POV-Ray : Newsgroups : povray.off-topic : Web design IE mysterium Server Time
5 Jul 2026 04:44:45 EDT (-0400)
  Web design IE mysterium (Message 21 to 30 of 52)
Subject: Re: Web design IE mysterium
Date: 21 Jan 2008 05:02:08
Message: <op.t49x6mrqc3xi7v@news.povray.org>
And lo on Sun, 20 Jan 2008 05:49:18 -0000, Rune <aut### [at] runevisioncom>
did spake, saying:
> I'm working on implementing a new design on my website (based on the
> mock-up I posted about earlier) and I've come quite far. Web design
> seems to have
> become much easier since six years ago, where browsers had far more
> peculiar
> behaviours than now.
Looks okay with both Firefox 2.0.0.11 and Opera 9.22.8801 although on an
underpowered machine I've noted it scrolls quite slowly. In the past this
is due to fixed background images, but I didn't spot any in your source;
Not a concern, just a remark.
In the IE front the first thing you might consider is switching to a
strict type. MS fixed some div/floating/other bugs in IE6 to match the
standard model, but only if you use a strict type.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 21 Jan 2008 05:11:41
Message: <op.t49ymibwc3xi7v@news.povray.org>
And lo on Mon, 21 Jan 2008 10:02:36 -0000, Phil Cook
<phi### [at] nospamrocainfreeservecouk> did spake, saying:
> <aut### [at] runevisioncom> did spake, saying:
> In the past this is due to fixed background images, but I didn't spot
> any in your source; Not a concern, just a remark.
Scratch that it's your fixed body background image. I overrode it with a
"scroll" and can't see any difference visually it just removes the
slowdown.
Phil Cook
Date: 21 Jan 2008 09:37:30
Message: <4794ae2a@news.povray.org>
> slowdown.
The fixed background is a subtle gradient (greener towards the bottom of the
screen) but if it causes a slowdown, I won't use it. Thanks for letting me
know.
Rune
http://runevision.com
Date: 21 Jan 2008 09:38:53
Message: <4794ae7d$1@news.povray.org>
"scott" wrote:
> I don't get that at all in IE7, it looks perfect and identical to FF.  I
> thought maybe you have fixed it since you made the first post?
Yes, I did. :) Thanks for testing it!
Rune
Date: 22 Jan 2008 04:40:40
Message: <4795ba18$1@news.povray.org>
Tim Cook wrote:
> It shouldn't; I'm just saying that there's nothing *requiring* you to
> use CSS to design a webpage, or that you can't use the parts of CSS that
> *do* work with IE and make a working layout.  I use some CSS on my
> webpage and it renders fine in IE.
Of course there's nothing *requiring* me to use CSS to design a web
page.  On that note, there's nothing that says I have to use standard
compliant HTML or, for that matter, HTML at all (viva la Flash...ugh).
I do not care to do a whole lot of web design work.  I generally just
want my layout and style to work without a whole lot of hassle (or ugly
hacks) because I'd rather focus on the content.  The last thing I want
to do is fiddle endlessly with my markup and stylesheet because a
browser fails to render it properly.
Again, I fail to see why you chose to make a sarcastic post when I
brought up something that is a very clear and obvious problem with the
way that IE is designed.  I shouldn't have to dodge features of a
language, or use lame quirks, just because IE is too inept to deal with
it.  Every browser but IE handles it without question.
-Ian
Date: 22 Jan 2008 06:06:49
Message: <op.t5bvtcowc3xi7v@news.povray.org>
And lo on Tue, 22 Jan 2008 09:40:39 -0000, Ian Burgmyer
<spe### [at] gmailcom> did spake, saying:
>> that *do* work with IE and make a working layout.  I use some CSS on my
To give it a physical viewpoint if you're moving small bags around it's
easy to do it by hand; if you're moving pallets then you want to use the
forklift. Then you discover the forklift's too tall to fit through the
door of one of the warehouses. So either you stop ordering things by
pallets because of one awkward door, or you may be able to use a pallet
truck for this one warehouse. Either way it's a hassle and you don't get
things quite the way you'd want them.
Phil Cook
Date: 22 Jan 2008 06:16:00
Message: <4795d070$1@news.povray.org>
Physical viewpoints require thinking in terms of physical labor.  Screw
that. ;)
Think about it from my perspective, though.  If I were an experienced
web designer that knew of most of the quirks that IE had and how to
easily write around them, I probably wouldn't have complained about it
in the first place.
However, as someone who isn't a big fan of doing web design (mostly
because of such quirks, really), I would much prefer it if it just
worked so I could get the stinking page online without having to deal
with any workarounds or hacks.
And yes, the fact that I dislike crude hacks in web pages but use them
occasionally when I program (like that one time I hacked unsafe
multithreading into a .NET app I was developing and it somehow managed
to run quite stably without too much extra work) is kind of ironic, but
that's a story for another bedtime. :P
-Ian
Date: 22 Jan 2008 12:02:58
Message: <op.t5cb7mh0c3xi7v@news.povray.org>
And lo on Tue, 22 Jan 2008 11:15:59 -0000, Ian Burgmyer
>> the forklift. Then you discover the forklift's too tall to fit through
>> the door of one of the warehouses. So either you stop ordering things
>> by pallets because of one awkward door, or you may be able to use a
>> pallet truck for this one warehouse. Either way it's a hassle and you
>> don't get things quite the way you'd want them.
> that. ;)
Heh, but it helps some people.
> in the first place.
Yeah if you're experienced in using the pallet truck it's annoying, but
you can do it. You don't like having to use it, but it's not a major
hardship; then...
...on the other hand you get those who've only used the truck being shown
how to use the forklift and then moaning that it doesn't fit under the
doors they've taken for granted as being the right height, there's too
many controls, etc.
Phil Cook
Date: 22 Jan 2008 13:10:56
Message: <479631b0$1@news.povray.org>
> hardship; then...
> ....on the other hand you get those who've only used the truck being
> shown how to use the forklift and then moaning that it doesn't fit under
> the doors they've taken for granted as being the right height, there's
> too many controls, etc.
Indeed.
When I do web design I just want to get it done so I could focus on
other things.  I recall times where I spent upwards of 45 minutes trying
to figure out how to get similar results on IE, Firefox, and Opera, then
moving on and quickly running into a roadblock.  That's usually the
point where I just move to a prefabbed system out of sheer frustration.
-Ian
Date: 22 Jan 2008 13:43:39
Message: <4796395b$1@news.povray.org>
Rune wrote:
I though you once made an image of a cracking egg with an eye peering
through, but can't find it on the groups or on your website. If this was
indeed your image, you should consider reworking it and submitting it to
the RTChallenge topic 'Into the Wilderness.'
www.tc-rtc.co.uk
  -Shay
