"Darren New" <dne### [at] sanrrcom> wrote
> somebody wrote:
> >> Just hope that they don't ask you to write the answer...
> Yes. Blame the tequila. (I knew someone would bring that up. :-)
> > Which, by the way, is of course "because the covers are round".
> Nope.
Wrong you are, but if you want a more verbose answer:
In "space", the natural shape for anything is a sphere (maximal symmetry for
anything finite). On the surface of the earth, gravity breaks symmetry
(vertical axis is different from the others) so spherical symmetry reduces
to cylindrical symmetry. The natural symmetry for *anything* on the surface,
barring any other constraints, is therefore cylindrical. Since there
typically is no good reason (ask not why is X, but why is not not X) to make
manhole covers non-cylindrical, most are cylindrical. Hence the holes.
Errr, no. Indeed, if you actually look, most manholes on the *sidewalk*
are not round. And even small "manholes" like for meters and such, as
big as your spread hand, are round when they're in the street.
Chances are you won't just guess unless you've actually ever seen the
outside of a manhole.
Given the hint that they're all round in the street and they're not
round on the sidewalk... any more takers?
(As for the "so it won't fall in the hole" bit, people invented hinges
long before they invented manholes.)
"That's pretty. Where's that?"
"It's the Age of Channelwood."
"We should go there on vacation some time."
John VanSickle wrote:
> A manhole is *circular* minimize the amount of extra material needed to
> make it impossible for the cover to fall into the manhole.
Are you guessing, or have you actually (say) worked someplace that
designs manholes? :-)
> Minimizing the extra material is important because manhole covers are
> heavy;
Even six-inch wide manhole covers covering holes a foot deep are round.
> Also, a circular manhole fits in any direction. A polygonal manhole
> cover has to be turned to fit, or else be picked up again (these things
> are heavy) or the corners will wear (or break) off after a bunch of
> near-misses.
Hinges are your friend. :-)
I can't actually agree on this, but it can depend on the country etc, so
that doesn't matter. There's 2 reasons:
1) No corners -> no tire fatalities.
2) Harder pressure on ground surface (there can be tonnes of masses on
one axle on the street) -> harder construction (cylindrical shape is
better to handle pressure from outside).
Eero "Aero" Ahonen
http://www.zbxt.net
aer### [at] removethiszbxtnetinvalid
On Sun, 08 Jun 2008 08:32:33 -0700, Darren New <dne### [at] sanrrcom>
I'm not sure what you're thinking about but hinges are not your friend
when your talking about manholes. The manhole cover can be left up.
(Naughty, naughty) Also hinges would be a weak point and liable to
break. They would also involve lifting the heavy manhole cover upright
which would take more effort than lifting it up an inch or two and
sliding it away.
Regards
"Darren New" <dne### [at] sanrrcom> wrote in message
news:484b0f3d$1@news.povray.org...
> Actually, I've never seen anyone get the answer write to "why are
> manholes round." I almost hope they ask me that at my next job
> interview, because the interviewer probably doesn't know either.
> Darren New / San Diego, CA, USA (PST)
Round manholes fit whichever orientation you drop them.
Round manholes cover (usually) cyclindrical access spaces which are
better able to resist ground pressures and (again) permit putting
thiings
into them without concern for orientation. (Round pegs/square
holes:
square pegs/round holes).
Lots more reasons, but it is a field question as opposed to some
design or theoretical question: what works best and easiest is
what is done.
If you've ever worked with manhole covers you know it is enough
work
without having to fit corners.
(also - odds are any sufficeintly sized circular manhole cover will
fit
the odd hole and the odds are that covers with corners will not
work as a --- cover.)
news:484bfade@news.povray.org...
make
That's not a given by a long shot. Manholes here and all places I've seen
are round in the sidewalk too. The city isn't going to maintain two
different types of manholes unless there's a good reason (the sidewalk ones
might be thinner, I naturally did not inspect carefully). The large
rectangular ones you see on sidewalks on cities are not manholes but grills.
There are also rectangular storm drains (some are even formed into an S
shape between the road and the sidewalk for accessibility). However, neither
grills nor storm drains are meant for a "man" to go through a "hole", so are
not manholes, nor are the holes in the ground for meters that you mention.
>> near-misses.
Hinges introduce additional complexity and are subject to breakage under
stress...
Jim
> thiings
> holes:
You left out the fact that a round cover will not fall into the manhole
no matter how you might screw up opening it.
And what everyone so far has missed is that roads get repaved. The
manhole screws into the vault at the bottom (so you can make it flush
with the surface of the road) and has threads on the outside. When you
repave the road, the first thing you do is give all the manholes an
extra crank or two to lift them up an inch or so, so they stay flush
with the surface of the road after you add more asphalt.
Plus, of course, it takes less metal to make a round cover to cover a
certain opening than any other shape, which is important when you're
planning to place millions of manholes and calculating how much your raw
materials will cost.
Helpful housekeeping hints:
Check your feather pillows for holes
before putting them in the washing machine.
