POV-Ray : Newsgroups : povray.off-topic : Why??? Server Time
9 Jun 2026 15:59:39 EDT (-0400)
  Why??? (Message 14 to 23 of 33)
Subject: Re: Why???
Date: 7 Dec 2007 06:47:05
Message: <475932b9$1@news.povray.org>
> Oh, I've seen reports of managers who won't believe that a particular task
> actually takes 20 minutes, and "can't you just change it to only take 3
> seconds?"
An extremely valuable skill of any specialist is the ability to explain
stuff to non-specialists in a way they understand.  Telling your manager
that it's compute bound on 4 threads and is proven to not run any faster
than the O(n^3) algorithm you are using is not going to work too well...
(unless your manager is also a "specialist").
> After the consultants laughed and told them it was impossible, they made a
> stroppy retort
> I guess the root of all this is people who have no concept of what is or
> isn't possible with a computer. But it's more than that - people who have
> no clue but *think* they do.
And it's people like that on both sides that cause the problem, which just
leads to the problem getting worse.  On the one hand you have stroppy
companies who have no clue about computers, but refuse to believe what they
are told.  On the other hand you have supposed "specialists" who actually
don't know what they are talking about.  Who's going to believe who anymore?
> I mean, if a bridge was being designed, you wouldn't presume to know
> enough about structural engineering to make decisions about how long it
> should take or what the best way to do it is.
Hahahahahha.  I take it you've never worked as an Engineer on a project
then?  Almost every problem is due to the customer saying "I want X" and the
Engineers saying "ermm we can't really do that".  Of course the customer
usually forces the way they want, but then other things need changing or go
wrong later.
A recent example is the LCD that goes in the instrument cluster of some car
to be launched soon.  It goes behind a dark glass cover so that the driver
cannot see anything behind, the display just kind of "glows" through it
(like some Sony MP3 player i saw the other day).  Anyway, near the end of
the design phase of the project, they told us they wanted it about twice as
bright because they had made their dark glass darker than before.  We told
them this was a bad idea as there might be problems with overheating etc.
Of course they forced their way and told us they'd done tests etc and it was
ok.  So guess what, we made it brighter, and now it shuts off during the
high-temperature test because of overheating...  And as usual this is a
"problem" with our design and we have to fix it at our expense asap....
Subject: Re: Why???
Date: 7 Dec 2007 07:00:32
Message: <475935e0$1@news.povray.org>
>> task actually takes 20 minutes, and "can't you just change it to only
>> take 3 seconds?"
I like to think I'm fairly good at this. I'm probably just deluding
myself though...
>> or isn't possible with a computer. But it's more than that - people
>> who have no clue but *think* they do.
> just leads to the problem getting worse.  On the one hand you have
> stroppy companies who have no clue about computers, but refuse to
> believe what they are told.  On the other hand you have supposed
> "specialists" who actually don't know what they are talking about.
True...
I think if we could sort out who the *real* experts are from the liers
and fakers, we'd probably be in better shape though.
>> it should take or what the best way to do it is.
> the Engineers saying "ermm we can't really do that".  Of course the
> customer usually forces the way they want, but then other things need
> changing or go wrong later.
OK, I rephrase: *I* wouldn't presume to know about structural
engineering. ;-)
Subject: Re: Why???
Date: 7 Dec 2007 07:41:55
Message: <47593f93@news.povray.org>
> OK, I rephrase: *I* wouldn't presume to know about structural engineering.
But, like with a lot of subjects, most people think they know the basics.
Like if I told you that your new server room could only take 3 servers
otherwise the floor would break, you would probably suggest that I made the
floor stronger... If I then said this was not possible due to X, you (ok,
not you personally) would either let it go or get angry and tell me to make
the floor stronger as it *must* be possible.  You might then start to look
at the details yourself and see if some beam could be made larger, you might
even demand that I put in this bigger beam instead.
Then when the walls below collapse due to increased weight of the servers
and the bigger beams you'll blame me :-)
Subject: Re: Why???
Date: 7 Dec 2007 07:50:29
Message: <47594195$1@news.povray.org>
>> engineering. ;-)
> basics. Like if I told you that your new server room could only take 3
> servers otherwise the floor would break, you would probably suggest that
> I made the floor stronger... If I then said this was not possible due to
> X, you (ok, not you personally) would either let it go or get angry and
> tell me to make the floor stronger as it *must* be possible.  You might
> then start to look at the details yourself and see if some beam could be
> made larger, you might even demand that I put in this bigger beam instead.
> servers and the bigger beams you'll blame me :-)
Mmm... clearly I'm not as much of a butthole as the people you get to
work with. :-}
Subject: Re: Why???
Date: 7 Dec 2007 08:06:55
Message: <4759456f$1@news.povray.org>
> Mmm... clearly I'm not as much of a butthole as the people you get to work
> with. :-}
Maybe you would be if you'd already ordered 10 new servers and announced to
the entire company that the new system will be up and working by date X, and
everyone is planning their own work based on your date, and if you don't get
those servers running you will be responsible for your company losing a lot
of money... And if you have no other options on where to put the servers,
you're going to be on my back to make them go in that room whatever it
takes...
And here's what happens when you mess with stuff:
http://en.wikipedia.org/wiki/Hyatt_Regency_walkway_collapse
Subject: Re: Why???
Date: 7 Dec 2007 08:42:54
Message: <47594dde$1@news.povray.org>
Gail Shaw wrote:
> Warning, rant follows. If you're not interested, don't read further.
> So, yesterday my boss asked that I take a quick look at a couple of the
> scripts for a rather major change to our one system that's going live
> tomorrow evening. I wasn't overly concerned, because the code had already
> been checked over.
> *sigh*
> I feel a bit better now.
WOW - I feel for you.
Since you've been dragged in to 'check' it, are you now responsible to
'care' for it.  Then I REALLY feel for you.
All I have to say is - "Good Luck!"
Tom
Subject: Re: Why???
Date: 7 Dec 2007 10:16:25
Message: <475963c9@news.povray.org>
"Tom Austin" <taustin> wrote in message news:47594dde$1@news.povray.org...
I'd be responsible to care for it even if I hadn't seen it.
I'm the person the users call when the database apps are slow, so slow code
in production is automatically my responsibility.
Persionally I'm glad I found it this week and not next week.
Subject: Re: Why???
Date: 7 Dec 2007 10:20:21
Message: <475964b5@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:47591445@news.povray.org...
> Of course, The Real WTF is that they're asking you to check stuff over a
> few days before it goes live. ;-)
Actually I prefer that to the alternative: finding the mess in production
next week when someone complains.
My boss had no reason to suspect that anything was wrong. He asked me to
check a couple scripts just to make him happy. He's now very unhappy. *g*
> Me: "Every determinent is a candidate key."
My colleagues think it's strange that I can list, from memory, the
requirements for each normal form, some 10 years after university. They
think its even stranger that I can look at a table and tell in a couple
seconds what normal form its in.
Subject: Re: Why???
Date: 7 Dec 2007 10:44:31
Message: <47596a5f$1@news.povray.org>
True. But finding out 2 weeks ago would have been even better, no?
Ah, but can your boss actually do anything about this mess? That's the
crucial question... ;-)
Yeah, cos after all, it's not like normal form is *important* or
anything, is it?
*weeps softly in the corner*
By the way... what *is* 4th normal form?
(I was one of the few people in the class who could understand the
normal forms - and why they matter - but we never looked at anything
above BCNF.)
Subject: Re: Why???
Date: 7 Dec 2007 11:00:10
Message: <47596e0a@news.povray.org>
The I hope that you have an understanding boss who is willing to work
with you.
Tom
