POV-Ray : Newsgroups : povray.off-topic : Haskell raving Server Time
2 Jul 2026 01:43:51 EDT (-0400)
  Haskell raving (Message 83 to 92 of 92)
Subject: Re: Haskell raving
Date: 4 Nov 2007 22:01:22
Message: <472e8782$1@news.povray.org>
nemesis wrote:
> good ol' abstract data types.
That's not an abstract data type. It's merely a hidden implementation.
>  I still enjoy Haskell's powerful algebraic
> datatypes, higher-order functions, currying and concise coding a lot more.
*That* is way closer to an abstract data type. :-)  And yah, I'm not
condoning it as better. Merely as possible.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 4 Nov 2007 22:02:34
Message: <472e87ca$1@news.povray.org>
Orchid XP v7 wrote:
>  (But then, presumably the module that
> uses this thing will handle all creation and destruction.)
Well, yes, that's the idea. That's one way it's better than C++'s
mechanism, which requires you to (for example) recompile every client if
you change the layout of the private bits of the class.
> Also fun, you
> how cannot have an array of this thing.
You can't have an array of pointers, or an array of the things? That
seems odd if the former.
Date: 5 Nov 2007 04:30:10
Message: <472ee2a2$1@news.povray.org>
Darren New wrote:
> Orchid XP v7 wrote:
>>  (But then, presumably the module that uses this thing will handle all
>> Also fun, you how cannot have an array of this thing.
No, the latter; you can't have an array who's elements are a particular
type since the compiler won't know how big it is.
(Notice that Haskell has no such limitation; you can expose no
implementation information to THE PROGRAMMER whilst this information IS
still exposed to THE COMPILER. Indeed, you can even define rewrite rules
on the code in your library, so clients of the library actually have
their code transparently rewritten, and the clients don't need to know
this...)
Date: 6 Nov 2007 00:06:08
Message: <472ff640$1@news.povray.org>
Right. Not unusual in compiled languages, that.
So, I can have a module that changes the size of the objects it works
with, and the compiled code of the caller doesn't have to see that?
I.e., to make this happen, does the caller need the source code to my
module? Or can I compile that module, give you the executable (or
library), and you can allocate the right size object without knowing it?
Cause, like, doing that when you're distributing library sources is
pretty easy.
Date: 6 Nov 2007 04:42:03
Message: <473036eb$1@news.povray.org>
Darren New wrote:
>> particular type since the compiler won't know how big it is.
Indeed.
>> IS still exposed to THE COMPILER.
No.
If your code calls my module, and my module changes internally, you will
have to recompile your code. You don't need to *change* your source code
in any way, just recompile it.
The optimiser performs moderately extensive cross-module optimisations.
[My code might get inlined into yours. My types (which you, the
programmer, can't see the representation for) might get unboxed into CPU
registers during tight inner loops in your code. My module might define
transformation rules that rewrite parts of your program when you compile
it. And you don't have to care about any of this...]
Suppose I write some module named "Banana". In order to compile your
code against my module, you will need to possess either
* The source code ("Banana.hs")
* The object code ("Banana.o") + the interface file ("Banana.hi")
As long as you have one or the other, you can compile against my code.
So yes, I can write Banana.hs, compile it (thus generating Banana.o and
Banana.hi) and give you the latter files (which are both binary). You
won't have my source code, but you can still compile against it.
Indeed, the compiler ships with compiled base libraries, and doesn't
*provide* source code unless you download it seperately. (Which is just
as well, because it's quite large and takes a while to compile...)
(As an aside, in order to use the object code file, you'll need to be
using the exact same compiler version as me. On the same platform,
obviously.)
> pretty easy.
Um... I'm not sure exactly which statement you're trying to make.
Date: 6 Nov 2007 14:42:07
Message: <4730c38f$1@news.povray.org>
> Indeed.
OK, all the stuff you described is pretty much SOP for compiled modular
languages (for everything but C++, that is).
Ada, for example, won't even let you link against the .o file if you
compiled against a corresponding .hi file that was compiled more
recently than the .o file.  So you can't even mix-and-match
representations incorrectly.
I meant that making it such that you can "hide" the representation from
the programmer and do all that fancy stuff, but then require the source
files of the declarations (a la C++) is a pretty easy thing to do. Much
harder to allow (say) inlining of already-compiled code.
Date: 6 Nov 2007 14:52:21
Message: <4730c5f5$1@news.povray.org>
>> Indeed.
I'm probably missing something... can't you do it with .o + .h in C++?
Date: 6 Nov 2007 19:25:45
Message: <47310609$1@news.povray.org>
The .h file is source code, hence revealing the internal layout of your
objects. And the functions you want to inline are presented in source.
And you can't be sure the .h matches the .o.
Date: 7 Nov 2007 04:20:57
Message: <47318379@news.povray.org>
...whereas Haskell's .hi files are machine-generated (and not
human-readable).
Date: 19 Nov 2007 05:31:53
Message: <slrnfk2pgp.529.bisqwit@bisqwit.iki.fi>
On Thu, 01 Nov 2007 21:13:15 +0000, Orchid XP v7 wrote:
> I was under the impression that these encodings apply to *strings*, not
> individual characters by themselves...
The encoding applies to individual characters, and
from those characters is the string composed.
  code point character   utf8 encoding
   U+006B     k            6B
   U+0070     p            70
   U+0069     i            69
So the UTF-8 encoding of the string becomes 9 bytes long in total.
Similarly, the Czech word for "cat" would be encoded like this:
   U+006B     k            6B
   U+006F     o            6F
   U+010D     ?            C4 8D
   U+006B     k            6B
   U+0061     a            61
(Note: I'm posting in iso-8859-1, which cannot express
the third character in the word: a "c" with a hacek,
hence substituting with "?".)
And the Japanese word for Japan would be:
   U+65E5     ?            E6 97 A5
   U+672C     ?            E6 9C AC
The encoding (UTF-8) has a few clever attained design goals:
- Backwards compatibility with ASCII
- Asciibetical sorting still works the same way
- Forward and backward seeking in the string possible without desynchronization
- Minimal space wasted
- Possibility to extend naturally if the unicode set grows
Joel Yliluoma - http://iki.fi/bisqwit/
