POV-Ray : Newsgroups : povray.off-topic : GPU rendering Server Time
16 May 2026 16:12:21 EDT (-0400)
  GPU rendering (Message 25 to 34 of 34)
Subject: Re: GPU rendering
Date: 22 Jul 2008 21:51:48
Message: <48868eb4$1@news.povray.org>
Orchid XP v8 wrote:
> Nicolas Alvarez wrote:
>> Orchid XP v8 wrote:
>>> (Also... I get the impression you need Vista for the GeForce 8 to work.)
>> I have a 8600 GT. Used to use it on Windows XP. Now running Linux.
> Oh, OK then.
You need Vista to run DirectX 10.
You can still access all the functionality of the card through OpenGL,
though, on XP, Linux, and MacOS.
In fact, I saw a demo that tricked XP into installing DX10, so you could
still run almost everything that claimed it required Vista.
...Chambers
Date: 23 Jul 2008 04:22:48
Message: <4886ea58@news.povray.org>
Oh right. I'll have to check to see whether CUDA works. >:-D
Basically there's a couple of graphics demos I've seen out there that
require a GeForce 8 or higher. How much do you want to bet that's really
because they want DirectX 10?
I find that a little surprising - AFAIK, Vista uses a radically
different internal graphics pipeline, so you'd think it wouldn't be
possible to make it work on XP at all.
http://blog.orphi.me.uk/
Date: 23 Jul 2008 04:53:21
Message: <4886f181@news.povray.org>
> I find that a little surprising - AFAIK, Vista uses a radically different
> internal graphics pipeline, so you'd think it wouldn't be possible to make
I imagine they've hacked the DX9 drivers to use some of the hardware
functionality that is only exposed under DX10 (and thus only in Vista).  I
would highly doubt that they have managed to replicate the Vista graphics
system on XP, so there is no way all applications designed for DX10 are
going to work.  To do that they would have had to pretty much rewrite the
whole Vista graphics system and parts of the OS GUI to run on XP, which
seems a bit unlikely.
Date: 23 Jul 2008 04:59:05
Message: <4886f2d9$1@news.povray.org>
> I would highly doubt that they have managed to replicate the Vista
> graphics system on XP, so there is no way all applications designed for
> DX10 are going to work.  To do that they would have had to pretty much
> rewrite the whole Vista graphics system and parts of the OS GUI to run
> on XP, which seems a bit unlikely.
They don't hack the DX9 drivers, and they don't replicate DX10 - they
actually trick DX10 into installing on XP, so you get full functionality.
Such an act, of course, is against the EULA, and I wasn't willing to
risk hosing my system enough to try it out - but it seemed interesting,
at least :)
...Chambers
Date: 23 Jul 2008 05:00:52
Message: <4886f344$1@news.povray.org>
Rather, they want certain functionality in the cards that's only
provided in the GF8 series and above, and that functionality is only
exposed by DX10.  So it's not that they want DX10, it's that they want
the card, and to use it to its fullest you need DX10 (or GL, but that's
another matter).
...Chambers
Date: 23 Jul 2008 06:14:57
Message: <488704a1@news.povray.org>
But that's impossible to keep full functionality, DX10 has many new function
calls that talk to the new window manager in Vista.  Such things simply will
not work in XP.  I suspect that at the moment very few programs actually use
those calls (to make developing DX9 and DX10 versions simultaneously
easier), so most programs probably will still work ok.  One example is how
Vista handles the mouse pointer compared to XP.
Of course a limited functionality of DX10 would be useful on XP, but I
imagine it's very buggy in places, which is why MS never bothered spending
the effort to really tidy it up and get it working properly.
Subject: Re: GPU rendering [98K]
Date: 23 Jul 2008 06:59:51
Message: <48870f27@news.povray.org>
> OK, so for anybody who knows about such things... Would it be feasible to
> render an Iterated Function System image using a GPU? And would it be any
> faster than using the CPU?
See attached image. That spike in the right CPU chart was where I started
the program.
I'm using the standard fern algorithm that's on the wikipedia page about
IFS.
Speed: 23.2 million iterations per second (512x512 points in parallel per
frame at 88 fps)
This is on an nVidia FX1700, if I get time I'll try it on my FX7900 tonight,
should be significantly faster.
I don't know how this compares to how fast a CPU would be, if I get time
later I will try out the same on the CPU for comparison.
The hardest bit was actually getting a good random number generator inside
the pixel shader.  What I ended up doing was to generate a big texture full
of random numbers at the start of the code, then in the pixel shader it
generates an xy coord based on a number of things and looks up the value in
the random texture at that position.  Seems to work well, because believe
me, if your random number generator is just a little bit wonky, the fern
doesn't look very nice at all!
Download 'image1.jpg' (99 KB)
Preview of image 'image1.jpg'
Date: 23 Jul 2008 07:16:18
Message: <48871302$1@news.povray.org>
> started the program.
Sweet! That looks pretty awesome.
Next step: realtime animation. ;-)
Date: 24 Jul 2008 03:38:07
Message: <4888315f$1@news.povray.org>
> frame at 88 fps)
> tonight,
OK so my FX7900 wasn't that much faster (37 million per second), despite the
specs indicating about 5x the pixel throughput.  The speed bottleneck is
obviously somewhere else in this code then, probably in the texture lookup
in the vertex shader, I guess that isn't very optimised yet.  If I had a
DX10 card I could use a geometry shader to cut the number of texture lookups
and vertex shader calls by a factor of 4, that would definitely speed things
up significantly.
Using a single core of an Intel E6400 I get 11 million iterations per second
(C++, but with no graphics).
Also it took me like 5 minutes to write the CPU code from scratch, but
several hours to get the GPU code working correctly!
Date: 24 Jul 2008 03:52:47
Message: <488834cf$1@news.povray.org>
>> frame at 88 fps)
>> tonight,
> the specs indicating about 5x the pixel throughput.  The speed
> bottleneck is obviously somewhere else in this code then, probably in
> the texture lookup in the vertex shader, I guess that isn't very
> optimised yet.  If I had a DX10 card I could use a geometry shader to
> cut the number of texture lookups and vertex shader calls by a factor of
> 4, that would definitely speed things up significantly.
Ooo... profiling GPU code... THAT SOUNDS FUN! o_O
> second (C++, but with no graphics).
Mmm, OK.
Heh. All hail the day when GHC has a GPU backend! ;-)
(Mind you, apparently Roman Cheplyaka is working on a physics engine
using Data Parallel Haskell as a Google SoC project. Apparently rigid
body collision is working already...)
