POV-Ray : Newsgroups : povray.off-topic : Suggestions: Text editors Server Time
17 May 2026 08:03:07 EDT (-0400)
  Suggestions: Text editors (Message 31 to 40 of 58)
Subject: Re: Suggestions: Text editors
Date: 3 Jan 2008 05:06:08
Message: <477cb390$1@news.povray.org>
>> Oh, Vim is an OK text editor. It's just not that fantastic...
> Well yes, it's not an operating system ;-)
> I don't know, what feature(s) do you miss?
> I'm fairly certain I'm using Vim at a fraction of its capacity, so I
> don't feel any incentive to move, personally...
Well, you know, it's a text-mode editor. I guess by definition that
places rather strong limits on what useful things it can do. For example,
- You can't click on where you want the cursor to move to. You must
manually move the cursor around using several million arrow key presses.
- You can't cut and paste blocks of text.
- You can't change the display to fit more than 80 characters on the screen.
- You can't have multiple files open at once. (Well, unless you count
using virtual terminals.)
- You can't realistically do syntax hilighting. (Well, again, I suppose
theoretically you could - but with only 8 colours available, how good is
that going to look?)
It's not that Vim is a bad product - I'm not sure how any possible
text-mode program could possibly overcome these limitations. They seem
to be inherant in the description "text-mode program" rather than
specific to Vim itself...
http://blog.orphi.me.uk/
Date: 3 Jan 2008 05:25:57
Message: <477cb835$1@news.povray.org>
But all of these flaws are fixed in GUI versions of Vim, including Cream
and probably WinVi.
As for syntax highlighting, maybe try to type :syntax on in a text-mode
Vim and see for yourself if it works... Though I still prefer it in the
GUIs.
Vincent
Date: 3 Jan 2008 09:12:55
Message: <477ced67@news.povray.org>
I can use the mouse even on the text-mode vim over a remote ssh connection.
Of course you can. It's just called 'yank' and doesn't use the system
clipboard by default. You can also use the mouse to select the block
before copying. On Windows you can use Ctrl-C and Ctrl-V for consistency.
> screen.
Yes you can. On the GUI, you resize the window. On text-mode on an
decent console, you resize the window (that includes a putty window
connected to a remote copmuter). On text-mode on Windows command prompt,
you can't resize it (that's a Windows flaw), but you can change the
column count manually with :set columns=100; I just tried it and it
works on Windoze too. Who would use text-mode on Windows anyway?
Vim can split the window, and show different files on each. It also has
tabs on the GUI version; but I never tried that on text-mode. Split
windows definitely works (and if your console supports mouse, you can
resize the split by dragging too).
Consoles have 16 colors usually, not 8. Some Unix consoles support 4096.
Vim can use all 16 million colors on the GUI, but do you *really* need
them? Probably not. The default color schemes would be happy on 8-bit color.
Date: 3 Jan 2008 11:00:01
Message: <web.477d0636af0f26ec773c9a3e0@news.povray.org>
yes, I guess working on streams of bytes also "places rather strong limits on
what useful things" a computer it can do...
really?  This is not true as of this age and even if it was true, believe me:
arrow keys are evil.  Use "{" or "}" to jump between paragraphs and other
blocks of text, "50G" to go to line 50, "(" or ")" to jump between sentences
and when you want to go back to previous stops, "CTRL+O" goes back through the
location stack...
you're insane:  "3y}" copies the 3 long blocks of text below without even
thinking about it.  "p" places it just before the cursor.  If you want the
notepad graphical way, gVim and others do it just fine and still let you work
the more productive modal way.
gVim lets you even change the font!  I use gVim on Windows or else I'd hang
myself on the office...
Vim has had multiple buffers and even sessions for ages now.  I'm sure you're
using just limited ol' vi in some ancient Unix...
pretty friggin' good.  Try :syntax enable and :colorscheme koehler
I do povray stuff in it and pov SDL syntax highlighting is not usually found or
integrated into most text editors...
Download 'vim_kicks_ass.jpg' (51 KB)
Preview of image 'vim_kicks_ass.jpg'
Date: 3 Jan 2008 11:05:00
Message: <web.477d078aaf0f26ec773c9a3e0@news.povray.org>
modal text-editing using keyboard only is far from being a flaw:  I call it
productive.
> GUIs.
I don't think you understand:  typing :syntax enable or disable also works on
the graphical versions, at least on gVim.
Date: 3 Jan 2008 11:09:56
Message: <477d08d4$1@news.povray.org>
> location stack...
None of these things quite compares to "I want to put the cursor *here*..."
[Although, finding like 138726 quickly might be useful if the compiler
reported an error on line 138726.]
...riiiiight. *I* am insane? ;-)
LOL. I'm loving that filename...
Doesn't much seem to resemble the little program I end up having to use
when I'm trying to fix a broken Linux install where /etc/fstab is messed
up or some such and I need to edit it. You certainly can't get more than
80 characters on screen there - because the terminal window is only 80
characters wide.
For sure you can run a text-mode program inside a terminal window. I
didn't know somebody had actually put buttons on it by now though. Still
doesn't look like much fun to actually use...
Date: 3 Jan 2008 11:12:18
Message: <477d0962$1@news.povray.org>
Nicolas Alvarez wrote:
...in summary, a GUI version exists now.
>> suppose theoretically you could - but with only 8 colours available,
>> how good is that going to look?)
> color.
Really? That's interesting. I know that VGA gives you 16 colours, but I
thought it was hard-wired so that you can only use 8 of those for the
foreground, and the other 8 for the background?
Date: 3 Jan 2008 11:12:35
Message: <477d0973@news.povray.org>
> productive.
I wasn't talking about modal text-editing but of the flaws of Vim *as
perceived by Andrew*. He did not seem aware of GUI versions that solve
most of his gripes by default; I never said there were no way to do that
in text-mode.
>> GUIs.
Have I said somewhere that it doesn't? I think you misunderstood my
post. What I meant to say was that syntax highlighting does work even
with the relatively limited number of colors available in text-mode, but
that I prefer the colors that can be defined in graphical versions.
Vincent
Date: 3 Jan 2008 11:12:45
Message: <477d097d$1@news.povray.org>
> and probably WinVi.
OK. Well if I get time, maybe I'll try it...
Date: 3 Jan 2008 11:25:00
Message: <web.477d0b57af0f26ec773c9a3e0@news.povray.org>
you can just click there.  or type /word or ?word (reverse) and use "n" (next)
until you reach precisely where you want.
Every software has its quirks.  Read that as "Yank 3 blocks", "}" used because
of its widespread use in computer programming as a block terminator.  Now, I
understand "CTRL+C" as copy, because of C, but why Paste uses "v"?!  quirks...
well, that's an unusual situation, don't you agree?  In there, everything is
limited, and it's just you, the kernel, a basic shell and good ol' basic vi...
