POV-Ray : Newsgroups : povray.off-topic : new news client Server Time
9 Jun 2026 13:00:20 EDT (-0400)
  new news client (Message 31 to 40 of 60)
Subject: Re: new news client
Date: 26 Jan 2008 11:15:00
Message: <web.479b5c27ade97551743af2f90@news.povray.org>
Nicolas Alvarez <nic### [at] gmailisthebestcom> wrote:
> FYI, GMail doesn't let you send exes, and checks the *contents* of zip
> files for exes.
yeah, that's right.  Learned it the bad way, when I tried to send the file to
some friends so that they sent it back renamed... :/
Date: 26 Jan 2008 11:34:16
Message: <479b6108$1@news.povray.org>
nemesis nous apporta ses lumieres en ce 2008/01/26 10:31:
> Alain <ele### [at] netscapenet> wrote:
>> Have you tried some other, less known, compression formats: BH, SIT, RAR, 7Z, A,
>> ACE, ARC, TZ, GZ, GZA, LHA, TAR,...
> You know, the sad part is that I'm on a Linux box.  Could've just typed tar czf
> foo.tgz and be done with it.  But I wanted to do it the dumb graphical way.  So
> I just relied on the defaults.  That means "File-Roller" took the executable
> name and just added zip.  The exe continued.
> Another option would be to rename the file to be uploaded, eliminating the exe
> sufix.  Not possible on Windows, but I've done it several times in the past on
> Linux.  Like when sending tgzed mp3 to gmail. :)
Very easy to change or remove the extention on windows. You just neet to set
explorer to not hide known extentions. Always the first thing I do on a new install.
   I was making love to this girl and she started crying. I said,  "Are you
going to hate yourself in the morning?" She said, "No, I hate Myself now."
	Rodney Dangerfield
Date: 26 Jan 2008 11:40:00
Message: <web.479b6229ade97551743af2f90@news.povray.org>
really?!  It's possible to have a Windows file with actually no extension?  I
don't mean hiding the extension from view, but actually having none...
Date: 26 Jan 2008 11:57:51
Message: <op.t5jqqop3cs6ysw@e6600>
> extension?  I don't mean hiding the extension from view, but
Of course it is. What made you think otherwise?
FE
Date: 26 Jan 2008 12:10:00
Message: <web.479b68c1ade97551743af2f90@news.povray.org>
old times?  I remember at some point Windows didn't let it be done.
Date: 26 Jan 2008 12:37:15
Message: <op.t5jskdzhcs6ysw@e6600>
At what point was that? Even MS-DOS let you have extensionless files.
FE
Date: 26 Jan 2008 13:25:01
Message: <web.479b7a2dade97551743af2f90@news.povray.org>
perhaps it did, but not obviously.  Alain said he had to set up some
configuration in order to do it.
Date: 26 Jan 2008 13:31:23
Message: <op.t5ju2ktucs6ysw@e6600>
That is a problem caused by the default options in Explorer. It was not an
issue back in the days of MS-DOS and Windows 3.x, nor is it an issue if
you use the command console in Windows XP/Vista.
FE
Date: 26 Jan 2008 14:17:30
Message: <479b874a$1@news.povray.org>
nemesis nous apporta ses lumieres en ce 2008/01/26 13:21:
Explorer's default to always hiding the extentions that are registered.
To change:
Open an explorer window.
In the menu, chose "Tools"
Chose "Folders options"
Select the "Display" tab
Scroll down to "Hide extentions of known files types"
Uncheck the associated box.
Click "OK"
A few lines lower, you can supress the anoying "shortcut to..." from been added
to the name of new shortcuts.
You know you've been raytracing too long when you resign the fact that printing
uses CMYK instead of RGB to one of those tests God gave to Job; otherwise life
would be too painful to go on.
     -- Taps a.k.a. Tapio Vocadlo
Date: 26 Jan 2008 16:07:02
Message: <479ba0f6$1@news.povray.org>
Jim Henderson wrote:
> http://www.nocrew.org/software/httptunnel.html
> I've used this myself when I absolutely needed the ability to use NNTP
> and the port was blocked.
Umm... no thanks.  I'd rather not lose my job if they find out I've
installed custom software to bypass their security :)
...Ben Chambers
www.pacificwebguy.com
