POV-Ray : Newsgroups : povray.off-topic : Microphones Server Time
11 Jul 2026 06:06:20 EDT (-0400)
  Microphones (Message 2 to 11 of 31)
<<< Previous 1 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Microphones
Date: 11 Jun 2008 16:48:59
Message: <48503a3b$1@news.povray.org>
My guess is that it's just picking up the wrong input in the app.  The
mic probably works fine (try plugging it into the mobo mic jack and see
if it behaves properly).
Jim
Date: 11 Jun 2008 18:25:47
Message: <485050eb$1@news.povray.org>
48501913$1@news.povray.org...
> OK, so here's an irritating problem...
Maybe this microphone is an electret one and need to be powered (whitch your
motherboard microphone input does but not your additionnal soundcard)
Maybe you need to switch something like 'plugin power' somewhere (either
hardware or software switch).
Be careful your preamp may have a ' 48v phantom power' option but it is way
too much for a PC microphone.
Marc
Date: 12 Jun 2008 03:10:48
Message: <4850cbf8$1@news.povray.org>
> A while back I bought an external sound card. I'm very happy with it by
> the way. But then I unplugged my microphone from my PC's built-in sound
> card and plugged it into the external one. I can't hear a damned thing.
As Marc said, your microphone is probably a powered one, and PC sound cards
normally provide power on the mic socket.
> "OK, so it needs a line input" I thought. So I went out and bought a
> microphone preamp. And you know what?
> I still can't hear anything.
The pre-amp is probably expecting a real microphone, not one that needs
power.
Date: 12 Jun 2008 05:58:51
Message: <4850f35b@news.povray.org>
4850cbf8$1@news.povray.org...
> power.
Some top-notch microphones need power :-)
on professionnal equipment 48V DC phantom power through ballanced wiring is
commonly used.
http://en.wikipedia.org/wiki/Phantom_power
But as I said it does not fit to PC microphones that use plugin power
A detailed arcticle :
http://www.epanorama.net/circuits/microphone_powering.html
Marc
Date: 12 Jun 2008 06:20:05
Message: <4850f855@news.povray.org>
Actually I'm pretty sure my PC microphone is a crystal mic...
[The microphone that works is marked as "dynamic", whatever that means.]
I had a go with my dad's test meter. At 0 Hz, the working mic has a
resistence of about 600 Ω, whereas the non-working one is about 1.2 kΩ.
I don't know whether that has anything to do with anything. [I don't
have the specifications for my outboard sound card to hand...]
http://blog.orphi.me.uk/
Date: 12 Jun 2008 06:39:37
Message: <4850fce9@news.povray.org>
4850f855@news.povray.org...
UH? do they still sell that? Usually they are electrets
It means a moving coil microphone, no need for power
> resistence of about 600 ?, whereas the non-working one is about 1.2 k?. I
> don't know whether that has anything to do with anything. [I don't have
For the dynamic microphone you measure the DC resistance of the coil .
Electret microphone are buffered by a FET and insulated from DC by a
capacitor.
You can't measure a useable impedence at 0 Hz :-)
maybe you measured between rim (power +) and sleeve (ground)
http://en.wikipedia.org/wiki/Electret_microphone
Marc
Date: 12 Jun 2008 06:49:26
Message: <4850ff36$1@news.povray.org>
Sure - why not? They sell crystal ear pieces too - very useful with
home-made crystal radio sets. And let's not forget, picture speakers use
crystals too...
Right. So a reverse speaker then?
> For the dynamic microphone you measure the DC resistance of the coil.
Right. So the working mic has a DC resistence of 600 Ω.
> capacitor.
OK. So assuming it really is electret, I can't measure its impedence
meaningfully.
I'm 70% sure this is the guy BTW:
http://www.maplin.co.uk/module.aspx?ITAG=SPEC&ModuleNo=24698&doy=12m6#spec
Date: 12 Jun 2008 07:51:34
Message: <48510dc6$1@news.povray.org>
4850ff36$1@news.povray.org...
> crystals too...
The frequency response of crystal microphones is often limited to a
relatively narrow band . They boost treeble and have poor basses.
It may be good for a close-miking of voice to enhance speach recognition but
they are far from all-purpose applications.
Exactly but not optimized for that use :-)
> meaningfully.
The *stereo* (the exact name is TRS for Tip/Rim/Sleeve) jack for a mono
microphone makes me suspect it is an elecret.
The rim is for power +.
Marc
Date: 12 Jun 2008 09:27:44
Message: <48512450$1@news.povray.org>
Mmm - I understand you can also make a mic out of a speaker. But it
tends not to work well. ;-)
Hey, I wonder - can I use the alternator on my car to drive the car
instead of recharge the battery? :-D
Hmm... a stereo jack on a mono microphone... yeah, that does seem a
little suspect.
Oh goodie. Now I need to find some power from somewhere. :-/
Date: 12 Jun 2008 09:47:35
Message: <485128f7@news.povray.org>
48512450$1@news.povray.org...
Out of curiosity, whitch model is your additionnal soundcard?
Marc
