POV-Ray : Newsgroups : povray.off-topic : Suggestions on motherboard Server Time
17 May 2026 01:56:31 EDT (-0400)
  Suggestions on motherboard (Message 21 to 30 of 40)
Subject: Re: Suggestions on motherboard
Date: 17 Mar 2008 09:32:55
Message: <47de8117@news.povray.org>
>> Isn't that wildly insecure
> Not when Mac address filtered and with a network key. Besides, it's a home
> network, not a corporate.
Well, OK, fair enough.
Personally, whenever I get anything that has a wireless capability, the
very first thing I do is try to find a way to permanently disable that
functionallity.
(On the other hand, I don't know how to work it properly, so...)
>> / unreliable?
> Never noticed so. Much better than cables running all over the place. It's
> for a flat of 3 rooms, so I don't need excessive range
My dad used to use wireless networking. But he found that he had to
constantly plug and unplug the wireless adaptor until it found a
network. Sometimes the wireless adaptor itself was reported as "not
plugged in" when in fact it was.
[The amusing thing is he bought a Belkin base station and wireless
adaptor bundle, which was quite pricey, and it really didn't work
reliably. Then he bought some cheap no-name wireless adaptor for one of
the other PCs, and that worked flawlessly. I wonder if it's because it
was in the same room?]
Well anyway, long story short: Eventually he went back to wired
networking just so it would ****ing work properly.
http://blog.orphi.me.uk/
Date: 17 Mar 2008 09:36:45
Message: <47de81fd$1@news.povray.org>
"Gail Shaw" <initialsurname@sentech sa dot com> wrote in message
news:47de7e96@news.povray.org...
> "Fredrik Eriksson" <fe79}--at--{yahoo}--dot--{com> wrote in message
> news:op.t75ireku7bxctx@e6600...
>> Personally though, I would recommend one of these:
>> http://www.pclabs.co.za/ProductDetail.aspx?prodId=312&catId=20
>> http://www.pclabs.co.za/ProductDetail.aspx?prodId=317&catId=22
>> Less bling and more function.
> But I like the bling. *g*
    Heh... Nothing wrong with a bit of *Bling* Gail!  :)
> Seriously, the second one looks nice. Very nice.
    Oooh, that is nice actually. I like the idea of the double hinge door.
With mine, you have to slide either of the sides backwards to get inside -
that's ok doing that, but trying to put them back the same way is SO
awkward! Yes, I have to use my chin to hold one spot in place and then my
hands to slide the sides back in place. Horrible design.
   ~Steve~
Date: 17 Mar 2008 09:46:42
Message: <47de8452@news.povray.org>
"Phil Cook" <phi### [at] nospamrocainfreeservecouk> wrote in message
news:op.t75uzsqac3xi7v@news.povray.org...
>> Got a wireless network card I'll be using.
> I know Asus does motherboards with built in WiFi tum-ti-tum ah here we go
> http://www.neoseeker.com/Articles/Hardware/Reviews/asus_p5b/
Ooh. I'll check that one out. Depends on the price, as I already have the
wifi card.
Date: 17 Mar 2008 09:48:03
Message: <47de84a3@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:47de8117@news.povray.org...
> functionallity.
Only time my laptop's wifi is on is when I'm at home.
Date: 17 Mar 2008 13:01:35
Message: <op.t759ouvd7bxctx@e6600>
On Mon, 17 Mar 2008 15:22:45 +0100, Gail Shaw sa dot com>
Then perhaps this one:
http://www.pclabs.co.za/ProductDetail.aspx?prodId=314&catId=20
More expensive, but you can see your own reflection in it.
There is also a gun metal black version:
http://www.pclabs.co.za/ProductDetail.aspx?prodId=313&catId=20
Keep in mind that transparent windows are a bad thing if you want a quie
t
computer.
It is also considerably smaller (though still fairly roomy on the inside
Check that the PSU is powerful enough for your needs first though.
FE
Date: 17 Mar 2008 13:09:38
Message: <op.t75917sh7bxctx@e6600>
> - that's ok doing that, but trying to put them back the same way is SO
The double hinge is on the door that covers the top half of the front. The
side plate is still very easy to handle though.
FE
Date: 17 Mar 2008 13:22:24
Message: <op.t76angvr7bxctx@e6600>
On Mon, 17 Mar 2008 15:47:11 +0100, Gail Shaw sa dot com>
e
>> go
the
> wifi card.
The P5B line of cards is getting a bit long in the tooth. Better to pick
one of these:
http://za.asus.com/products.aspx?l1=3&l2=11&l3=534&l4=0&model=
1749&modelmenu=2
1646&modelmenu=2
http://za.asus.com/products.aspx?l1=3&l2=11&l3=572&l4=0&model=
1872&modelmenu=2
If you already have a WiFi-card though, you might be better off with a
(cheaper) non-WiFi motherboard.
This is a good choice if you intend to use several PCI cards:
http://www.gigabyte.co.za/Products/Motherboard/Products_Spec.aspx?Produc
tID=2748
FE
Date: 17 Mar 2008 13:28:42
Message: <47deb85a$1@news.povray.org>
news:op.t75917sh7bxctx@e6600...
>> nside  - that's ok doing that, but trying to put them back the same way
>> is SO
  Ah, I see, thank you. It was a little misleading, but if the side plate is
better than mine, I'll look out for something like that for the next one I
get.
    ~Steve~
> FE
Date: 18 Mar 2008 04:08:55
Message: <op.t77fpiluc3xi7v@news.povray.org>
And lo on Mon, 17 Mar 2008 14:22:45 -0000, Gail Shaw sa dot com>
<"<initialsurname"@sentech> did spake, saying:
I thought you were after a case not a fridgefreezer ;-)
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 18 Mar 2008 10:09:10
Message: <47dfdb16@news.povray.org>
news:op.t77fpiluc3xi7v@news.povray.org...
*g* My fridge looks positivly dingy compared to that case.
