![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Have you ever spent an entire day working on an important problem,
finally thought you had it solved, and then discovered that actually it
wasn't solved at all?
I hate days like that...
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Don't you mean:
"I hate days like this"
John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Many, many times. Had a network bridged loop problem a few years ago
caused (we think - never did find the root cause) by a failure in STP
between two redundant routers. The vendor's solution was "unplug the
cable between the two routers for 20 seconds, wait for the software to re-
route, and then plug it back in".
We "fixed" it the first day (we thought) and at 6 AM the next morning, it
happened again.
Just you try and do a sniffer trace of a billion packets and find the
cause. <sigh>
That was one of the nastiest we had. We ended up having to redesign the
system because the vendor couldn't figure it out.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> happened again.
> cause. <sigh>
Interesting. The network in our old building one day started being
clogged with STP packets. I never did find out why. It just *stayed*
clogged. At least, until we got our new building a few months ago.
Gee, 4 years. That's one hell of a long broadcast storm!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yesterday, actually.
I've spent the last month working on the code for a large art piece, the
design of which called for some motion detection which caused the
creatures in the piece to migrate towards the viewer. Can't actually do
mo-cap, and the critter's movements would get picked up, can't move the
camera because it would get flooded by the other projectors in the room.
So, we put it right over the screen, which is parallel to the floor and
on a little stand. Hand moves over the screen, the dark shadow moves the
little buggers.
Then someone gets the bright idea to make the back ground of the screen
dark.
I've 'fixed' the problem with detecting dark shadows against a black
background with so many different kludges the past few days. All of them
worked for a few minutes, until several people got near the display, or
stray light entered the room, or the other displays in the room got
turned on.
Finally, someone listened and made the background lighter again. The
first solution works again.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> re- route, and then plug it back in".
>> it happened again.
>> cause. <sigh>
>> the system because the vendor couldn't figure it out.
That it is....
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Let me suggest Rule of Start-Ups #27:
Do not go into a start-up that depends on results from several other
companies that are also all start-ups and have never done something like
this before.
Ever notice how people in a zombie movie never already know how to
kill zombies? Ask 100 random people in America how to kill someone
who has reanimated from the dead in a secret viral weapons lab,
and how many do you think already know you need a head-shot?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> this before.
I wish it was a start-up, then I could quit or demand to be heard.
Instead, I'm interning with the School of Visual Arts. They've done the
"Let's build something for a display" part before, just never the "Hey,
bright idea, let's use Flash CS 3 to do some 3D".
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I hadn't meant to imply this was *your* problem. :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Don't you mean:
Well, yeah.
I spent an *entire day* reimaging a laptop, and it still has exactly the
same problem.
Specifically, when you plug in a USB device, it detects that the device
has been plugged in, but it doesn't make any attempt to find drivers for
it. If you manually tell it to look for drivers, it finds them and the
device works. But it WILL NOT search for them automatically.
I cannot begin to describe how frustrated I am with trying to fix this
problem...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
