POV-Ray : Newsgroups : povray.off-topic : Mac Plus vs AMD Dual Core Server Time
7 Jul 2026 19:06:29 EDT (-0400)
  Mac Plus vs AMD Dual Core (Message 131 to 140 of 170)
Subject: Re: Mac Plus vs AMD Dual Core
Date: 27 Oct 2007 08:44:06
Message: <47233296@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4722aa00$1@news.povray.org...
> scott wrote:
>> that's one reason why cameras use USB and not LAN or WLAN
> USB *is* a LAN. You mean memory chips? I've seen cameras that do wireless
> LAN too, for (for example) places that take your ID photo and print it out
> for you.
>> too hard/impossible to get a network stack on DOS?
> Errrr, nope!  You could get network stacks pretty easily, really. That's
> what the whole NETBIOS was.  Back in the DOS 3.x days, if I recall. Why
> would it be difficult to put a network stack on a DOS machine?
Oh gawd, suddenly I remember it all:
The long boot sequence
The 3C509 drivers;
IPConfig;
The ReDiRector
<has a Jason-Bourne-finding-out-he is-really-David-Webb episode>
Date: 27 Oct 2007 11:34:02
Message: <47235a6a$1@news.povray.org>
Orchid XP v7 nous apporta ses lumieres en ce 2007/10/27 05:55:
> Darren New wrote:
>> Orchid XP v7 wrote:
>>> Because almost no software will run on it any more.
>>> Seriously. I'd still be using WinNT if it wasn't for that.
>> Now consider why it might be that new software doesn't run on old
>> OSes, even tho the old software runs on the new OSes.  Maybe it's
>> because the new OSes provide more services and functionality that the
>> programmers like to take advantage of to make their lives easier?
> More likely M$ rearranged some API to induce an artificial dependency,
> but anyway...
No API rearrengement at all, NEW APIs! Some older APIs where also upgraded, but
they are still called the same way as before and return the same thing. After
all, they have to make sure that existing softwares designed for win 2K and XP
continue to run. Whitch in turn, impose that programms made for the win 9x to
still be able to run on XP and Vista.
Al Gore is proof that Tennessee has a sense of humor.
Date: 27 Oct 2007 12:41:15
Message: <47236a2b@news.povray.org>
"Alain" <ele### [at] netscapenet> wrote in message
news:47235a6a$1@news.povray.org...
> > but anyway...
upgraded, but
And some of those new APIs are quicker and easier to use. Hence the lazy
programmers (*) who develop apps for windows will use those over the older
APIs. Hence stuff works on XP that won't work on 98
(*) It has been said that laziness is a desirable trait in programmers. I'm
not making a judgement on everyone who develops
Date: 27 Oct 2007 16:21:16
Message: <47239dbc$1@news.povray.org>
Warp wrote:
>   Why is that relevant?  There are no programming languages which can handle
> the entire set of integers.
Again:
But yes, what happens when you exceed what the machine can handle is
*exactly* what we're talking about here. C does a well-defined but
surprising-to-the-naive method for dealing with integers too large.
Programming languages that natively handle unbounded integers don't
distinguish between signed and unsigned integers, because people don't
program down to the last bit of an integer. Hence, there's no need to
define what happens when you combine an unsigned integer that won't fit
in a signed integer's value range with a signed integer.
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 27 Oct 2007 16:23:50
Message: <47239e56@news.povray.org>
> but anyway...
Then NT code wouldn't run on XP, which is generally not the case unless
you go out of your way to make that happen.
Date: 2 Nov 2007 04:50:24
Message: <472af2e0@news.povray.org>
DirectX is a prime example, since V5 it has got easier and easier to use
with each revision.  In V6 IIRC you needed a huge amount of code to query
the graphics card for screen modes and types, driver capabilities etc.  Even
the change from V9 to V10 has simplified a lot of the functions for checking
driver capabilities, you no longer have to query every function you are
using to see if it is supported or not...  You'd be silly to use V6 when
V9/V10 is much easier to use, supports many more features and 99% of people
can use it.
Date: 2 Nov 2007 04:56:45
Message: <472af45d$1@news.povray.org>
> That was now about 10 years ago (doesn't seem possible it was that long
> ago).  But desktop lockdown and software installation policies are very
> common in corporate IT policies these days, especially with all the
> crapware/malware/spyware that's in the Windows world.
Yep, and the policy works too.  Where I used to work everyone was using
Win95 (to start with, they slowly changed to XP when I was leaving) and I
don't think we ever saw a blue-screen.  This was because we were only
allowed to use approved software, and IT had tested to death anything that
was to be used on the system to make sure it was compatible with everything.
Add to that the fact that they routinely wiped the HDs, it meant a very
stable computing environment virtually transparent to the user (unless you
wanted to install some application that was not in the list).
Allowing users to modify settings and install anything usually leads to an
unstable environment and many many IT support calls.
Date: 2 Nov 2007 05:00:41
Message: <472af549$1@news.povray.org>
> Sure, manipulating an 8 megapixel photo takes a lot of RAM. But what about
> while you're *not* manipulating an 8 megapixel photo? Why should it
> require any more RAM then? (Not to mention CPU time...)
Because it keeps 100 levels of undo data, has code for doing 400 different
brush types and colour gradients, functions for adjusting colour balance and
histogram equalisation, red-eye removal, perspective correction, much higher
resolution and colour depth icons for all the tool-bars, critical parts of
the code have been optimised for speed (at the expense of RAM usage) now
that everyone has more RAM, it has loaded lots of stuff to RAM that it
thinks you *might* use so that it appears to run quicker, etc.
Personally, I like having all that stuff at the expense of it using 1% of my
RAM instead of 0.1%.
Date: 2 Nov 2007 14:41:15
Message: <472b7d5b$1@news.povray.org>
>> about while you're *not* manipulating an 8 megapixel photo? Why should
>> it require any more RAM then? (Not to mention CPU time...)
> different brush types and colour gradients, functions for adjusting
> colour balance and histogram equalisation, red-eye removal, perspective
> correction, much higher resolution and colour depth icons for all the
> tool-bars, critical parts of the code have been optimised for speed (at
> the expense of RAM usage) now that everyone has more RAM, it has loaded
> lots of stuff to RAM that it thinks you *might* use so that it appears
> of my RAM instead of 0.1%.
Well, you must have some serious amounts of RAM to play with is all I
can say... ;-)
Date: 2 Nov 2007 14:42:22
Message: <472b7d9e$1@news.povray.org>
> an unstable environment and many many IT support calls.
Finally, something we can agree on...
