POV-Ray : Newsgroups : povray.off-topic : I miss this Server Time
5 Jul 2026 08:46:32 EDT (-0400)
  I miss this (Message 18 to 27 of 137)
Subject: Re: I miss this
Date: 24 Oct 2007 17:44:55
Message: <471fbcd7$1@news.povray.org>
Darren New wrote:
> You forgot "It shoots through walls", altho I must admit I never really
> learned to take advantage of that feature, given the difficulty of
> *aiming* thru walls.
I found that once you learned a map really well, this actually became
reasonably easy to do, particularly since I think the gun has a bit of
spray after it goes through a wall.  Once you learned an area well,
you'd know things like:
- Ok, they just went through that door, so if they run in the normal
pattern they''l be coming behind this point in the wall/floor in about a
second and a half.
- I just heard an elevator, and there's only two of those in the level,
so I'll quickly fire off a shot through the wall of the room adjacent to
one of them.
It actually got to the point when my friends and I learned that we
needed to do things like press elevators and not get on them, or run
around corners, stop, wait for the tau cannon blast or grenade through
the window, then continue.
I also liked the use of the tau cannon for propelling yourself through
the air at crazy speeds.
Date: 25 Oct 2007 03:11:54
Message: <472041ba@news.povray.org>
> Well, in an atmosphere, it would be like being hit by an explosion, as you
> pile up all the air in front of it.
Wouldn't something going that fast vaporize immediately when it hit the air
going that fast?  Doesn't stuff that going only a fraction of that speed
burn up in the outer atmosphere?
> Plus, don't forget all that nice gamma-burst radiation. (The railguns in
> the story actually had to fire for a few thousand rounds to punch a hole
> in the atmosphere so the needles wouldn't just vaporize.)
Ah yes, ok :-)
>> Well... technically a railgun (not to be confused with a coilgun) fires
>> projectiles using electrical propolsion. There's nothing in the
>> definition about how fast. ;-)
> True. But to get the electrical propultion to work, the projectile needs
> to be pretty small, which means it needs to go pretty fast. Otherwise it's
> more of a thrower than a firearm. :-)
In one of our lectures at university the dude had this rail-gun.  It was
about 2 metres long and plugged into the 420V 3-phase power supply.  He
loaded it with a brass (I think) solid lump of metal that was in a pointy
bullet shape.  It wasn't small, about 10cm diameter and 30cm long.  When he
flicked the switch it punched through (and got stuck in) a big bit of wood
just off the end of the bench he was using.  Rig up 10 or 20 metres of that
baby and it would be interesting :-)
Date: 25 Oct 2007 06:23:15
Message: <47206e93$1@news.povray.org>
Darren New wrote:
> Bill Pragnell wrote:
>> although the basic premise for the gun is a real one,
> Sure. You try holding a weapon that fires something at relativistic speeds.
I meant the railgun aspect - accelerating the projectile using
electromagnetics.
>> or the dubious claim that it can fire projectiles at near lightspeed
> That's what a railgun is for.
No it's not. A railgun accelerates a projectile with something like a
linear accelerator. You get a fast-moving slug but I don't think
anyone's under the illusion that it could be relativistic.
> You're only seeing the shockwave. ;-)
Hmm. *shakes head dubiously*
Date: 25 Oct 2007 06:25:50
Message: <47206f2e@news.povray.org>
> it's more of a thrower than a firearm. :-)
A railgun is exactly that - a thrower. A firearm uses chemical reactions
to provide impulse.
You would never use one as a portable antipersonnel weapon anyway, it's
probably more useful as a large scale space-based anti-ship or
planet-busting weapon.
Date: 25 Oct 2007 06:30:40
Message: <47207050$1@news.povray.org>
Darren New wrote:
> (The railguns in the story actually had to fire
> for a few thousand rounds to punch a hole in the atmosphere so the
That's pretty cool. Relativistic weapons would only really be as useful
as nukes - to cause almost-total destruction.
>> But anyway, even without relativity, the recoil would be absurd.
> Yep. If it can go thru a concrete wall coming out the front, the stock
> can certainly break your shoulder.
It would do more than that. I can't be bothered with the sums right now
but I imagine the recoil from a relativistic projectile gun would smash
you to bits. You'd have to design any such gun to be recoilless somehow.
<insert inertia-absorbing machinery here>
Date: 25 Oct 2007 07:32:27
Message: <47207ecb@news.povray.org>
> electromagnetics.
  Newton's third law still applies, even at relativistic accelerations.
If a force is applied to the projectile to make it accelerate at a certain
direction, another force will accelerate something else (ie. the gun)
at the opposite direction. I can't think of any way of avoiding that.
Date: 25 Oct 2007 07:49:54
Message: <472082e2$1@news.povray.org>
>> electromagnetics.
Yes, I know all that. When I said 'basic premise' I was referring to the
use of a magnetic field to accelerate the projectile, not the issues
surrounding the claimed muzzle speed.
Hollywood gets projectile momentum transfer wrong all the time. Every
time somebody gets shot by any kind of weapon, for a start.
Date: 25 Oct 2007 07:50:59
Message: <47208323@news.povray.org>
Bolt it to the Earth, then (assuming you're measuring recoil relative to the
Earth) the recoil will be avoided.
Date: 25 Oct 2007 08:09:10
Message: <4720875e@news.povray.org>
  Yes, it's funny how Hollywood physics are so skewed while still not
appearing completely wacky to the layman.
  For example, the faster the bullet, the farther it throws the person
who is hit by that bullet. In reality it's almost the opposite: The faster
the bullet, the less effect on the victim. The bullet just goes through
like a needle, and only little of its kinetic energy is trasnferred to
the victim itself. A slower bullet, however, transfers its kinetic energy
more to the victim because the body of the victim gets to slow down the
bullet, even so much that it might not even get through. In that case
the entire kinetic energy of the bullet is transferred. However, even in
that case the amount of kinetic energy is quite small compared to the
mass of an average person (the bullet is, after all, very light) and it
will not cause too much of an effect. Any minor effect will more likely
be overwhelmed by muscle spasms caused by the pain, which may cause the
victim to move to any random direction.
  (In some cases, if a fast bullet goes through, the jet effect caused
by the blood in the exit wound might even cause a movement towards the
shooter, not away from him... Still quite small, though.)
  Of course if we think about it in newtonian terms, if the victim gets
thrown back several meters, so should the shooter be too. The exact same
kinetic force is applied to the shooter, to the opposite direction.
(Well, technically speaking *more* kinetic energy is applied to the shooter
than to the victim because the bullet loses some kinetic energy during its
flight due to air friction, so if anything, the shooter should fly farther
back than the victim.)
  Then there are all those sparks. Bullets always send sparks when they
hit almost any surface. Of course real bullets don't, because bullets are
usually made of metals (such as copper) which do not spark even if they
hit some other metal. The movie makers themselves know this because they
can't get the sparks with real bullets but they must cheat (at least in
older and cheaper movies they used specially constructed "bullets" which
send sparks when they are broken).
  Those sparks have always bothered me. They make the scene unrealistic
and overboard. They don't add to the intensity of the scene.
  For a superb exception to this, see the beginning scene of Saving Private
Ryan. It's super-realistic. No bullet sparks. Yet the scene is extremely
immersive and intense. You can really *feel* the danger posed by those
bullets which you can't see but which are coming from everywhere.
Date: 25 Oct 2007 08:55:39
Message: <4720924b$1@news.povray.org>
Darren New wrote:
> Orchid XP v7 wrote:
>> range, and you can charge it up to deliver hits that can take down
>> just about anything. (If you don't miss!)
I remember that gun - excellent in DM games.
As others have said - one can get pretty good at where to shoot at the
right times to get a kill.
I had some people pretty miffed at me sometimes because they couldn't
hide anywhere...
Tom
