMD claim to have learned their lesson there. Certainly the new AM2+
chips all work in socket AM2 motherboards (although obviously not as
well as they could do).
But then, I heard people saying things like "this could be the end for
AMD" (referring to the way Phenom pales in comparison to Core 2).
Date: 26 Aug 2008 10:11:47
Message: <48b40f23@news.povray.org>
I doubt it.  A company the size of AMD doesn't just disappear overnight,
no matter how hard times are.
They've got time to get their act together.
...Chambers
Date: 26 Aug 2008 10:14:28
Message: <48b40fc4$1@news.povray.org>
Heh. I guess "oh noes, this is teh endzors!" just makes better headlines
or something. ;-)
They just bought ATi, so they can't be doing that badly. (Or,
alternatively, ATi were doing *really* badly!)
That put me in a bit of a spot. I always buy AMD CPUs, and I always guy
nVidia GPUs. So AMD buying ATi was a problem. Of course, currently AMD
is nowhere in terms of CPU performance, so if I were to upgrade sometime
soon, I'd have to go with Intel...
(Now and then I get these crazy ideas that I might buy a Mac or
something... This usually wears off when I look at the price list.)
