POV-Ray : Newsgroups : povray.off-topic : Adventures with digital painting Server Time
4 Jul 2026 02:40:10 EDT (-0400)
  Adventures with digital painting (Message 188 to 197 of 197)
Subject: Re: Adventures with digital painting
Date: 16 Mar 2008 21:24:44
Message: <47ddd66c@news.povray.org>
nemesis wrote:
> No, I'd say it's because C# the language is about as useful as Java the
> language:  not at all!  Both don't work outside their humongous associated
> libraries/frameworks.
Personally, I'm looking into Erlang right now, thinking about how it
might work for the code I have at work. Looks pretty cool, but it's one
of those things that it seems most of the stuff makes sense at the
fundamental assignment/arithmetic/functioncall level, and then there are
libraries for things like "Build a release of several applications that
let you upgrade a running system along with the distributed database
schema without shutting it down." So like the "kernel" and "stdlib"
documents are together 800 pages (something like 60 pages of one-line
descriptions for routines in Kernel), and all the stuff in between is
just huge.
Contrast with C#, where each library is pretty well distinct, for the
most part. You can read about the regexp library without even knowing
about the existence of the dynamic-code-loading library.
I think for anything particularly useful, you're going to have big
libraries anyway. It's hard to build an "enterprise" class application
without a whole bunch of stuff, so why not design a library for
enterprise-class applications and actually use it in your system? C#, I
think, started out with the idea, rather than building it up without
extensive language support like Java did.
Got the book on order, tho, so that should help.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 16 Mar 2008 23:10:00
Message: <web.47ddee812f6d31e07a680aea0@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Personally, I'm looking into Erlang right now... the "kernel" and "stdlib"
> just huge.
Why is it any different with the Erlang library?  I've just taken a look at
stdlib in http://erlang.org/doc/pdf/ and, though a big document, the various
modules it describes as part of the "standard library" are clearly all distinct
and separate from each other, with an occasional reference to related
functionality in other modules.
Perhaps what bothered you is that the unmaintained docs are kept in PDF files
without links rather than a cross-referenced tree-based Windows Help file?
> libraries anyway.
I didn't say otherwise.  I said .NET is closed and non-standardized and C#
without it is like bread and no butter -- well, much worse actually...
Actually, the thing that p*** me off about Java libs or .NET or even Python etc
is that they're all just a bunch of redundant -- but perhaps a bit more
convenient -- wrappers to existing OS functionality.  In the case of Java or
Python at least, this leads to cross-platform ease.  In the case of .NET, it's
just Windows2 on top of Windows1, really, for no reason other than captivating
an evergoing mass of programming enterprise drones that prefer to type
FileAccess.ChangeDirectory(dir) rather than cd(dir) or something...
Date: 16 Mar 2008 23:38:01
Message: <47ddf5a9$1@news.povray.org>
>> just huge.
Look at anything other than the stdlib module.  I'm still wading thru
kernel, but stuff like understanding the supervisor model, or the
release application, or the mnesia stuff, requires a whole bunch of
background.  (Not that it's hard to find the background. It's just
there's a whole lot of it.)
C# probably has a lot of similar stuff, like when you're doing code
generation and such. Understanding "assemblies" for example takes a lot
of background, but doing something with assemblies that needs that
understanding that stuff is unusual rather than step one.
In other words, I can't imagine why you'd want to use Erlang for a
system other than a system that takes advantage of all the difficult
stuff, while I can easily imagine using C# to do nothing more than a bit
of simple XML parsing or some file management sort of thing.
It's entirely possible I'm reading Erlang docs in the wrong order. :-)
I'm still trying to figure out where the parser is described. Various
routines seem to imply you can add your own parsing to the language
("behaviors" and "records" come to mind), as well as manipulating
parse-trees, and I'm curious to see what that's all about.
No, they have fine cross-references. It's just hard to know where to
start. In retrospect, starting with kernel and stdlib is probably best,
but I figured that out by reading the part in the release management app
that said you had to include those in every release. :-)
>> libraries anyway.
Yeah. And Erlang without the standard libraries (including gen_server,
sasl, etc) isn't especially useful either.
I would disagree. Certainly a large part of what you might use in some
types of programs is like that. But if you're writing an ASP.NET
program, most of the stuff you're doing has zero to do with the OS.
Indeed, for that stuff, I understand that the executables are directly
portable between MS's .NET and Mono.
> In the case of Java or Python at least, this leads to cross-platform ease.
Yeah, right. Let me know when you have cross-JVM ease, let alone
cross-platform ease, with Java.
Date: 17 Mar 2008 13:23:36
Message: <47deb728$1@news.povray.org>
>>> libraries anyway.
>> and C#
Yes, except Erlang's libraries aren't closed technologies dictated by a
single monopolistic company trying to pass it as free and open by
standardizing just the language and very basic library.  Anyone can
benefit, anyone can contribute and anyone can use without fear of
dependencies of closed technologies that change depending on
market/financial mood.
>> ease.
I run most Java or Python programs unmodified both at the WinBox at work
and at my Linux home box.  The guy coding them doesn't have to worry
about hairy ifdefs or memory management to get it working on different
platforms.  The only requirement is that he uses the standard
cross-platform API and doesn't rely on specific platform services.
Date: 17 Mar 2008 13:34:20
Message: <47deb9ac$1@news.povray.org>
I saw a post in worsethanfailure of a Java method to copy files. It
created a .bat file with a 'copy' command, then ran it, and finally
deleted the .bat.
Date: 17 Mar 2008 15:10:59
Message: <47ded053$1@news.povray.org>
You're probably not doing too much hairy. I have to have three different
JVMs installed at work to use three different libraries from three
different partners.
I was always amused by the taglines that said things like
    100% Java! (Requires Java 1.5.2)
Date: 17 Mar 2008 16:39:06
Message: <47dee4fa@news.povray.org>
>> work and at my Linux home box.  The guy coding them doesn't have to
>> worry about hairy ifdefs or memory management to get it working on
>> different platforms.  The only requirement is that he uses the
>> standard cross-platform API and doesn't rely on specific platform
>> services.
> deleted the .bat.
yes, even Java with all its stupid "enterprise" limitations is
completely fool-proof!
Date: 25 Mar 2008 17:59:55
Message: <47e983eb$1@news.povray.org>
On Fri, 14 Mar 2008 18:38:46 +0000, Orchid XP v7 wrote:
>>> Now you know why I dislike scripting languages in general. ;-)
>> They work for what they're designed for - I use awk quite a bit, perl
>> occasionally, and shell scripts on rare occasions.
>> But if I wanted to write something that was usuable by a general
>> computer user, I'd look to develop in a compiled language, as a general
>> rule.
> The kind of tasks I typically want to do involve heavy number crunching.
> Scripting languages aren't terribly suitable to this...
Scripting languages aren't designed for performance, as a general rule,
so yes, that wouldn't be appropriate for a scripting language if you have
complex calculations or lots of data to process.
Jim
Date: 26 Mar 2008 06:11:49
Message: <47ea2f75@news.povray.org>
This is the problem with POV-Ray's SDL. People *have* built physics
engines with it, but it's really not fantastically suitable for that task...
http://blog.orphi.me.uk/
Date: 26 Mar 2008 09:03:56
Message: <47ea57cc@news.povray.org>
>>> crunching. Scripting languages aren't terribly suitable to this...
>> have complex calculations or lots of data to process.
> task...
Well, I don't know that I'd call it a problem per se, more of a
limitation to be aware of.
Jim
