POV-Ray : Newsgroups : povray.off-topic : Backup Server Time
9 Jun 2026 10:11:26 EDT (-0400)
  Backup (Message 19 to 28 of 58)
Subject: Re: Backup
Date: 19 Mar 2008 11:13:05
Message: <47e13b91$1@news.povray.org>
Invisible wrote:
> I guess we *could* back up to a hard drive. But I'm not really that keen
> on the idea. We would have to shut the server down to connect the drive,
USB.  Or, apparently, something called "eSata" now?
Oh, is your machine back in the prehistoric pre-USB era still? So buy a
$200 desktop machine that *does* have USB, put XP on it or something,
and back it up over the network.
> start it back up again, format the drive,
Format it once, yes.
> copy all the data, somehow verify the data,
They call that "the backup program".
> I don't have any hard evidence to back this up, but isn't power-on the
> most common time for a HD to fail? (Rather like lightbulbs.) Wouldn't
> the constant cycling tend to wear them down?
Once a day is "constant"?  Besides, it's your backup drive. Buy two.
Switch back and forth between them. When one fails, buy another.
> The other small problem is that 30 harddrives presumably take up
> slightly more space than 30 DDS tapes. ;-)
Well, yeah, but they also last a lot longer, I expect.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Subject: Re: Backup
Date: 19 Mar 2008 11:33:11
Message: <47e14047$1@news.povray.org>
>> That depends on your backup strategy.  If it requires 30 separate
>> media, then yes, storage space can be a premium.  Just tuck one or two
>> near QA girls desk and say 'hi' each time you get one ;-)
> Right. I'm sold!
you can also do this with the tapes - your shelf just can't hold them all.
Subject: Re: Backup
Date: 19 Mar 2008 11:35:37
Message: <47e140d9$1@news.povray.org>
I've been using HD backups for about 5 years now - never had a failure.
That is not to say it can happen tomorrow - they are more *fragile*.
We do keep them in a padded case for off-site storage - never leave them
in a hot or cold car, etc....
Tom
Subject: Re: Backup
Date: 19 Mar 2008 13:14:36
Message: <47e1580c$1@news.povray.org>
Darren New wrote:
>> keen on the idea. We would have to shut the server down to connect the
>> drive,
I'm just not keen on attaching and removing bits of hardware on a
server. Our QA guys probably wouldn't like it either.
I would anticipate that formatting the drive is quite a lot faster than
trying to actually delete the existing files on it.
Really? What on earth makes you think that a highly complex and fragile
device like a HD will last longer than a simple lump of tape?
http://blog.orphi.me.uk/
Subject: Re: Backup
Date: 19 Mar 2008 17:39:24
Message: <47e1961c$1@news.povray.org>
> I guess I should go look up prices for LTO tapes...
$20-$40 each in varying lengths
$40 x 8 = $320 ~ 800 GB
@ 15 MBS (LTO-1)
~ 15 hours to fill
LaCie D2 Quadra HD = $560 ~ 1 TB
@ 3 GBS (eSATA)
~ 6 minutes to fill
LaCie Mobile HD = $139 ~ 250 GB
@ 20-25 MBS (USB 2) (driver free, USB powered)
~ 3 hours 30 minutes to fill
Subject: Re: Backup
Date: 19 Mar 2008 18:45:45
Message: <op.t8aeyjto7bxctx@e6600>
On Wed, 19 Mar 2008 23:39:22 +0100, Tim Attwood <tim### [at] comcastnet>
> @ 3 GBS (eSATA)
> ~ 6 minutes to fill
SATA/300 is 3 Gb/s, not 3 GB/s. There is also a 8/10 encoding to take in
to
account, which puts the actual maximum transfer speed to 300 MB/s. No
actual drive can deliver a sustained write speed that high though; a
really fast drive might approach 100 MB/s. At that speed it would take
roughly three hours to fill the disk, assuming that the source disks can
deliver data at the same speed and the CPU can keep up.
FE
Subject: Re: Backup
Date: 19 Mar 2008 22:13:46
Message: <47e1d66a$1@news.povray.org>
That's what USB is *for*. But as I say, plug the backup machine into the
net next to the server, and back up over the network. Works fine. It's
how I do it.
Oh, if you want to delete everything, I suppose. If you're only putting
one backup file on there, it's probably equally fast.
Experience.  Do you really think you can rewrite a tape 10,000 times?
Subject: Re: Backup
Date: 20 Mar 2008 05:19:56
Message: <47e23a4c@news.povray.org>
Maybe I'm just twitchy because of that scanner I just installed. Some
guy bought a cheap-looking business card scanner. It comes with a
hackish-looking program that lets you press a button and scan a business
card and insert it into your Outlook contacts list. (Huh? I don't get
how that's physically possible...)
On one PC, it puts the PC into an infinite loop where the "Found New
Hardware" wizard keeps popping up and won't **** off. The hardware also
won't work. On other PC, every time you plug it in it *demands* the
product installation CD. Won't do anything without it. And often doesn't
work the first time. You gotta go through several iterations of
uninstalling and reinstalling the driver, rebooting the PC, and
performing voodoo chants over a burning candle. And then, eventually, it
works. And it keeps working - until the next time you unplug it.
I have no idea WTF all that is about! But doing that kind of crap with a
server just makes me damn nervous...
> how I do it.
It has a flavour...
>> than trying to actually delete the existing files on it.
Our backup software has a "backup to folder" option, but it works like a
file copy. IME, deleting millions of files isn't "fast"...
>> fragile device like a HD will last longer than a simple lump of tape?
Well, most of the tapes we own were put into service long before I
joined the company, and they're still going strong. (Now and then we
have a tape go dud and I replace it.) That's plenty long enough for me...
Subject: Re: Backup
Date: 20 Mar 2008 05:38:24
Message: <47e23ea0$1@news.povray.org>
>SATA/300 is 3 Gb/s, not 3 GB/s. There is also a 8/10 encoding to take into
Ah, I misread something, still that's at least 150 MB/s, faster
than the HD will go.
They do make faster tape drives with more storage, but it
sounds like Andy's company might as well re-use the old
hardware. I bet it's one of those machines you could dig
out of a building collapse and still recover the data. And
if they compress the data they probably can fit a 160 GB
backup onto a single tape.
Subject: Re: Backup
Date: 21 Mar 2008 12:06:56
Message: <47e3eb30$1@news.povray.org>
I don't know. Let me suggest that a hard drive isn't going to be as
problematic. :-)
>> But as I say, plug the backup machine into the net next to the server,
>> and back up over the network. Works fine. It's how I do it.
> It has a flavour...
That must be some British expression I'm not familiar with...
Odd. No, deleting millions of files isn't fast. What's wrong with the
backup software that comes with Windows?
But as you say, partition the disk so you can use one partition per
backup, and format over the drive each time.
You're much luckier than I was with tapes. Probably because your company
is buying high-quality tapes.
