POV-Ray : Newsgroups : povray.off-topic : Theoretical programming question Server Time
11 Oct 2024 05:21:48 EDT (-0400)
  Theoretical programming question (Message 1 to 10 of 16)
Subject: Theoretical programming question
Date: 30 Oct 2007 18:19:24
Message: <4727bbfb@news.povray.org>
Assume you have a stack-based programming language where the stack is
the only place where you can store and handle numerical values. The
language supports pushing and popping values from the stack, as well
as all the basic mathematical operations which operate on the top value
on the stack (for one-operand operations, for example a not operation pops
the top value and pushes its logical not value) or the two top values on the
stack (for example a plus operetion pops two values from the stack and
pushes their sum). Swapping the two top values on the stack is also
supported. Looping is supported, but the loop counter must obviously be
a value on the top of the stack (when the loop condition is evaluated,
like eg. "if the value on top of the stack is not zero, loop").
  What is *not* supported is accessing any value in the stack deeper
than the two top values (which can be accessed eg. using the swap
command).
  My question is: Is this kind of programming language turing-complete?
Can every possible algorithm be implemented with it?
  A more concrete question: Could for example the mandelbrot set be
calculated with such a programming language? (Let's assume there exists
a command like "output the value on the top of the stack as an ascii
character", for example.)
  I just can't figure out a way of doing this.
  For example postscript is stack-based, but it has commands which give
you access to any value in the stack, like "copy the nth value in the
stack to the top of the stack", which is enough to implement the mandelbrot
set calculation. However, without such free access I just can't figure out
a way.
Subject: Re: Theoretical programming question
Date: 30 Oct 2007 21:12:26
Message: <4727e48a$1@news.povray.org>
> command).
How about reading and writing memory that isn't an "immediate" value?
(I.e., random data memory, instead of inline literals in the code?)
Depends in part, I expect, on the size of your values. :-) Seriously, if
you have unbounded integers for values, that's a different question.
I *will* say that when I implemented FORTH a few times, getting things
like "access 6 deep and copy it to the top of the stack" made things
about 23,845 times easier to write programs.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 30 Oct 2007 21:48:57
Message: <4727ed19$1@news.povray.org>
BTW, the way you would prove this is to implement an interpreter for
turing machines in the language. Since a TM has an arbitrarily large
state table, you need to be able to access unbounded state. Without
being able to access main RAM (i.e., the representation of the state
table) without losing your current position (i.e., without popping
everything else off the stack), I'd guess not.
Having a "load the word whose address is on top of the stack" would be
necessary but maybe not sufficient.
Date: 30 Oct 2007 21:49:52
Message: <4727ed50@news.povray.org>
> > command).
  Well, that would effectively be a variable, and thus it's not so much
a stack-based language anymore.
  In this specific case, there's no such support. (Well, technically
speaking it could be possible to construct support for it, but it's way
too cumbersome and complicated to be feasible.)
  I know, but no such luck in this case...
Date: 30 Oct 2007 21:56:47
Message: <4727eeef$1@news.povray.org>
Technically, it's still stack based, since the memory access is going
thru the stack.
Are you saying the only operations to put data *on* the stack are DUP
and PUSH IMMEDIATE?  Seems like it would be difficult to do much, yah.
Date: 30 Oct 2007 22:47:26
Message: <4727face@news.povray.org>
  It supports pushing characters (as their ascii values) in a string too,
but that isn't much of a help in this case.
Date: 30 Oct 2007 22:59:09
Message: <4727fd8d$1@news.povray.org>
I take it you mean in the same way you could just code a series of "push
this integer literal" instruction?
I don't see how you can do it, then.  Imagine a 10,000 state turing
machine. You wouldn't be able to access state 5000's instruction without
wiping out at least instructions 5003-10000.
Maybe there's something exceptionally clever you could do, but with
limited-width registers (i.e., top-of-stack) it would be hard to know what.
Out of curiousity, what kind of language or machine is this?  Or is this
like some contest/homework style problem?
Date: 31 Oct 2007 08:19:33
Message: <472880e5@news.povray.org>
  Befunge.
  I tried to create a mandelbrot generator with it. Failed.
Date: 31 Oct 2007 13:25:00
Message: <web.4728c750d9f26ea37d55e4a40@news.povray.org>
>   Befunge.
What about
http://catseye.tc/projects/befunge93/eg/mandel.bf
linked to from
http://catseye.tc/projects/befunge93/eg/INDEX.html
Tom
Date: 31 Oct 2007 14:59:42
Message: <4728dead@news.povray.org>
Tom York <alp### [at] zubenelgenubi34spcom> wrote:
> What about
  Not much of a help trying to know how to implement it, as you can see...
