POV-Ray : Newsgroups : povray.off-topic : My Experience with Visual C++ 2008 Express Edition Server Time
17 May 2026 01:37:29 EDT (-0400)
  My Experience with Visual C++ 2008 Express Edition (Message 126 to 135 of 135)
Subject: Re: My Experience with Visual C++ 2008 Express Edition
Date: 21 Feb 2008 11:28:49
Message: <47bda6c1$1@news.povray.org>
Darren New wrote:
> Invisible wrote:
>> Well, perhaps you're right. All I know is that we started ending up
>> with lots of "Java" programs which only actually work with the M$ JVM.
> I've seen very few Java programs that work correctly on multiple Java
> interpreters, myself. I think I have 3 JVMs installed at work (under
> Linux) to support the three different java-based libraries I'm using
> from different parts of my program.
> If you want your Java portable, don't use proprietary libraries. It's
> pretty easy.
In fairness, it would probably help if the AWT hadn't been designed by
an escaped monkey...
http://blog.orphi.me.uk/
Date: 21 Feb 2008 14:13:52
Message: <47bdcd70$1@news.povray.org>
Heck - in early versions of Java (i.e., Netscape 4 timeframe), they
didn't even have Hashtable working right.
     On what day did God create the body thetans?
Date: 21 Feb 2008 14:25:24
Message: <47bdd024@news.povray.org>
That's an implementation bug. Invisible is talking about AWT *design*,
which can't be just "fixed on the next release".
Date: 21 Feb 2008 20:33:20
Message: <47be2660@news.povray.org>
Yes. He was changing the topic, and I was still on the original topic.
:-) Just saying, AWT wasn't the worst of it. Java had all kinds of evil
brokenness, and still does.
Date: 22 Feb 2008 04:32:01
Message: <47be9691@news.povray.org>
So does .Net have a less horribly broken library design then?
Date: 22 Feb 2008 09:00:02
Message: <web.47bed54d3fe42908bf7e3e540@news.povray.org>
probably and sadly yes.  Because it was made to run on a single OS from a single
company.  Many choices and tradeoffs are easier to make as is making it work
nice with the underlying architecture.  of course, it's less broken but much
more evil than Java. ;)
Date: 22 Feb 2008 09:08:30
Message: <47bed75e$1@news.povray.org>
>>> *design*, which can't be just "fixed on the next release".
>> evil brokenness, and still does.
AFAIK, The library for making windows and stuff is less broken than Java
AWT, *because* it's too Windows-oriented. Since they didn't bother with
any crossplatformness, the API is simpler...
Date: 22 Feb 2008 11:11:31
Message: <47bef433$1@news.povray.org>
Other than some of the low-level windowing stuff, what do you see in the
.NET libraries that would be difficult to implement on (say) Linux?
The only bits I've seen that are actually Windows-specific were the bits
that were either accessing directly the win32 stuff (like turning off
particular windows message pump messages), which you don't need to do.
Or stuff that Linux doesn't support anyway, like distributed
transactions. (E.g., AFAIK, you can't write code in Linux to rename
three files from A,B,C to D,E,F in such a way that nobody ever sees D
without seeing F, and a powerfailure after you rename A and before you
rename C undoes the renames you've done so far.)
The stuff you'd expect to be portable (web stuff, file stuff, threads,
data structures, code generation, library management, temp files, etc)
are all quite portable.  Just off the top of my head, I'd say maybe 10%
of the library routines, tops, have an API or functionality that makes
them hard to port, and maybe 1% have an API or functionality that makes
them hard to port to an OS that actually supports that kind of
functionality.
Of course, it's *difficult* to port the windowing stuff, but that
doesn't mean it's inherently non-portable. Only that it's complex. It's
difficult to make X programs run under Windows, too, without writing an
X server.
What classes do you think are unportable?
Date: 22 Feb 2008 11:11:44
Message: <47bef440$1@news.povray.org>
I would say it does, actually, yes.
Now, granted, it's very *complex*, because it has a lot in it. And some
of the design decisions aren't obvious unless you actually read the 20
or 30 pages of "this is why we did it this way" documentation.
For example, most of the classes say "static class methods are not
thread-safe, but instance methods are."  Huh?  Why would you do such a
thing?  But the rationale is actually quite reasonable, and it's obvious
the designers had spent some time thinking it through.
The same with the organization of complex callbacks/events, where you
have a pre-change callback, a post-change callback, and throwing errors
results in different behaviors at different points in the process.
Complex, but when you go looking for "how do I do this..." you go "Oh,
they already made that work right."
The regexp matcher, for example, is also way complex compared to what
I'm normally used to. But it lets you match on one call multiple
subexpressions, find out where they matched, and so on. In that case,
there's really no "simpler" version, and the documentation is mildly
obtuse, but playing around with it a little and looking at the result
set in the debugger made it clear.
It also helps that there are things like events (linked lists of
callback pointers) and properties (automatically-named getter/setter pairs).
There are, of course, still warts, many caused by the static typing. For
example, the return type from the regular expression matcher is several
inter-related classes all referencing each other. Confusing, until you
actually read all the docs. Not more confusing than, say, trying to
understand C socket programming based on the man pages, tho.
There are also warts caused by interfacing to systems (like SQL) with
different data models (like, there's an "int?" type, which allows for
integers or NULL, but the IDE doesn't generate code to use that, instead
requiring things like resultset.column[2].isnull()).
The encryption stuff is kind of funky, as half of it is still using the
Windows library things, so like the encryption stuff only works if
you're running web pages under IIS, because it's using IIS's encryption
library.
I haven't had to deal with reflection, introspection, or code
generation, nor with all sorts of dynamic loading/programming/etc.
But overall, it's surprisingly clean.
Date: 22 Feb 2008 11:30:17
Message: <47bef899$1@news.povray.org>
Java has a long list of brokeness. The language itself is horridly
broken, but the standard libraries are insane...
It's been a while since I actually used Java. But IIRC, the Object class
has a surprisingly vast collection of methods. The base class for AWT
widgets is *huge*. And there are multiple methods which apparently do
the same thing... except... they don't... but it's not documented... Hmm.
Other fun things include the frequency with which they deprecate massive
sections of the API and provide new ones. (IIRC, originally we did
stream-type stuff with stream wrappers. And then they added "readers"
and "writers" and deprecated all the old interfaces.)
Basically, if you run the same program on several different JVMs, you
get wildly different behaviour, because nobody is sure exactly what all
the GUI-related method calls are actually *meant* to do...
I really hope .Net has managed to avoid all that...
