POV-Ray : Newsgroups : povray.off-topic : new news client Server Time
9 Jun 2026 09:36:14 EDT (-0400)
  new news client (Message 51 to 60 of 60)
Subject: Re: new news client
Date: 29 Jan 2008 00:35:30
Message: <479ebb22@news.povray.org>
Sabrina Kilian wrote:
> Darren New wrote:
>> Alain wrote:
>>> Have you tryed "cheating"?
>> I saw a great tool for tunneling IP over DNS.
> What next, IP via Morse Code timed SNMP pings? The check sums would need
> work, one faulty router in the middle and S turns into O.
I saw an RFC for IP carried by Carrier Pigeons, once :)
...Ben Chambers
www.pacificwebguy.com
Date: 30 Jan 2008 12:59:38
Message: <47a0bb0a@news.povray.org>
Darren New wrote:
> Fredrik Eriksson wrote:
>> At what point was that? Even MS-DOS let you have extensionless files.
> Heck, CP/M let you have extensionless files. :-)
yes, for old systems like Unix and all, extensions are just part of the
name, nothing special.  I was under the impression that on Windows it
was just another artificial limitation imposed on users, like GUIs and
dialog boxes...
Date: 30 Jan 2008 13:23:48
Message: <47a0c0b4$1@news.povray.org>
nemesis nous apporta ses lumieres en ce 2008/01/30 12:59:
> dialog boxes...
Old name storage limitation when the names where in the 8.3 format. 8 characters
for the name, of whitch you must use from 1 to 8, and an extention for an extra
3 characters for the extention, hence the term "extention". Those could cary 0
to 3 characters. The content of the extention is purely arbitrary, with some
having specific, reserved, signification.
Sometimes my love of the arcane combines with my askew humor to make me
unintelligible!!
Date: 31 Jan 2008 00:27:05
Message: <47a15c29$1@news.povray.org>
That's the same on Windows, Unix, and CP/M.  The only difference is how
the command line and/or libraries parse the names.
CP/M had 11-digit names. Most command-line utilities interpreted a dot
as "fill with spaces to the 8th character", and a "*" as "fill with
question marks to either the 8th or 11th character, whichever comes
first."  Basically.  There certainly wasn't any "." or 8.3 on the disk.
Windows just stores the dot, at least on NTFS volumes. FAT volumes still
have the 11-character limitation (which is where you get 11-character
volume names) until you get the "extended names" (which are encoded
names stored in directory entries marked as "deleted").
UNIX original (as in v7) had 14-character names, because they had
16-character slots in directories with 2-byte inode numbers.
Nowadays, it's all pretty opened up. But there's nothing that enforces
anything in Windows to use particular extensions for particular types of
files, except maybe executable EXE and DLL files. (Not even sure about
that.)
     On what day did God create the body thetans?
Date: 31 Jan 2008 01:27:48
Message: <47a16a64@news.povray.org>
> that.)
ISTR that it used to be (at least) with DOS that the interpreter/shell
(ie, command.com) had special handlers for .com and .exe and that you
couldn't execute a program with.  That said, I do know that the exec...
and spawn... C functions could launch any file as an executable (used to
do this myself, actually - replacing a login.exe file with a custom-
written wrapper that exec'ed a login.nov executable).
Jim
Date: 1 Feb 2008 00:14:54
Message: <47a2aace@news.povray.org>
I'm not sure what that means. But yeah, I don't necessarily count
Explorer (for example) as "part of the OS". It's just a shell.
But that's what I meant by "except maybe EXE and DLL files". I'm not
sure if the extension is required to be there for some of the exec/spawn
type calls to work.
Date: 1 Feb 2008 12:48:36
Message: <47a35b74$1@news.povray.org>
Whoops, I meant "without those extensions", and then my brain kicked in
and reminded me that it was command.com that did that, not the DOS kernel.
Yep.
> type calls to work.
At least in DOS, it's not.
Jim
Date: 1 Feb 2008 14:04:33
Message: <47a36d41@news.povray.org>
> Yep.
so what?  Unless you go calling kernel subroutines by hand just to
overcome the limitations the shell imposes, the shell and its
idiosyncrasies is what you, as an user, is limited to.
Date: 1 Feb 2008 14:25:45
Message: <47a37239$1@news.povray.org>
>> Yep.
> so what?
As a DOS programmer, that's a very significant difference.
I don't believe I ever said I was just a user.  In fact, I used to write
DOS-based programs quite regularly to accomplish specific tasks,
including using undocumented DOS calls to make it do things outside of
what the "normal" DOS BIOS functions would allow.
Hands up, all those here who know what INT21 is without looking it up.
Bonus points for those who can describe INT2F and how it relates to INT21
functions.
Jim
Date: 1 Feb 2008 21:10:05
Message: <47a3d0fd@news.povray.org>
>> Yep.
Uh, yeah, most programmers call kernel subroutines by hand.
My point being that all the stuff about file extensions meaning certain
things, and ".gif" files being images etc, is all handled by explorer.
If you want to have ".c" files be images and compile C source code
stored in ".jpg" files, nothing prevents you.
