POV-Ray : Newsgroups : povray.off-topic : Adventures with digital painting Server Time
31 May 2026 22:16:14 EDT (-0400)
  Adventures with digital painting (Message 91 to 100 of 197)
Subject: Re: Adventures with digital painting
Date: 10 Mar 2008 08:06:54
Message: <47d5326e$1@news.povray.org>
> In what universe is this a "simple tool" with "well defined inputs and
> outputs"?
ls is a good example of a program that *doesn't* have well-defined
outputs, in the sense that scripts should never rely on parsing ls
output. ls is supposed to have *human-readable* output.
Date: 10 Mar 2008 08:13:11
Message: <47d533e7$1@news.povray.org>
Warp wrote:
> Invisible <voi### [at] devnull> wrote:
>> Ah yes, but in Unix land, a device driver is counted as part of the
>> kernel. ;-)
>   There are many pros in monolithic kernels. Of course there are cons,
> but many people believe that the pros outweight the cons in this case.
I just prefer being able to add new drivers without having to recompile
the kernel and reboot the machine - but that's just me...
OOC, what are the benefits?
http://blog.orphi.me.uk/
Date: 10 Mar 2008 08:18:24
Message: <47d53520$1@news.povray.org>
Warp wrote:
>   Autoconf exists because not all systems have the same tools or libraries
> installed, nor all systems have the same versions of those tools/libraries.
As far as I can tell, autoconf exists because some systems use BSD awk
and others use GNU awk, and the two aren't precisely compatible.
Multiply this by the 50,000 other tiny utilities you may or may not need
to set up this program and you have a configuration nightmare so bad it
requires an automated tool to make things remotely tractable.
And it seems to me that most of this has happened because the entire
system has been poked and prodded by so many different people over time
that you now have a huge tangled mass of different implementations all
of which are only semi-compatible.
>   Autoconf also exists because computer architectures are different.
> For instance, some architectures may be little-endian while others are
> big-endian. Some architectures may be 32-bit while others are 64-bit.
Shouldn't the compiler be dealing with those issues?
>   Portability is a key feature of unix-like systems.
That I don't have a problem with... ;-)
Date: 10 Mar 2008 08:40:35
Message: <47d53a53$1@news.povray.org>
No. If the compiler "dealt" with little endian and big endian, by making
the C code always see one or the other, it would make the other
architecture much slower.
Also, the C standard only mentions minimum sizes for data types. A
compliant C implementation may have 64-bit bytes if it wants to.
Date: 10 Mar 2008 08:47:37
Message: <47d53bf9$1@news.povray.org>
What I meant was, shouldn't the programmer be able to just write their
program, and let the compiler generate the correct code depending on the
actual processor architecture?
But then, since C is little more than semi-portable machine code, I
guess that would be quite hard to do.
IOW, the C standard is insane. ;-)
Date: 10 Mar 2008 08:53:13
Message: <47d53d49$1@news.povray.org>
>> making the C code always see one or the other, it would make the other
Of course there is a lot of code that can be written without caring
about endianness. In which case you wouldn't tell autoconf to do that check.
Date: 10 Mar 2008 08:54:23
Message: <47d53d8f@news.povray.org>
  I have never had to recompile the kernel or reboot the machine because
of requiring a new driver.
  man modprobe
  For example, the interfaces and protocols between the kernel and the
drivers can be modified easily without having to worry about backwards
compatibility. If an existing interface or protocol results to be a bad
design choice, or it results to have some inefficiencies in a newer
architecture, they can all be changed without problems. Basically, the
kernel is not burdened with backwards compatibility issues with regard
to drivers.
Date: 10 Mar 2008 09:00:40
Message: <47d53f07@news.povray.org>
  In other words, autoconf exists to increase portability. My point exactly.
  You seem to have quite many nightmares others don't.
  There are some cases were endianess matters, especially if you are trying
to write low-level efficient code.
  A concrete example which I remember where the program has to behave
differently depending on endianess is mplayer. The source code has to
know the endianess of the target system in order to be able to write
bytes in the proper order.
  (Sure, the code could have been written so that endianess doesn't matter,
but then it wouldn't have been so efficient.)
Date: 10 Mar 2008 09:06:46
Message: <47d54076@news.povray.org>
>   man modprobe
No - but it *is* fun if you try to install some device driver that needs
to be compiled from source and you don't have the kernel headers
installed. (Whereas on Windoze you just install the driver - and hope to
God that PnP actually does what it's meant to...)
I had great fun trying to get the nVidia graphics drivers to actually
blinking work...
> compatibility.
Mmm, OK. I can see how that would be useful...
Date: 10 Mar 2008 11:38:23
Message: <47d563ff$1@news.povray.org>
On Mon, 10 Mar 2008 10:07:04 +0000, Invisible wrote:
> The trouble with Linux is that everything is 50,000 utterly *tiny*
> pieces, each of which does almost nothing useful by itself, and you have
> to put thousands of these tiny pieces together to do anything useful.
Well, that's a fallacy right there.  I'm running a monolithic application
at the moment called "pan", which is a newsreader.
I've got another fairly monolithic application called "firefox" running
in the background, and another called "OpenOffice" that's at the
standby.  Also one called "Pidgin" which is an IM client.
None of these apps particularly *requires* any of the standard command-
line utilities on my OS for anything short of building it (if I should
desire to do so).
Jim
