POV-Ray : Newsgroups : povray.off-topic : Paraniod Server Time
17 May 2026 06:16:37 EDT (-0400)
  Paraniod (Message 26 to 35 of 125)
Subject: Re: Paraniod
Date: 4 Jul 2008 03:58:13
Message: <486dd815$1@news.povray.org>
>>> I would have recommended a USB memory stick, myself.
>> That only works if you *have* a USB stick. :-P
>     If the files are that important, I'm sure he can buy one. They're
> cheap.
Not in 20 minutes flat, no.
[Recall that we're in the middle of nowhere.]
http://blog.orphi.me.uk/
Date: 4 Jul 2008 04:03:50
Message: <486dd966@news.povray.org>
>> I've been saying that for *years*.  I'd get questions every once in a
>> while from managers wanting to keep their IT people out of files on the
>> network.  My first question was always "why don't you trust your IT
>> admins?".
> I see a similar question on the SQL forums all too often.
> How do I prevent the database administrators from seeing the
> views\procs\data in a database?
> Simple answer: You don't
Er... like, WTF?
The sysadmin has absolute power. They can do *anything*. Up to and
including completely replacing the entire OS with one that will allow
them to do whatever they want. You *cannot* prevent somebody who wields
that kind of power from doing whatever the hell they want - so they had
*better* be worthy of such trust!
Date: 4 Jul 2008 05:18:47
Message: <486deaf7$1@news.povray.org>
On Fri, 04 Jul 2008 09:03:49 +0100, Invisible wrote:
> Er... like, WTF?
Well, it's not that difficult to understand - this is what happens when
technically incompetent people decide how to implement policy.
From what you've seen, you've witnessed some of this behaviour firsthand.
That said, there are ways, for example, to prevent a sysadmin from seeing
files in a filesystem.  File-level encryption, for example - or directory-
level.  With Linux, this is almost so simple as to be trivial using encfs
(of course with requisite Linux-foo skills).
But ultimately, yes, you're right - a sysadmin needs to be worthy of the
trust placed in them.  That's rule #1.  They may not be able to get at
the encrypted files, but the sure could still nuke them.
Jim
Date: 4 Jul 2008 05:22:12
Message: <486debc4$1@news.povray.org>
What's technical? The sysadmin is, by definition, God. You can't stop
God from doing things. QED. You don't need to know a thing about
technology to comprehend this extremely simple principle.
Yeah, sure, but the *key* has to be stored somewhere. ;-)
Date: 4 Jul 2008 05:40:10
Message: <486deffa@news.povray.org>
>> directory-
Just use Windows built-in encryption, that works off your login password
doesn't it?  Even if the admin can remotely log in, they won't be able to
read your encrypted files unless they somehow get your password.
Or just zip things up with a password.
Date: 4 Jul 2008 05:50:00
Message: <486df248@news.povray.org>
> doesn't it?
Wouldn't that mean that every single time you change your login
password, all of your files instantly become unreadable?
What I suspect happens is that it's actually asymmetrically encrypted,
and the decryption key is encrypted with your login password. That means
if you change your login password, you gotta change one thing - the
encrypted decryption key - and all your stuff is still accessible.
> to read your encrypted files unless they somehow get your password.
Do you know what the "use reversible encryption" tickbox in AD does? >:-D
Now *that* could actually work. Especially if you use that password for
nothing else. Now all the sysadmin needs to do is install a keylogger...
oh, wait... ;-)
Anything you can do, the sysadmin can undo. He controls the machine
you're using. You can't win. [Theoretically at least. In practice you
can make it too hard to be worth the bother.]
Date: 4 Jul 2008 06:05:00
Message: <486df5cc$1@news.povray.org>
You'd think so, but clearly the evidence suggests it's not that obvious -
otherwise they *would* have grasped it.
>> seeing files in a filesystem.  File-level encryption, for example - or
>> directory- level.  With Linux, this is almost so simple as to be
>> trivial using encfs (of course with requisite Linux-foo skills).
The key is in my head.  If you can extract my password from my brain,
you'll have proven that you *are* God.
Jim
Date: 4 Jul 2008 06:09:33
Message: <486df6dd@news.povray.org>
If the built-in encryption keys off the login password only (ie, the
login password just unlocks the encryption key), then as an admin, you
just have to change the user's password.  If there is a weakness to
encfs, that's what it is as well - the key is stored in an encrypted
keystore that's locked with the password (so I understand).  But it's not
the login password, so if you root my machine and change my login
password, you're still not getting at the encrypted files.
Still, you could use something like truecrypt to get around that if it's
that critical the data be unreadable without the key.
That's a pain to use, though - used to do that back in the early 90's - I
even wrote a wrapper program that took a randomization key and generated
a 256-character pseudo-random pkzip password for that purpose.  Always
had to purge deleted files from the system after working on the code a
bit (old NetWare server, 2.15 and then 3.11).
If you don't securely wipe the unpacked files after you're done with
them, then they can be recovered from the drive with relative ease.  And
while you're using them, the files are exposed.
Jim
Date: 4 Jul 2008 06:14:21
Message: <486df7fd$1@news.povray.org>
> What I suspect happens is that it's actually asymmetrically encrypted, and
> the decryption key is encrypted with your login password. That means if
> you change your login password, you gotta change one thing - the encrypted
Yeh that's probably more like it - I just know that if you forget your login
password you can never get back your encrypted data.
>> Even if the admin can remotely log in, they won't be able to read your
AD? I normally tick the box in "encrypt" box in the file properties window.
> oh, wait... ;-)
You can outsmart a key logger by simply typing in part of your password,
then clicking the pointer to move the cursor, and typing in another bit,
click again etc.  On my bank log-in I have to choose the numbers with the
mouse, exactly to avoid keyloggers working I guess.  But I guess then the
admin can install a mouse and screen logger too ;-)
Date: 4 Jul 2008 06:24:29
Message: <486dfa5d$1@news.povray.org>
> login password you can never get back your encrypted data.
Oh, you need only guess what the password is. ;-)
Active Directory. (The thing Windoze now uses to manage network user
accounts.)
There's a tickbox that allows legacy systems to interoperate with
Windoze. Legacy systems that require you to send the user's password in
the clear. What this option basically does is allow the sysadmin to know
what each user's password actually is. (Normally this isn't possible -
the server only stores a hash *of* the password, not the password itself.)
> click again etc.  But I guess
> then the admin can install a mouse and screen logger too ;-)
...exactly.
And if that doesn't work, a kernel-level debugger can see every octet of
data in the machine's main RAM and swap file. There really is no escape.
