POV-Ray : Newsgroups : povray.off-topic : Astonishment Server Time
16 May 2026 20:20:28 EDT (-0400)
  Astonishment (Message 51 to 60 of 90)
Subject: Re: Astonishment
Date: 15 Jul 2008 13:13:58
Message: <487cdad6@news.povray.org>
On Tue, 15 Jul 2008 16:56:40 +0100, Orchid XP v8 wrote:
> NASA?
> Aren't they those guys who tried to launch a rocket with a faulty
> O-ring?
Um, yeah, and it blew up, killing all crew on board. :-(
Jim
Date: 15 Jul 2008 13:18:16
Message: <487cdbd8$1@news.povray.org>
On Tue, 15 Jul 2008 17:26:23 +0100, Orchid XP v8 wrote:
>>> NASA?
>>> O-ring?
>>   Take two programs of comparable size made in Microsoft and in NASA,
>> and compare the total amount of bugs found during testing. The former
>> will have in the order of thousands, while the latter will have
>> something like 10.
>>   And the latter while never exceeding budgets nor deadlines.
> A NASA rocket exploding is something like an M$ product having a severe
> security vulnerability.
NO, it isn't.  People haven't died because of MS security vulnerabilities.
> So far, NASA has had, what, 2 major incidents like this? In its entire
> history?
Three that caused fatalities.  The first was a fire in a Mercury 7
capsule during a test - pure oxygen atmosphere + spark = fire.  All three
crew members were killed.  The most recent two were the Challenger and
the Columbia - the first exploded about 23 seconds into the launch, the
second burned up on re-entry.
Now, if you count the rockets that were unmanned that blew up, there were
a fairly significant number of very spectacular failures.  Find a copy of
"When We Left Earth:  The NASA Missions" to see some archive footage.
Jim
Date: 15 Jul 2008 14:05:40
Message: <487ce6f4$1@news.povray.org>
Yes, but that's because nothing M$ makes is *capable* of killing anybody
[directly]. So a security flaw is about the most serious malfunction it
*is* capable of. :-P
>> history?
I was almost right. :-D
Either way, the number of severe security issues from M$ dwarfs this
number by any reasonably reconing.
Isn't that like counting the number of bugs M$ had *and fixed* before
"launching the product"?
http://blog.orphi.me.uk/
Subject: A reply
Date: 15 Jul 2008 14:06:44
Message: <487ce734$1@news.povray.org>
Well, at last I have a reply!
They said I can keep the mug, and they'll send me the thing I actually
ordered shortly. Seems reasonable to me... (Assuming they get it right
this time. I imagine they will.)
Date: 15 Jul 2008 14:16:34
Message: <487ce980@news.povray.org>
Orchid XP v8 <voi### [at] devnull> wrote:
> Space is a pretty harsh environment, so there's a whole array of
> possible malfunctions that could end a mission - broken motors or
> sensors, compromised computer hardware, corrupted RAM portions, or
> conceivably simple programmer error. The last one would seem one of the
> easiest classes of fault to prevent, but sure, one might have slipped
> though somewhere...
  The good thing about software bugs is that if they are caught before
problems happen, they can be fixed even if the probe is half-way through
the solar system from here. Hardware problems can't.
Date: 15 Jul 2008 14:39:32
Message: <487ceee4$1@news.povray.org>
>>> severe security vulnerability.
>> vulnerabilities.
That is the most serious malfuction, probably, but equating that with the
loss of life doesn't work for me.
>>> history?
>> were a fairly significant number of very spectacular failures.  Find a
>> copy of "When We Left Earth:  The NASA Missions" to see some archive
>> footage.
Um, no, because they happened during launches.  They just happened to be
unmanned launches.
Jim
Date: 16 Jul 2008 03:19:12
Message: <487da0f0$1@news.povray.org>
> Some, but definitely not all. Many places a small fix-up may not need a
> day's worth of meetings, but with the shuttle, not a single line of code
> can be changed.
The same happens for code for cars, but IIRC only after the first version
has been released and tested during development.  After that point there is
a huge amount of resource put onto testing and evaluation, and after it has
been "qualified", no changes are allowed without a big meeting and
discussion for even tiny changes.
> Ah, I figured the avionics linkages would be hydraulic, not computer
> controlled.
No, too risky to have lots of hydraulic lines going all round the plane,
also harder to detect when they've (partially) failed and automatically
switch to a backup system etc.
It's funny, because a lot of the time people regard electronics as much more
unreliable than mechanical systems.  It's just the failure mechanisms are
different, but certainly electronics can be made just as reliable as
mechanical systems, and even more reliable if necessary.  Take for example
when cars changed from a mechanical distributor to an electronic system ...
no more getting out the WD40 to dry it out after heavy rain!
>> about to switch it on, and then as he flicked the switch, the mass moved
>> extremely quickly to point B, past point B, kept accelerating and smashed
>> off the end of the demo. Everybody laughed.
> Heh. Ouch...
Yeh IIRC, his comment was something like "ok, well that didn't seem to work
then", at which point someone shouted out "no s4!t" :-)
The other system they seemed to be very fond of was the inverted pendulum
controller.  The pivot of the pendulum can be moved left and right by a
motor/pulley system, and the idea is to keep the pendulum's tip upright.
After a hideous amount of maths you finally get to implement it on a real
system and watch how some people's go totally ape and smash against the end,
while most people got theirs working eventually.  In the end it is really
cool to be able to add weights and stuff to the top and wobble it, all the
while the motor is making tiny adjustments to stop it falling over.
Date: 16 Jul 2008 04:54:39
Message: <op.uedm02qkc3xi7v@news.povray.org>
And lo on Tue, 15 Jul 2008 13:02:36 +0100, Stephen <mcavoysAT@aolDOTcom>
did spake, saying:
> On Mon, 14 Jul 2008 11:20:31 -0700, Darren New <dne### [at] sanrrcom> wrote:
>> Stephen wrote:
>>> Also when the Romans were in power Greece was subjective to them and I
>>> would think that they would talk about Jupiter or Jove rather than
>>> Zeus to Romans out of respect.
>> I wasn't sure that was the case. My ancient history isn't too good. :-)
> I guessed :-)
Saying that though the Romans (and others) were quite happy with the idea
of localised deities. They might know that Zeus and Jove were the same
god, but in a Greek temple they'd most likely use the name by which he was
known there.
When in Rome...
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 16 Jul 2008 07:34:50
Message: <487ddcda$1@news.povray.org>
Lets be fair. The security issues are only security issues because of
the ubiquity of the product. I'm sure other vendors' products have a
good number of security problems, but they aren't exploited because no
one cares to exploit it.
Date: 16 Jul 2008 08:05:30
Message: <487de40a$1@news.povray.org>
I doubt that M$ is the *only* vendor that produces insecure software.
However, I reject the claim that *all* software is equally faulty. This
is simply not the case. There are products that work far better than
anything M$ has produced so far.
