POV-Ray : Newsgroups : povray.off-topic : Wahahahaha! Server Time
5 Apr 2026 13:17:17 EDT (-0400)
  Wahahahaha! (Message 121 to 130 of 170)
Subject: Re: Wahahahaha!
Date: 9 Nov 2007 04:33:02
Message: <4734294e$1@news.povray.org>
Stephen wrote:
> Well if we are going for a P***ing contest:)
> uniselector and a rotary phone dial. It could add and subtract with the output
> in binary. Almost as much fun as the wine making.
Um... technically that's not a stored-program computer. :-P
Date: 9 Nov 2007 04:34:25
Message: <473429a1$1@news.povray.org>
Jim Henderson wrote:
> On Thu, 08 Nov 2007 18:20:39 +0000, Orchid XP v7 wrote:
>> Nicolas Alvarez wrote:
>>> Invisible escribió:
>>>> (I never really understood why programs produce core dumps. I mean,
>>>> seriously. What chance is there of anybody *ever* deducing anything
>>>> useful from this data? 10^-78?)
>>> The original programmer with access to the sourcecode *can* deduce data
>>> from it.
>> I seriously doubt it...
> I've done it, several times, even with things I'm not the original
> programmer for but have access to the source code.
Really?
Well, it still sounds absurdly improbable to me, but I'll take your word
for it.
Now, how about that Windoze habit of saying "The program has experienced
an error and will be shut down. Do you want to send debugging
information?" What do you estimate the chances are that *anybody* will
do anything at all with the data thus sent? ;-)
Date: 9 Nov 2007 05:30:00
Message: <web.473435f66f9d6136726bd13c0@news.povray.org>
I think really it was an electro mechanical abacus. It had two hard wired
programmes, add and subtract. :) You had to throw a switch to change the
operation.
Date: 9 Nov 2007 06:07:56
Message: <47343f8c$1@news.povray.org>
> operation.
The word you're looking for is "calculator". ;-)
And what, you couldn't throw in a few extra logic circuits to convert
from binary to decimal? ;-)
I, on the other hand, spent months designing CPU and some RAM circuits
on my Amiga 1200 using DPaint IV AGA. I'm not really sure if it would
ever have worked, but (without the RAM) would have required roughly 200
chips. (7400, A.K.A. TTL quad 2-input NAND.)
I tried to restart that effort using KLogic - but it crashes too much.
Date: 9 Nov 2007 07:40:00
Message: <web.473454e06f9d6136726bd13c0@news.povray.org>
> > operation.
Tobor the Robot :)
binary to decimal converter using only relay logic?
Ah! TTL, I built a digital clock out of TTL but did not put it together when I
checked the current. The PSU would have needed to supply 100 amps at 5 volts
could run on a PP3 battery.
Date: 9 Nov 2007 07:50:25
Message: <47345791@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Most other languages don't futz with the class of the object while it's
> being constructed, so it doesn't really come up, I guess. One of the
> costs of multiple inheritance as implemented by C++?
  I don't understand what multiple inheritance has to do with this.
Date: 9 Nov 2007 07:54:26
Message: <47345881@news.povray.org>
> Presumably that means that if you do sufficiently freaky things with
> pointers to pointers to data through multiple levels of type casts, the
> compiler can't figure out what you're actually doing or something.
  Or you simply have a regular function in the base class, this function
gets called in the initialization list of the base class constructor, and
in the implementation of this function you call a pure virtual function.
  It would be difficult for the compiler to follow how the functions are
being called (and, in fact, it's impossible for it to know if the pure
virtual function actually gets called in the general case).
  The problem with calling a pure virtual function in the base class
constructor is that the derived class has yet not been initialized and
thus calling a derived class function implementation could cause undefined
behavior because it's not constructed.
Date: 9 Nov 2007 07:57:16
Message: <4734592c@news.povray.org>
Um... probably. You know way more about C++ than I ever will.
Either way, it's definitely a program bug, and it's definitely
completely unrelated to virtual memory. ;-)
Date: 9 Nov 2007 08:05:30
Message: <47345b19@news.povray.org>
  That person is presenting the classical symptoms of clueless user whose
brain functions get diminished by 90% when in the precense of a computer.
  One typical symptom is the complete inability to read and understand
simple error or message dialogs. Typically from a message containing 12
words they see 2 and make all kinds of weird conclusions based on these
2 isolated random words.
  The symptoms are worsened when in precense of a knowledgeable person who
is trying (futilely) to teach them how to use the computer. The most typical
(and annoying) thing they will do is, when presented with a dialog with a
simple message and one single button ("Ok"), to ask "what do I do now?"
The mere precense of the knowledgeable person makes them completely blind
to the message in the dialog. They see random symbols which could as well
be chinese kanji.
Date: 9 Nov 2007 08:15:21
Message: <47345d69$1@news.povray.org>
In this particular person's case, I'd say more like a reduction of 60%.
But that's still quite a big reduction, I'm sure you'll agree...
It seems to be a case of somebody seeing
   Microsoft VisualC++ Runtime Library
   A pure virtual function call occurred in SVCHOST.EXE.
and instead read it as
   La la la, la la, la la la *virtual* la la, la la la, la la.
This is probably not helped by the "engineer" who was supposed to be
working on the equipment that this software runs. Apparently he saw this
message and proclaimed "oh, your computer doesn't have enough virutal
memory", and increased the setting from 250 MB to 2500 MB. (I.e., over 2GB.)
Ever since that time, nobody will believe me that the error message has
nothing to do with virtual memory. Or rather, I explain that it's
nothing to do with virtual memory, they go "oh, OK", and then a few days
later they're asking me what I'm going to do about the virtual memory
error that keeps happening. *sigh*
I guess you could classify that as a memory fault rather than a
comprehension fault. I mean, when I explain that it's not virtual
memory, they seem to kind of not really understand but never the less
accept that what I'm saying is right. They just don't *remember* about it...
Oh, and if I find that "engineer", I'm going to give him a talking to.
But, apparently, I'll have to join the queue first.
[Long story. Rather than getting the manufacturers to service our
devices, we're using some El Cheapo company who's staff don't seem to
really know what they're doing, and who take multiple visits to fix
anything. Everybody is very exasperated, but we have been told by HQ
that we can't use the manufacturers for cost reasons...]
