> That's more or less the level of what I'm trying to do too. I make POV-Ray
> render some insane stuff, build AVIs out of it, and then put it onto a
> real DVD so it can be played anywhere. (Plus playing uncompressed video
> seems to stress my HD.)
For playback on PCs (and on the PS3 connected to my TV) I usually convert to
h264 which is really good for high resolution. I found a program called
xvid4psp which is free and has a nice GUI to do all the conversion, without
needing some huge command line only to find that your player doesn't support
"adaptive b-frames" or some pyramid thingy.
> The thing I've got seems to crash a lot. It allows you to do some limited
> video editing, but stubbornly refuses to allow you to do things like
> insert pauses or writing and so on.
Oh, Windows Movie Maker is good for stuff like that, it's what I usually use
for simple editing with text, still images, pauses etc. I've got a feeling
that it's only the version that comes with Vista that lets you do HD quality
though, but I guess that's not a problem for you.
> You do realise that I was *in* Curries looking at new TVs only a few days
> ago, right?
That's funny, on their website they have plenty of HDTVs under 400 pounds.
> Really? That's a rather sudden price drop, don't you think? I mean, the
> format is still brand-spanking-new.
Hmm I don't think so, once the PS3 came out, basically nobody could sell a
blu-ray player for above 400 pounds. Since then the prices have gradually
come down from 350 or so to the 200 you see today.
> Are there even any BluRay titles to play yet?
Amazon only have 1507 titles listed.
> Now that's just puzzling. I tried to use Windows Movie Maker once, and it
> wouldn't do *anything* I wanted it to do. Sure, I could take a bunch of
> videos and join them together to make one video. But that seemed to be the
> sum total of its abilities.
You didn't notice the fades and text and all the effects you could add then?
> convert to h264 which is really good for high resolution. I found a
> program called xvid4psp which is free and has a nice GUI to do all the
> conversion, without needing some huge command line only to find that
> your player doesn't support "adaptive b-frames" or some pyramid thingy.
I usually just use MPEG-1. It works everywhere, and it's easy to create.
(Doesn't look quite as nice as a DVD though.)
I used to use Huffyuv, but it only gives you a few percent compression,
and then one day it spectacularly stopped working on my PC and I nearly
lost a whole load of renders that had taken months to produce. o_O
>> days ago, right?
Well, unless they only put the expensive ones out on display or something...
>> the format is still brand-spanking-new.
> a blu-ray player for above 400 pounds. Since then the prices have
> gradually come down from 350 or so to the 200 you see today.
Oh. So it's Sony's fault? ;-)
OK, there is no way anybody could have shot over 1,000 movies in less
than 4 months. That's impossible. They must just be rereleasing SD
content printed on BluRay disks...
>> it wouldn't do *anything* I wanted it to do. Sure, I could take a
>> bunch of videos and join them together to make one video. But that
>> seemed to be the sum total of its abilities.
> then?
I noticed the faced, and the fact that these are limited to a maximum
duration of 2 seconds - the exact limitation I was hoping to get round
by using Windows Movie Maker instead of the other thingy.
http://blog.orphi.me.uk/
> OK, there is no way anybody could have shot over 1,000 movies in less than
> 4 months. That's impossible. They must just be rereleasing SD content
What makes you think that older films only exist in SD format? Do you think
they always used to show SD format at the cinema?!?! :-O
> duration of 2 seconds - the exact limitation I was hoping to get round by
Don't have that limitation here, just go to timeline view and drag the video
clips around after you've applied the transition.
487365a2$1@news.povray.org...
> Other than audio and video data (which is inherantly large), I can't think
> of anything you can do with a computer that actually uses much memory.
At least, having a lot of memory lets you open many RAM-hungry apps at the
same time. I can have FinalRender gobbling memory to render a huge scene and
still be able to edit images with Photoshop while having Firefox opened with
lots of tabs etc. Also, there are many professional applications where more
RAM = bigger whatever is the goal of the application. I'm working with
linear programming for instance, and more RAM = larger models.
G.
> think they always used to show SD format at the cinema?!?! :-O
Er... yes. (Let's face it, at the cinema the pictures are usually more
blurry than on TV! For some reason, they never bother to get the
projector sharply in focus...)
> video clips around after you've applied the transition.
I'll try it when I get home.
OK, but all of what you've described is pretty unusual for home use.
Sure, I run flam3, which eats RAM like candy. But that's because I'm a
nerd. Normal humans don't do things like that.
At any rate, none of this explains why *Vista*, by itself, requires
multiple gigabytes of RAM. (And therefore, presumably, if you want to
run *real applications* that require gigs of RAM, you have to add even
more RAM to your system to accomodate them!)
> blurry than on TV! For some reason, they never bother to get the projector
Never noticed that before at the cinemas I've been at. What I do notice is
that even when you walk right up to the screen at the end, the text of the
credits still looks good, even when you've got 1% of the screen taking up 1
foot right infront of your face. Now try going up close to your TV during
the end credits of a film and seeing how detailed the text looks... There's
an order of magnitude difference.
Invisible wrote:
> I'm just loving the concept of "only 1 GB of RAM" - as if that's a
> "small" amount or something...
Yeah, I was looking at machines in Fryes yesterday (just because I was
there) and noticing all of them had either 2 or 5 gig, for fairly
reasonably-priced machines. (Not cheap, mind, but below mid-range even
had 2G of RAM.)
Helpful housekeeping hints:
Check your feather pillows for holes
before putting them in the washing machine.
scott wrote:
> Because when everyone had only 256 MB of RAM, there weren't cameras that
> could generate 10 mega-pixel images, video cameras capable of creating
> 1920x1080x30fps resolution video, DVDs that could store 8GB worth of
> game data, graphics cards that were capable of rendering billions of
> multiply-textured triangles per second etc etc.
I remember when Myst first came out on a CD. Wow, over 600 meg on one
read-only disk. "Well," I thought, "there goes the end of game pirating.
You'd never be able to copy such a thing onto a hard drive."
And yeah, it's nice to have a 10G text file, wonder how you're going to
trim lines off the top and bottom conveniently, and then realize you are
on a 64-bit machine with 16G of RAM, so you just fire up VI.
Wouldn't scrolling the file take more than the linetime of the universe?
