POV-Ray : Newsgroups : povray.off-topic : I hate DVD as a physical media Server Time
24 Dec 2025 09:06:08 EST (-0500)
  I hate DVD as a physical media (Message 1 to 10 of 18)
Subject: I hate DVD as a physical media
Date: 15 Dec 2007 08:51:50
Message: <4763dbf5@news.povray.org>
The DVD is a bad physical form of media. It's too fragile.
  I have the 4-disc edition of Titanic, and my computer has now trouble
recognizing the second disc. It's just a tiny scratch on the very outer
edge of the disc, but that's enough to make it difficult for the drive
to recognize the disc.
  There's nothing else wrong with the disc, only the tiny scratch on the
outer edge. If such a small flaw is enough to completely stop the DVD from
being played, that's IMO a clear sign that the DVD as a format is flawed.
One tiny scratch should not disable the entire disc just because it happens
to be physically located at a certain place on the disc. DVDs are supposed
to have lots of redundant information for the exact reason to avoid it being
rendered unplayable by tiny flaws. Why can't it have redundant information
of the most critical sections of the disc, at different parts of the disc,
so that drives can try another copy of the critical section if one is
unreadable?
  This sucks.
Subject: Re: I hate DVD as a physical media
Date: 15 Dec 2007 10:08:12
Message: <4763eddc$1@news.povray.org>
> unreadable?
	Do you know what DVD drive you have? On a number of occasions, I've
seen DVD's not work on generic laptop drives - only to work just fine on
my computer. Better error correction was something my drive was known
for (at the time I bought it).
"Honey, answer the phone."  "Okay.  BaRRING! BRRNG! BaRR"
                   /  \/  \ u e e n     /  \/  a w a z
                       >>>>>>mue### [at] nawazorg<<<<<<
                                   anl
Date: 15 Dec 2007 10:18:33
Message: <4763f049@news.povray.org>
  The computer sees it as "Pioneer DVD-RW DVR-108".
Date: 15 Dec 2007 11:10:05
Message: <4763fc5d$1@news.povray.org>
It's been that way since they chose not to enclose CDs in a protective case.
Date: 15 Dec 2007 18:43:34
Message: <MPG.21ce1494d78a323798a0ca@news.povray.org>
In article <4763f049@news.povray.org>, war### [at] tagpovrayorg says...
You could try resurfacing it, if you can find some place that does that.
Mind you, you don't want to do that a lot, since every time you repolish
the disk you take a bit of the plastic off, but, in principle, it will
fix "most" scratches, as long as the damage is only on the plastic side,
not the data layer.
void main () {
    if version = "Vista" {
      call slow_by_half();
      call DRM_everything();
    call functional_code();
  else
    call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 15 Dec 2007 19:56:19
Message: <476477b3$1@news.povray.org>
> not the data layer.
I have a CD with an MS-DOS game. It's full of scratches. And when I say
"full", I don't mean just "a lot"; I really mean it as in "there isn't
any space left for any more scratches".
Last time I tried, all disc access took several minutes, until a certain
point during installation where the drive decides it's completely
hopeless and gives a read error.
I wonder *where* I can get it "resurfaced"...
Date: 15 Dec 2007 23:00:18
Message: <4764a2d2$1@news.povray.org>
Sounds similar to my car, which would need to get cleaner before it can get
any dirtier.
Date: 15 Dec 2007 23:13:16
Message: <4764a5dc$1@news.povray.org>
Lots of places will sell for 20 bucks or so a little device to do that.
Never had to use one, so I can't comment further.
     It's not feature creep if you put it
     at the end and adjust the release date.
Date: 16 Dec 2007 02:34:30
Message: <4764d506$1@news.povray.org>
clean, buff, and wax.
http://www.wikihow.com/Fix-a-Scratched-CD
Date: 17 Dec 2007 02:41:57
Message: <47662845@news.povray.org>
Did you try it in another drive?  IME it's often the drives that suck, not
the discs.
