POV-Ray : Newsgroups : povray.off-topic : Ray tracers and transformations Server Time
4 Jul 2026 09:01:28 EDT (-0400)
  Ray tracers and transformations (Message 12 to 21 of 21)
Subject: Re: Ray tracers
Date: 14 Mar 2008 04:57:00
Message: <47da4bec@news.povray.org>
Severi Salminen wrote:
> Yeah, Pov uses the exact same method. It is very simple and fast method.
> Pov also has one additional check, which I'm not sure is worth it. POV
> also returns both hits always. I only return the hit in front of the
> ray. I have no use for the other.
It's used for CSG. (E.g., if you "difference" the sphere against
something else, the "back" intersection might actually be where the
solid surface begins.)
[Mutters something about Haskell and lazy evaluation...]
http://blog.orphi.me.uk/
Subject: Re: Ray tracers and transformations
Date: 14 Mar 2008 07:30:49
Message: <47da6ff9@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> Warp wrote:
> >   That's the reason why you can't, for example, scale something by 0.
> > Inverting that matrix would result in a division by 0.
> Presumably it would also result in an invisible object too though. ;-)
  Not if you scale by 0 on only one axis.
> Does POV-Ray actually apply all the matricies and invert only the final
> one? Or does it construct them in inverted form in the first place?
  IIRC it calculates the inverted matrices when parsing and uses them
when rendering.
Date: 14 Mar 2008 07:52:16
Message: <47da7500$1@news.povray.org>
Ah, good point...
> when rendering.
I thought that would be the case.
Date: 14 Mar 2008 08:15:20
Message: <slrnftkuj8.k3r.bisqwit@bisqwit.iki.fi>
On Fri, 14 Mar 2008 11:41:35 +0200, Severi Salminen wrote:
> 2. What does "ucomisd %xmm0, %xmm0" effectively do? It compares the same
> register.
Checks whether the low double precision floating point value
in the register is (non-)zero.
In the SSE architecture, an instruction such as "por" does not affect
the flags, so the familiar x86 way of "or eax, eax" to set flags would
not work on SSE.
Joel Yliluoma - http://iki.fi/bisqwit/
Date: 15 Mar 2008 07:14:29
Message: <47dbbda5$1@news.povray.org>
Hmm. I still don't get it. Why should I ever need to trace the ray in
the "wrong direction"?
The ray starts at camera and goes forward. If anything interesting is
found, it is in front of the ray, right? And the only exception is if
the camera is inside an object. But even then: shouldn't it be enough to
trace forward. Please enlighten me :)
Date: 15 Mar 2008 07:19:45
Message: <47dbbee1$1@news.povray.org>
You will never need an intersection from *behind* the camera.
However, a ray typically intersects a sphere in two places. POV-Ray
generates both points of intersection because you might need them both.
(E.g., if the object is transparent, you'll want to trace a ray out of
it. If the object is involved in CSG with other objects, the "back"
surface might actually be the first visible surface. etc.)
Date: 15 Mar 2008 08:58:33
Message: <47dbd609@news.povray.org>
Ok, but I guess that you can still handle all cases with an intersection
routine that only returns the point in front of the ray?
1. If the object is transparent, you first enter the object and then exit.
2. In CSG the same applies: you still have to first enter all the
participating objects to calculate the outcome.
So this is not something that is mandatory but a convenience?
Date: 15 Mar 2008 09:35:46
Message: <47dbdec2$1@news.povray.org>
Pretty much, yes.
(Although if you're bothering to compute the coefficients of a quadratic
equation, it seems a shame to compute them all over again to find the
second point of intersection...)
Date: 15 Mar 2008 11:47:14
Message: <47dbfd92$1@news.povray.org>
Well, I use the simplified form I posted to this thread. It is
computationally quite simple. So it all boils down to how often you
actually need the "unneeded" intersection and what is the net effect. I
haven't measured it.
Date: 20 Mar 2008 08:57:59
Message: <47e26d67$1@news.povray.org>
Nicolas Alvarez wrote:
>> Any clearer? ;-)
> Thanks; shows I'm still too noob for this kind of things.
> (that's a no)
OK, well because I'm feeling bored, let me try again...
Light travels in essentially straight lines. If we assume a ray starts
at position S and travels parallel to the vector D, we can write
   R(t) = Dt + S
That is, the vector D scaled by the scalar t, plus the vector S.
A sphere is the set of all points within a specific distance of a
certain point. So if C is the center of our sphere, and r is the radius
of the sphere, then the sphere consists of all points less than r units
from the point C. We're interested in the *surface* of the sphere, which
is the set of all points *exactly* r units away from C. We can write that as
   |P - C| = r
Solving this equation for any vector P gives us the surface coordinates.
But that's not what we're trying to do. We want to know whether any
point in space lines on the surface of the sphere *and* on a given ray.
In other words, solve simultaneous equations. Non-linear ones!
But we'll get to that in a second. First, notice that the dot product of
a vector with itself is equal to the length of that vector squared. In
oter words,
   vlength(V) = sqrt(V # V)
That means we can write
   sqrt((P - C) # (P - C)) = r
Alternatively, we can avoid the expensive square root operation by
   (P - C) # (P - C) = r^2
Finally, with a tiny bit of rearranging, we have
   ((P - C) # (P - C)) - r^2 = 0
(If the thing on the left *equals* the thing on the right, then
subtracting one from the other must logically result in zero.)
I'm going to be fanciful and write the above in shorthand:
   (P - C)^2 - r^2 = 0
It's a slight abuse of notation, but it's less typing.
Now if we replace our unknown point P with our ray equation R(t) we get
   (Dt + S - C)^2 - r^2 = 0
If I put X = S - C, we get
   (Dt + X)^2 - r^2 = 0
Opening the brackets as per the standard binomial theorum, we have
   D^2 t^2 + 2 D X t + X^2 - r^2 = 0
By which of course I actually mean
   (D # D) t^2 + 2 (D # X) t + (X # X) - r^2 = 0
This matches the form of the standard quadratic
   a t^2 + b t + c = 0
if we set
   a = D # D
   b = 2 (D # X)
   c = (X # X) - r^2
We can now apply the usual formula
   t = (-b +/- sqrt(b^2 + 4ac)) / 2a
Assuming that the square root part (the "determinant") is strictly
positive, we obtain two purely-real solutions. These are the values for
t where the ray "enters" and "leaves" the sphere. If the determinant is
negative, that basically means the ray doesn't touch the sphere at all.
Assuming we *do* have an intersection, just calculate
   Dt + S
for the two values of t to obtain the actual points of intersection.
Is *that* any clearer? ;-)
