POV-Ray : Newsgroups : povray.off-topic : A small puzzle Server Time
13 Jun 2026 08:40:04 EDT (-0400)
  A small puzzle (Message 129 to 138 of 198)
Subject: Re: A small puzzle
Date: 24 May 2008 10:35:23
Message: <483827D7.80904@hotmail.com>
Stephen wrote:
> On Fri, 23 May 2008 23:45:29 +0200, andrel <a_l### [at] hotmailcom>
> wrote:
>> We don't have that distinction. That is one of the reasons that I try to
>> convince people that the scales they use to measure their weight should
>> be called kilometers. Up till now with very minor success.
> I'm not surprised using length to measure mass, or am I missing
> something?
You might. Probably my mistake, I should also have mentioned that we
almost always abbreviate kilogram to kilo.
Date: 24 May 2008 11:15:43
Message: <97cg34hoa4p7edbei18cijm7gmf22ungej@4ax.com>
On Sat, 24 May 2008 16:36:07 +0200, andrel <a_l### [at] hotmailcom>
As do we in the UK
Regards
Date: 24 May 2008 11:25:06
Message: <hpcg34l2mqet7uqugv2ik4feu3apop54n5@4ax.com>
On 24 May 2008 05:09:04 -0400, Warp <war### [at] tagpovrayorg> wrote:
>  However, what are inches divided into? How would you express 7mm in
>inches?
Inches are divided into halves, quarters, eights, sixteenths and
thirtyseconds (1/32). We use thous (1/1000) in engineering. OK the
metric system is more logical but the imperial system is more
intuitive if you have taken the trouble to learn it so that you can
work in it without thinking. I use both. It is similar to using
fractions and decimals. You can also have fun with vulgar fractions
such as: the length is one and nine eights. ;)
Regards
Date: 24 May 2008 11:25:51
Message: <483833AC.4020501@hotmail.com>
> As do we in the UK
So, how would you call a device to measure kilos?
Date: 24 May 2008 11:43:09
Message: <483837B9.1060109@hotmail.com>
>> inches?
I think the point is that warp and me and everybody else raised in
metric disagrees. The metric system is just as intuitive and more logical.
a tiny bit more than 1/3 meter?
Date: 24 May 2008 12:03:06
Message: <48383c3a@news.povray.org>
> >inches?
  So how exactly do you express 7/10 inches? (Compare to 7mm being 7/10 cm.)
How do you measure that with a ruler?
Date: 24 May 2008 12:33:01
Message: <4838433d@news.povray.org>
Warp wrote:
>   Resistance to change, that's what it is. ;)
Could be that too, of course. Why learn something new when the old is
just as good (or at least good enough).
Another more-convenient: acres.  About 200 feet on a side, a small house
will have one-eighth acre of land.  A nice 3 bedroom job in an old
spacious neighborhood will have half an acre.  A big mansion will be on
  2 to 5 acres. A family farm would cover 100 to 200 acres, and a family
ranch like 600 to 800 acres.  Just right for a nice range of measurements.
We still do floorplan sizes for houses in square feet, tho, so you wind
up with 900 sq ft being a tiny house, 2000 being a
comfortable-for-Americans size, 8000 being a big mansionish house. I
think square meters would do better there, taking out one of the
"useless" zeros in there.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 24 May 2008 12:35:28
Message: <483843d0@news.povray.org>
Eero Ahonen wrote:
> I think this is an opinion-question,
Agreed. I'm not trying to get you to agree with my opinion. :-) I'm just
expressing it.
> but IMO cm/m is pretty easy and
> logical measurement for people. 197cm tells you that he's 3cm shorter
> than a normal door, so he won't hit his head.
Doors here are, I think, seven feet, so that's even easier. :-)
And we say "He's five nine", and everyone knows that means "five feet
nine inches tall".
> In below zero (C) temperatures air is dry and most of the normally-wet
> places are freaking slippery. Practically I find it very useful
> information in everyday life (the most important thing about outside
> temparature is that is it + or - in certain times of year).
I think you, like Warp, are used to much colder weather. I want to know
whether it's t-shirt, long sleeve, or sweater weather. :-)
Date: 24 May 2008 12:57:56
Message: <48384914$1@news.povray.org>
scott wrote:
> But as soon as you need to do anything with those numbers (eg adding,
> dividing etc) it's much easier to use 197 cm than 6 foot 5 (or whatever).
Certainly if you're doing math, you convert everything to one unit of
measurement.
>> Having numbers that go below zero for everyday temperatures seems less
>> convenient.
> No, it's obvious that 0 is "freezing",
Ehn. I think zero being "way colder than you want to be outside in" and
100 being "somewhat hotter than you want to be outside in" is more
convenient. Having to wear different clothes based on it being 32 vs 35
degrees doesn't seem right on this side of the pond. YMMV, of course.
>> Not if you're constructing something. Then you want to be able to take
>> a third of it, for example.
> And what if you need more accuracy than 1 inch (which is required in
> most household items), do you say 5 foot 10 point 7 or what?
Nah. You say "a hundred ninety seven point three inches".  Or, more
likely, "a hundred ninety seven and a quarter". If you need even better
than that, you're probably doing science and should be using metric
anyway. ;-)
Screws here go down to 1/32nd or 1/64th of an inch, rather than a
milimeter. It is kind of annoying that they reduce the fractions, tho.
Going "3 32nds is too small, 5 32nds is too big..." and having to do the
mental math to figure out what 4 32nds is does make me pause sometimes.
I suppose if I did it more than a few times a year, I'd internalize it
just like I know 4 feet is 48 inches without thinking.
> What if
> you need 5 foot 3 point 85 divided into 2?  Dividing 158.3 cm into 2 is
> much easier.
You'd cast everything to inches. That's how construction work is done.
Studs are 16 inches apart, for example. I went to the store and bought
20-inch hoses to connect wall to sink.
Date: 24 May 2008 13:03:15
Message: <48384a53$1@news.povray.org>
You don't do it that way. You measure in quarters and eighths.
You don't measure 7/10ths of an inch here any more than you measure a
sixteenth of a meter where you are.
All the rulers are marked in half-inch, quarter-inch, eight-inch, etc.
http://thumbs.dreamstime.com/thumb_65/11497665910bMuRS.jpg
Now, sure, if you're doing science or engineering or something where you
need to express 7/10th of an inch for some reason, then you express it
as 7/10th of an inch. But at that point you're not likely using a ruler
to measure it.
(Weren't the original DIP IC packages using 1/10th inch spacing between
pins? Was that the same in Europe?)
