POV-Ray : Newsgroups : povray.off-topic : Idle curiosity Server Time
16 May 2026 15:16:41 EDT (-0400)
  Idle curiosity (Message 22 to 31 of 31)
Subject: Re: Idle curiosity
Date: 19 Aug 2008 02:32:36
Message: <48aa6904$1@news.povray.org>
>> OK. So I think I'm building my device using TTL, just so I don't
>> *break* the thing before it's finished. :-S
> What are you making BTW?  Could you use one of those cheap micro
> controllers instead?
Is it actually possible to program a micro controller in such a way that
it does what you expect it to?
It's an interesting idea, but it looks like the kind of thing where I'd
spend the rest of my life wondering why it doesn't do what I thought I
programmed it to do. (I.e., it looks impossible to debug.)
http://blog.orphi.me.uk/
Date: 19 Aug 2008 02:39:35
Message: <48aa6aa7$1@news.povray.org>
Ermmm, yeh, otherwise I'd doubt they'd sell many.
If you're thinking of making it from logic gates, it would seem like it
would only be a very short program in any language.  Last time I used them
was about 10 years ago and you had to do it in assembly.  But there was a
simulator you could run your code on.  Nowadays I suspect they are far more
sophisticated, I'm sure you can get a USB programmable one fairly cheaply,
just google for "USB microcontroller".
Date: 19 Aug 2008 03:49:27
Message: <48aa7b07@news.povray.org>
>> Uh... OK. I never did that before - but hey, maybe that's why half my
>> circuits didn't work?
> Hehe maybe, you certainly shouldn't assume that a not-connected or
> floating input will be treated as logic 0.
Hmm... Oh dear.
>> Damnit, I thought digital electronics was just about on or off. :-/
> It is if you follow the specifications of the particular logic family
> you are using, IIRC TTL is something like 0-0.8V for logic 0, and 2.5V
> and above for logic 1.
Really? I thought it was 4.5V - 5.5V for logic 1...
>> You speak of "3-valued logic" with it's "Hi-Z" mode?
> I don't know what it's called, but I remember it when we were doing
> simple memory circuits at university, you need to be able to output
> either 0,1 or floating to the data bus.
http://en.wikipedia.org/wiki/Hi-Z
http://en.wikipedia.org/wiki/Three-state_logic
Date: 19 Aug 2008 04:16:25
Message: <48aa8159$1@news.povray.org>
http://www.twysted-pair.com/74xx.htm
Note that the output from one chip can actually only drive 10 inputs, I
thought it was much higher than this but maybe I was remembering some other
chip series.
Yes, exactly. Did you read the 2nd paragraph there? ;-)
Date: 19 Aug 2008 04:32:00
Message: <48aa8500$1@news.povray.org>
OK, that's interesting. Wikipedia claims
"All standardized common TTL circuits operate with a 5-volt power
supply. A TTL input signal is defined as "low" when between 0 V and 0.8
V with respect to the ground terminal, and "high" when between 2.2 V and
5 V.[8]"
And yet, note [8] refers to the link above, which contradicts that
statement. I'm confused...
> other chip series.
Well, I'm unlikely to reach even that number...
Damnit, the whole *point* of digital electronics is to obviate the need
for resisters and complex stuff like that. A digital circuit should just
be an arrangement of logic gates, and nothing else! >_<
Date: 19 Aug 2008 04:40:13
Message: <48aa86ed$1@news.povray.org>
> "All standardized common TTL circuits operate with a 5-volt power supply.
> A TTL input signal is defined as "low" when between 0 V and 0.8 V with
> respect to the ground terminal, and "high" when between 2.2 V and 5 V.[8]"
I think they just took the average of the minimum output voltage and minimum
input voltage (2.0 and 2.4) to simplify things.
Date: 19 Aug 2008 04:50:45
Message: <48aa8965$1@news.povray.org>
Am Tue, 19 Aug 2008 07:32:37 +0100 schrieb Orchid XP v8:
I'd suggest Atmel's AVR series, either ATtiny or ATmega, depending on the
requirements, but I'd think a puny ATtiny13 will suffice. They're around
1.50€ each and impressively well equipped (although only 5 I/O pins can
be used, or 6 if you don't want to use the /RESET pin, which you probably
wont - it's used for in-circuit serial programming).
Atmel provides an IDE with an assembler and a simulator, you can install
a GCC variant for the microcontrollers too.
I've built a simple music-box (out of an cheap MP3-player) with a motor
for my baby-boy, with programmable run-time and motor-speed. All driven
by an ATtiny13 and a C program. It's really enjoyable, so give it a try!
Date: 19 Aug 2008 04:57:44
Message: <48aa8b08$1@news.povray.org>
Am Tue, 19 Aug 2008 04:50:45 -0400 schrieb Michael Zier:
> pins can be used,
That means: well equipped internally, obviously (timers, interupts, PWM
generators, EEPROM for non-volatile data storage, RAM [so C can be used
for stack-based programms] ... )
Date: 21 Aug 2008 16:37:16
Message: <48add1fc@news.povray.org>
> requirements, (...)
I second that! The ATMegas are really great. I have build a
radio-controlled alarm clock with an LCD and binary display.
Later we build an inverted pendulum as a university project (computer
science), controlled by an ATMega88 (2.60$). Complete Board was around 30$:
http://www.inverses-pendel.de.vu
Next project will be a 8x8x8 LED cube. I've made some tests and I'm
confident that an ATMega88 will be sufficent to control 512 LEDs at
100Hz refresh rate, while still having recources to receive frames to
display over a serial interface.
Manuel
Date: 22 Aug 2008 03:08:28
Message: <48ae65ec$1@news.povray.org>
> 30$:
Cool videos, we did that as part of our Engineering course, nice touch with
the water on the pendulum!
