POV-Ray : Newsgroups : povray.off-topic : ODBC Server Time
10 Jun 2026 05:23:55 EDT (-0400)
  ODBC (Message 9 to 18 of 98)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: ODBC
Date: 13 Dec 2007 11:09:09
Message: <47615925$1@news.povray.org>
47614210$1@news.povray.org...
> Basically I want to develop a program that talks to a database. I was
> going to use ODBC to do this. But I don't have a database set up right
> now, so I was wondering if I could test it with a simple text file until I
> get round to setting up a real database. [Obviously a CSV file isn't going
> to even approach the speed of a half decent database engine. But I can
> test whether data goes in and data comes out.]
You can do some limited database work with text files (or Excel files etc.),
but that will mostly be limited to actions that can be done without
requiring indexes, i.e. SELECT and INSERT statements rather than UPDATE and
DELETE for instance. For testing a database, you'll need a database. MS
Access will do, and MySQL takes a couple of minutes to install on a PC.
G.
Subject: Re: ODBC
Date: 13 Dec 2007 11:16:49
Message: <47615af1$1@news.povray.org>
PostreSQL also takes a couple of minutes to set up. Unforuntately, I
can't make it do anything once it's installed.
MySQL isn't transactional = I'm not really interested.
Maybe I'll just use M$ Access. [Obviously that means I can only use
computers which have M$ Access.]
http://blog.orphi.me.uk/
Subject: Re: ODBC
Date: 13 Dec 2007 11:30:17
Message: <47615e19$1@news.povray.org>
It is if you use InnoDB engine tables. Note, it's about five times
slower, but it's transactional.
     It's not feature creep if you put it
     at the end and adjust the release date.
Subject: Re: ODBC
Date: 13 Dec 2007 11:31:04
Message: <47615e48@news.povray.org>
Last I heard, it's transactional yet still not 100% ACID-compliant.
Subject: Re: ODBC
Date: 13 Dec 2007 11:38:24
Message: <47616000@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:47615af1$1@news.povray.org...
No, you just need the access ODBC driver (which comes with the standad MDAC
package) You'll need a copy of access to create the database, you don't to
access the file over ODBC (or OleDB).
Not sure about the licencing implications, but I'm guessing you aren't too
concerned about that either.
Other option you can try is to download SQL Server Express. It's limited in
size of DBs it can handle, but is fine for testing.
If you download the management studio pack as well, you get a nice GUI
frontend for it. Otherwise you'll have to access it through command line
Subject: Re: ODBC
Date: 13 Dec 2007 11:42:35
Message: <476160fb@news.povray.org>
Hmm, interesting.
So you're only paying for the GUI frontend, but the database engine? (If
indeed it warrents the term "engine"...)
Or, alternatively, you can apparently download the full version of
Oracle for free - provided you promise to never ever use it "for real",
only "for test purposes". Apparently. And I already know how to work
Oracle...
But yes, Access would probably be much simpler just for test purposes.
Subject: Re: ODBC
Date: 13 Dec 2007 11:50:34
Message: <476162da@news.povray.org>
news:476160fb@news.povray.org...
in
> Oracle...
You can get a full version of SQL server for $50, feature equivalent to
Enterprise edition, just not licenced for production usage. Only really
worthwhile for people who work with SQL a lot.
I know there's a free version of Oracle, wasn't aware it was all the
features of the top version..
SQL Express is a restricted feature set, but it can be used anywhere,
including on production systems, free.
Subject: Re: ODBC
Date: 13 Dec 2007 13:34:52
Message: <47617b4c@news.povray.org>
Yeah. I was surprised too. But, apparently, when you "buy" Oracle they
send you a "media kit" that contains all the products, but only license
you to install the one you paid for. Hmm, I wonder how they can tell?
I plan to use PostgreSQL for the final thing, or maybe Oracle, but right
now I just wanna test. ;-)
Subject: Re: ODBC
Date: 13 Dec 2007 20:21:13
Message: <4761da89$1@news.povray.org>
Well, no, but it's transactional. The A and I and D parts, I think.  I'm
not sure whether it has support for the C part, since it insists on
having defaults for every data type, so things like declaring a column
"not null" and not providing a value isn't an error.
Subject: Re: ODBC
Date: 13 Dec 2007 20:23:53
Message: <4761db29$1@news.povray.org>
I'll note that the features that are restricted are performance
features, not SQL features as such. E.g., it'll only process one request
at a time, only run on one core, won't do hot backups, stuff like that.
But in theory anything you write on "real" SQL Server will run without
change on SQL Express, as long as timing isn't an issue.
I used SQL Express in one project I did where other things (wireless
bandwidth, primarily) kept us down to a couple of transactions a second,
and it worked fine.
