POV-Ray : Newsgroups : povray.off-topic : Using Excel as a 3D engine Server Time
17 May 2026 01:56:39 EDT (-0400)
  Using Excel as a 3D engine (Message 26 to 35 of 45)
Subject: Re: Using Excel as a 3D engine
Date: 12 Mar 2008 08:50:44
Message: <47d7dfb4$1@news.povray.org>
scott wrote:
>> Not because the algorithm is hard, but because I'd have to figure out
>> how to access the cells of the spreadsheet...)
> Oh my God.
I know...
What can I say? VB isn't exactly the easiest programming language ever.
And this stuff isn't really documented anywhere. (Sure, there's an
online help system that will tell you what function X does. But if you
don't know the name of the function you need... that's not much help.)
Now you see why it took me several hours to write a VB macro that puts
today's date into a particular cell?
http://blog.orphi.me.uk/
Date: 12 Mar 2008 08:52:09
Message: <47d7e009$1@news.povray.org>
>> I tend to use Excel as a function plotter - and it's annoying that things
>> like an FFT are so hard to do.
> The built-in FFT in Excel doesn't work?
Excell has an FFT? Since when? (Or is it in one of the non-default add-ins?)
> In any case, accessing cells with VBA is basic. Just start recording a macro
> and put something in a cell to see how it's done.
I didn't realise that uses VB. Oh, wait, I'm thinking about Access...
Date: 12 Mar 2008 09:09:16
Message: <47d7e40c$1@news.povray.org>
Rubbish!
Try looking up "range" or "cells" or "worksheet" in the object browser and
reading the help.  It even gives examples, like (these are from the help on
the "range" keyword, the others are similar):
Worksheets("Sheet1").Range("A5").Value =
Worksheets("Sheet1").Range("A1").Value
Worksheets("Sheet1").Activate
Range("A1:H8").Formula = "=Rand()"    'Range is on the active sheet
Worksheets(1).Cells(1, 1).Value = 24
ActiveSheet.Cells(2, 1).Formula = "=Sum(B1:B5)"
How could it be any more clear what to do?  Or, as Gilles said, record a
macro and then look at the code (and the help related to the code
generated) - a nice trick for learning how to do lots of things in Excel
(like creating charts, changing borders, sorting etc).
Date: 12 Mar 2008 09:31:03
Message: <47d7e927$1@news.povray.org>
47d7e009$1@news.povray.org...
>>> things like an FFT are so hard to do.
> add-ins?)
It's in the Analysis Toolpak which is not turned on by default (but just a
checkbox away).
http://www.maxim-ic.com/appnotes.cfm/an_pk/3292
It's been there for years I believe (the Analysis Toolpak has been there
since Excel 95 at least, I'm not sure about FFT itself).
I don't understand what you're saying... The entire Office suite uses VBA.
Actually that's one big selling point of Office (for businesses): one can
automate all the Office applications using the same language and have them
interact with each other.
G.
http://www.oyonale.com
- Graphic experiments
- POV-Ray, Cinema 4D and Poser computer images
- Posters
Date: 12 Mar 2008 09:38:34
Message: <47d7eaea$1@news.povray.org>
>> add-ins?)
> checkbox away).
Ah, right. I don't think I have that installed... (But as you say,
that's not hard to fix.)
I hope it's less clunky than that hacked-in complex number "support"
Excell has though.
Yes. But Access has an additional "macro language" that only Access
uses. By default it seems to record macros with that.
Heh. I'm *so* not trying that... ;-)
Date: 12 Mar 2008 09:41:20
Message: <47d7eb90$1@news.povray.org>
> Rubbish!
> and reading the help.
What is the "object browser"?
That seems reasonably clear.
Now, if you call a macro with a cell range as its argument, how does
that work?
I'm still at the level of not really knowing how to work the VB editor,
and not understanding basic VB syntax constructs...
Date: 12 Mar 2008 09:49:59
Message: <47d7ed97@news.povray.org>
47d7eaea$1@news.povray.org...
> Yes. But Access has an additional "macro language" that only Access uses.
No, you can't record a macro in Access. Recording macros is an
Excel/Word/Powerpoint thing and it  (now) produces VBA code. I agree that
"macro" as a term is inconsistently used in MS Office (a legacy issue I
guess).
G.
- Posters
Date: 12 Mar 2008 10:27:29
Message: <47d7f661$1@news.povray.org>
RTFM? It is all explained...
Date: 12 Mar 2008 10:48:52
Message: <47d7fb64$1@news.povray.org>
Manual? Chance would be a fine thing!
Date: 12 Mar 2008 12:33:24
Message: <47d813e4@news.povray.org>
Right click in the code view and choose "Object Browser".  It basically
shows every "object" available, and what its members are.  Help is available
for every item.
> Now, if you call a macro with a cell range as its argument, how does that
> work?
I don't have any experience with that, but I assume that the range would
just be placed into a variable, just like if you passed a number or
individual cell etc.  Look up "range" in the object browser and you'll see
its member functions to work with it.
Get a book?  Read a tutorial online?  Trial and error?
