POV-Ray : Newsgroups : povray.off-topic : An Exceptionally Simple Theory of Everything Server Time
15 Jun 2026 05:53:01 EDT (-0400)
  An Exceptionally Simple Theory of Everything (Message 21 to 28 of 28)
Subject: Re: An Exceptionally Simple Theory of Everything
Date: 20 Nov 2007 04:38:17
Message: <4742ab09@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Well, the "zero-point energy" is (amongst other things) the remaining
> jiggle in atoms even at absolute-zero.
  Isn't that kind of contradictory with the very definition of absolute
zero temperature? By definition if there's movement it's not absolute zero.
> It *has* to be there, because
> without it, you'd know both the momentum and position precisely.
  Did Heisenberg really state that the principle applies at all possible
temperatures, including absolute zero? Does it break some kind of universal
law (like conservation of energy or conservation of momentum) if at absolute
zero the uncertainty principle does not apply?
Date: 20 Nov 2007 10:17:22
Message: <4742fa82$1@news.povray.org>
Warp nous apporta ses lumieres en ce 2007/11/20 04:38:
ZPE is also the total energy of every photon that fits within any given finite
space, limited by it's wave length. In any volume you will find at least one
photon for every wave length that is less or equal than the dimentions of that
volume.
Now, how much energy does a single gamma ray photon cary? And now, how many
times it's wave length fits within an hydrogen atom?
I used to have an open mind but my brains kept falling out.
Date: 20 Nov 2007 11:15:21
Message: <47430819$1@news.povray.org>
	From Wikipedia:
"Absolute zero is the point at which particles have a minimum energy,
determined by quantum mechanical effects, which is called the zero-point
energy."
	I guess one can define absolute zero your way as well - but then it
becomes physically unattainable.
	Don't know if Heisenberg stated it, but I think physicists believe it
does. What makes those universal laws and not this?
ASCII stupid question... get a stupid ANSI!
                   /  \/  \ u e e n     /  \/  a w a z
                       >>>>>>mue### [at] nawazorg<<<<<<
                                   anl
Date: 20 Nov 2007 14:28:25
Message: <47433559$1@news.povray.org>
Only in layman's terms. Either you can't ever get to absolute zero, or
there is a theoretical range where the energy is negative (said range
also inaccessible in some sense).
But at this point you're pushing my knowlege of the subject.
I don't know. But look up "Bose-Einstein condensate", where you take one
atom and make it about 10 feet across by getting it close enough to
absolute zero.
Honestly, I don't know, but I wouldn't be surprised. I understand many
of the conservation laws come from quantum measurements.
     It's not feature creep if you put it
     at the end and adjust the release date.
Date: 21 Nov 2007 07:52:04
Message: <op.t147crg6c3xi7v@news.povray.org>
And lo on Tue, 20 Nov 2007 09:38:17 -0000, Warp <war### [at] tagpovrayorg> did
spake, saying:
> zero.
To tie this back to your original query the concept of absolute zero
resided in 'classical' science whereas ZPE belongs in quantum science.
Once again we have two otherwise accurate methods disagreeing.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 21 Nov 2007 08:10:13
Message: <47442e35@news.povray.org>
> did spake, saying:
>> zero.
Not as such; if absolute zero is defined as the temperature at which all
molecular motion ceases, and ZPE is an accurate description of what
exists, then one simply says "absolute zero is an unattainable property
due to the phenomenon of zero-point energy".
Tim Cook
Version: 3.12
Date: 21 Nov 2007 10:14:30
Message: <op.t15ds2d6c3xi7v@news.povray.org>
And lo on Wed, 21 Nov 2007 13:10:11 -0000, Tim Cook
<z99### [at] bellsouthnet> did spake, saying:
>> did spake, saying:
>>> zero.
But we know absolute zero is unattainable in non-isolated systems due to
the implications of the second law of thermodynamics without the
requirements of ZPE, however ZPE seems to set a limit on isolated systems
too. IOW from a classical viewpoint there appears to be no reason why 0K
for an isolated system cannot be achieved, but there is in quantum theory.
Phil Cook
Date: 21 Nov 2007 11:43:24
Message: <4744602c$1@news.povray.org>
Actually, the original "absolute zero" was a calculation. If you take a
litre of gas at 300K and chill it to 150K, it has about half the volume.
If you chill it to 75K, it has a quarter the volume. Absolute zero was
postulated as the temperature at which it would have no volume,
originally, and was recognized as probably not how things would really
work if you could manage to get things that cold. :-)
