POV-Ray : Newsgroups : povray.off-topic : AVI woes Server Time
7 Sep 2024 13:21:55 EDT (-0400)
  AVI woes (Message 1 to 7 of 7)
Subject: AVI woes
Date: 21 May 2008 16:29:15
Message: <4834861b$1@news.povray.org>
So I *finally* got around to obtaining a bmp->avi animation program by
the name of AviCreator. It's the one with a two-star rating at
povray.org's link section. Works fine, AFAICT, with 200x200 cyclic
animations running almost perfectly in Windows Media Player. The trouble
comes when I make a larger resolution animation, or compress one of any
size (saved as a WMF). Stuttering, jerky execution and slow looping are
the main problems plaguing these other animations.
Can anybody tell me why these problems are occurring? My system is
reasonably fast. My system is composed of a multi-core 2.4ghz CPU, 2gb
RAM, good nVidia card and Windows XP. An animation should run at
full-speed. DVDs work just fine. Do I need to convert the AVIs into
MPEGs or something? Somebody must have run into a similar problem...
Sam
Subject: Re: AVI woes
Date: 21 May 2008 17:25:27
Message: <48349347$1@news.povray.org>
> full-speed.
My best guess is that your harddrive isn't fast enough. I see exactly
the same problem - animations above a certain size just won't play smoothly.
DVDs use MPEG-II compression, so there's vastly less data per second to
be whisked around.
Basically it doesn't matter *which* codec you use, just so long as you
compress it down to a bitrate your I/O system can handle. [Which, unless
your I/O system is especially slow, should be a pretty easy target to hit.]
http://blog.orphi.me.uk/
Date: 21 May 2008 17:40:44
Message: <483496dc@news.povray.org>
  I hope that's not the one which loads *all* the input images into memory
(in raw format) before even attempting to write the avi file...
  I don't know about your problem, but I bet there are better programs
for what you want to do. VirtualDub is a popular free program for creating
and converting avis (using any codec installed in your system). While it's
not completely intuitive at first how you convert a series of image files
into an avi with VirtualDub, it's perfectly possible.
  Another free alternative, which is the de-facto encoder in linux,
is mencoder (its Windows port, to be more precise). Of course it's a
powerful "hacker tool" and thus not designed for maximum user
friendliness, so you might find it quite daunting at first. OTOH once
you learn to use it, it can be quite handy.
  (OTOH, VirtualDub probably meets your needs, and it's a bit easier
to use, so you might want to check that first.)
Date: 21 May 2008 18:48:03
Message: <4834a6a3$1@news.povray.org>
>> full-speed.
> smoothly.
> be whisked around.
This explanation makes some sense, though I'm not sure why a compressed
WMF file performs worse than an uncompressed AVI. Do you know of any
lightweight AVI->MPEG converters for Windows?
Sam
Date: 21 May 2008 18:55:48
Message: <4834a874@news.povray.org>
Yes, it's the one. I know this because I have to unload/reload all the
images after writing new ones from POV, or else the animation is not
changed. For being a simple program, it's not very user-friendly.
I'll give VD a try (that sounds a little wrong...).
By "hacker tool," do you mean it has some sort of command-line
interface? I'm not too fond of having to type out several commands and
paths every time I need to do something, unless I can save the text as a
batch file command sequence. Or is it as difficult as Blender? If so,
that will be no problem.
I'll look up both of these apps. Thanks!
Sam
Date: 21 May 2008 20:39:19
Message: <4834c0b7@news.povray.org>
You might want to try Windows Media Encoder,
it's a bit clunky but it makes compresed WMV files.
http://www.microsoft.com/windows/windowsmedia/forpros/encoder/default.mspx
Date: 22 May 2008 16:24:47
Message: <4835d68e@news.povray.org>
Of course, mencoder has no GUI :)
I personally use ffmpeg (which is command-line as well).
