POV-Ray : Newsgroups : povray.off-topic : Need for speed Server Time
30 Jul 2026 06:42:45 EDT (-0400)
  Need for speed (Message 9 to 18 of 168)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Need for speed
Date: 13 Jul 2008 07:43:36
Message: <4879EAA1.7090008@hotmail.com>
On 13-Jul-08 13:10, Orchid XP v8 wrote:
>>> That's true. But assuming we want, say, a normal "double precision"
>>> floating point number, how many clock cycles would you estimate it
>>> takes to operation on? A dozen? A hundred?
>>   A lot. I don't believe *any* existing program for those processors
>> does double precision floating point calculations.
> You're probably right about that. (Just moving 8 bytes around has to
> take a minimum of 8 instructions, before you *do* anything to those
> bytes.) Just wanted to make it a like-for-like comparison. ;-)
8 cycles to read, 8 to write and some more to fetch all the read and
write opcodes plus some overhead.
>>   As he said, I don't think the term FLOPS even applies if floating point
>> calculations are done in software instead of in hardware.
> Floating-point operations per second. Does it matter *how* it does them?
> Surely the important point is how many of 'em it can do.
It does. Multiplication is much slower than addition. Some operation's
timing also depend on the specific bit patterns and overflows
encountered during the processing. Best case and worst case could easily
differ by a factor of 2 or more for one operation. So what time are you
going to use?
>>>> Both had a variable instruction set that took a variable amount of
>>>> cycles to execute and therefor the number of instruction processed
>>>> depended on the program and especially on the addressing modes used.
>>> I thought this was true for *all* processors?
>>   No. The idea with RISC processors is that each opcode has the same size
>> and takes exactly 1 clock cycle to execute.
> Interesting. I was under the impression that processors such as the
> Pentium can execute multiple instructions in parallel, and therefore
> several instructions can reach the "completed" stage in a single given
> clock cycle, but that each individual instruction still takes multiple
> cycles from start to finish.
yes? The number of FLOPS are given by the producer for the optimal case
of completely filled pipelines so effectively 1 operation finished per
cycle per core (for an arbitrary value of core). In benchmarks they use
a more typical case yet still the pipelines will make a good contribution.
Date: 13 Jul 2008 07:59:48
Message: <4879ee34$1@news.povray.org>
>   Actually the Z80 has 16-bit registers, 16-bit memory addressing and
> a 16-bit ALU (don't believe wikipedia's lies about calling the Z80 an
> "8-bit processor"). But anyways.
OK. Well I was actually thinking more about the 6502. I don't know much
about the Z80...
>   I think it becomes a bit fuzzy if it's done in software, because then
> it becomes a question of how optimized that software is.
Well OK. But you would have thought that various "best case" numbers
wouldn't differ by huge factors. (Now, if you wanted a *precise*
number... no, that would be rather arbitrary.)
>   When calculating MIPS it doesn't matter how many clock cycles it takes
> for one opcode to be fetched and passed through the entire pipeline and
> executed.
This is true. I was just making a side-comment that I didn't think that
*any* processor could complete one entire instruction in just 1 clock
cycle...
>> I'm only trying to figure out "how many zeros" are in the number, if you
>> see what I mean...
>> Is it 10 MIPS? 100? 1,000? 1,000,000??
>   The wikipedia article about the subject has some numbers.
Apparently, yes. (I'm damn *sure* I checked that article and didn't find
any numbers... But they're there now.)
http://blog.orphi.me.uk/
Date: 13 Jul 2008 12:51:14
Message: <487a3282$1@news.povray.org>
I'm pretty sure that's not correct.  Granted, it's been decades since I
did Z80 assembler. It had a 16-bit ALU for the addressing, for the most
part, but the registers were definitely 8-bit registers. Some of the
opcodes would pair them up into an address or some such, but you'd be
taking two registers to do it. Not unlike the "AX = AH:AL" sort of thing
the x86 series does.
Actually, I take that back, didn't the Z80 add some IX and IY registers
the 8080 didn't have or something?  The 8080 was 8 bit; the Z80 might
have had *some* 16-bit registers.
Almost everyone calls the processor the number of bits on the data bus,
fwiw, when talking about this stuff.  The 8088 was an 8-bit processor
and the 8086 was a 16-bit processor even tho they were 100% software
compatible.
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Date: 13 Jul 2008 13:30:59
Message: <487a3bd3@news.povray.org>
  It's exactly what the x86 does, and that's why the x86 series is a
16-bit processor (up to the 386).
  With the z80 you can have 16-bit literals, perform 16-bit ALU operations
(such as additions, substractions, shifts, etc), you can address the entire
memory with one single 16-bit register, etc. I don't understand what's *not*
16-bit about the z80.
  Just because the 16-bit operations are performed on pairs of 8-bit
registers that doesn't make it any less of a 16-bit operation. The
crucial thing is that you can perform a 16-bit operation with *one*
single opcode. You can also load a 16-bit value into such a pair with
one single opcode. This means the opcode is a 16-bit one.
  If the z80 is not a 16-bit processor, then neither is the 80286.
  How is that even useful? It might tell something about the speed at which
the processor can handle data, but it doesn't tell anything about the
processor itself.
  I understand "8-bit" to mean "has 8-bit registers, and you can only
perform an 8-bit operation with a single opcode, because registers can
only hold 8 bits of data". Likewise for any other bitsize.
  Btw, didn't the 386 usually have a 16-bit data bus? The 386 is still
a 32-bit processor, though.
Date: 13 Jul 2008 13:38:29
Message: <487a3d95$1@news.povray.org>
Orchid XP v8 wrote:
> Can somebody find out the typical MIPS and FLOPS for the following:
> - Commodore 64 (6510 @ ~1 MHz)
Most instructions took from 2 to 5 clock cycles, so I'd venture to say
that the 6510 ran between .2 and .5 MIPS.  Floating point is implemented
in software, and since the processor didn't have a hardware multiply
(and shifts were one bit at a time), it probably took dozens of machine
cycles for addition/subtraction and hundreds for multiplication and
division.  I doubt that it ever got much past ten kiloflops, and
probably averaged lower than that.
John
Date: 13 Jul 2008 13:49:30
Message: <487a402a@news.povray.org>
Orchid XP v8 wrote:
> Right. Suddenly integer-only algorithms seem like a Big Deal. ;-)
There were games on the Apple (6502-based) which had seven versions of
any given sprite graphic so that they wouldn't have to be shifted in
order to display them on the screen.  8-bit game programmers learned
much about squeezing every last drop of performance out of limited speed
and memory.
One of the best C64 games was called Pinball Construction Set, which had
the pinball moving with apparently natural motion and reflecting off of
barriers of any angle.  I should have looked at the code to see how they
pulled it off.
John
Date: 13 Jul 2008 13:54:51
Message: <487a416b@news.povray.org>
andrel wrote:
> http://e-tradition.net/bytes/6502/6502_instruction_set.html
I had the whole instruction set, and the opcodes, memorized at one point
in life.  There were less than 160 of them to remember, so it wasn't hard.
During the 1985-87 time frame, I wrote a word processor, in assembler,
for my C64, I entered most of it as machine code as I went along.  It
worked quite well (given that it only had to send Epson-compatible
formatting codes for things like italics, bold face, and so on); I wrote
a short novel using it.
John
Date: 13 Jul 2008 13:56:13
Message: <487a41bd@news.povray.org>
> pulled it off.
  Well, have you seen the best C64 demos?
Date: 13 Jul 2008 14:53:06
Message: <487a4f12$1@news.povray.org>
> and memory.
Wouldn't having 7 copies of the same data eat more memory?
Did it actually store 7 copies, or just precompute them?
Also... Apple made a 6502-based product??
> pulled it off.
The equations for simple 2D acceleration and reflection are fairly easy,
and probably implementable in fixed-point arithmetic. The *hard* part
about physical simulations is that they usually involve a huge number of
items; *one* marble isn't too big a deal.
Date: 13 Jul 2008 14:55:54
Message: <487a4fba$1@news.povray.org>
Jesus! o_O
I just wrote the assembly on a piece of paper, and when the program was
properly finished, it'd do the "assembling" part by hand. (I.e., open my
dad's book and leaf through the op-code table.)
Eventually I tired of this, and wrote by old assembler.
*cough*
Well OK - wrote my own program to look up op-codes anyway. I typed the
whole op-code table into the computer (remember DATA statements?) and
wrote a program that does a trivial linear search to find the op-code
for the mnumonic I typed in. It was astonishingly slow, actually... hmm...
I didn't know much about algorithms back then. Give me a break! I was
only 11...
