POV-Ray : Newsgroups : povray.off-topic : Power Server Time
13 Jun 2026 21:04:57 EDT (-0400)
  Power (Message 34 to 43 of 133)
Subject: Re: Power
Date: 2 Sep 2007 23:50:29
Message: <46db8485$1@news.povray.org>
Orchid XP v3 wrote:
> Can anybody suggest why this might be? I mean, huge powerful electric
	They just are.
	I find it interesting that you're focusing on power rather than energy.
How long do you spend boiling water vs how long is the washer running?
Atheism is a non-prophet organization.
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Subject: Re: Power
Date: 3 Sep 2007 02:45:39
Message: <46dbad93$1@news.povray.org>
>> Yes, but 4 W!!!!  4 mW should be enough.
> Perhaps, depends on what other features the kit has, though.
How about running an LCD panel, transmitting and receiving data from a
base-station 10s of miles away, interpreting incoming data packets, waiting
for key presses?  All for 10 mW.
> I know, for example, that the system I have here at my feet has an ATX
> board, which means the "power" switch is solid state rather than a
> physical switch.  That means the board is powered all the time (when the
> power supply switch is on at the back of the system).
The main point is that mainboard and PSU makers have no incentive to make a
low power and efficient "off" state.  Really, such a small fraction of
people/companies will make a decision based on the efficiency of the off
state it is not worth it at all.
Subject: Re: Power
Date: 3 Sep 2007 02:46:56
Message: <46dbade0@news.povray.org>
> Even so... that takes it up to, what, 19 mW? I don't know what the other
> 3,981 W is for...
Heat.
> Convesly, the PC uses *less* power than I was expecting when turned on,
> so...
Is that with or without POV rendering? ;-)  Go on then, tell us how much it
would cost to do a 9 month render...
Subject: Re: Power
Date: 3 Sep 2007 03:04:20
Message: <46dbb1f4$1@news.povray.org>
> Oh... no, not really. I mean, sound vibrations are really, *really* tiny.
> (Think about it; even when the sound is turned up painfully loud, the
> speaker cones move by such a tiny amount you can't even see them move at
> all!)
Huh?  Even at normal listening volumes I can see the bass cones move on
mine...  Try feeding a 20 Hz sine wave in and watch the cone...  These are
only perhaps 6" drivers, nothing spectacular.  Mind you, I have never
noticed the tiny 2" cones move on my PC speakers.
> AFAIK, the reason we have 200 W amplifiers and speakers isn't so much
> because it takes that much electricity to move air around, but to reduce
> RF pickup in the speaker wire... (Or rather, to reduce the *signifigance*
> of such pickup.)
Huh?  You are saying that they deliberately make speakers less efficient so
that a higher voltage can be used to drive them?  I've never heard that
before.  Also I have never seen much "serious" hi-fi rated at anything like
200 W for home use.  IME 15 W per channel is plenty to fill a medium sized
room very loudly, perhaps if you live in a very large house and like
listening to music very loud you'd want 200 W.
> The mater claims 249.98 V.
Sounds ok to me, the voltage will fluctuate a lot depending on lots of
factors, like how much power people are using around you etc.  Try measuring
the voltage at different times of the day...
> Also, 49.97 Hz. (So much for "they keep it to exactly 50 Hz to help all
> those clocks that use it". The frequency waivers all over the place!)
And you think your meter is accurate to +/- 0.03 Hz?  It's worth noting that
the national grid in the UK keeps all power stations interconnected so all
generators *must* make power at the same frequency.  If everyone in the
country turned on their kettles then the frequency and voltage would
probably drop significantly...
Subject: Re: Power
Date: 3 Sep 2007 04:09:52
Message: <46dbc150$1@news.povray.org>
> waiting for key presses?  All for 10 mW.
Well, the distance to the base station doesn't matter unless it's
wireless, then it's just the transmitter power.
>> the power supply switch is on at the back of the system).
> make a low power and efficient "off" state.  Really, such a small
> fraction of people/companies will make a decision based on the
> efficiency of the off state it is not worth it at all.
Very true.
Jim
Subject: Re: Power
Date: 3 Sep 2007 04:31:34
Message: <46dbc666$1@news.povray.org>
I was just illustrating that a normal mobile phone can do all that stuff
(both transmitting and receiving to the base station) for around 10 mW.
Subject: Re: Power
Date: 3 Sep 2007 14:03:05
Message: <46dc4c59$1@news.povray.org>
>> other 3,981 W is for...
> Heat.
>> on, so...
Without *anything* happening, it uses 110 W.
With my stonking-great video card with a fan the size of a plannet, it
uses 190 W. (Roughly. It waivers a lot.) During the boot sequence it
tops 280 W. (Presumably when all those electric motors all start up at
once...)
Actually, what the heck...
http://blog.orphi.me.uk/about/power
(Table of my work so far.)
Subject: Re: Power
Date: 3 Sep 2007 14:03:38
Message: <46dc4c7a$1@news.povray.org>
John VanSickle wrote:
>> Damn... pitty we can't use heat to do *useful* stuff!
> Heat already does useful things.  For instance, it causes cute girls to
> wear skimpy clothing.
Hey, neat!
(Pitty it's too damn hot to do anything about it...)
Subject: Re: Power
Date: 3 Sep 2007 14:09:22
Message: <46dc4dd2$1@news.povray.org>
>> tiny. (Think about it; even when the sound is turned up painfully
>> loud, the speaker cones move by such a tiny amount you can't even see
>> them move at all!)
> are only perhaps 6" drivers, nothing spectacular.  Mind you, I have
> never noticed the tiny 2" cones move on my PC speakers.
I have never seen any cone on any speaker move visibly - no matter how
much physical pain my ears were in. See, human ears are, like, *really*
sensitive...
> so that a higher voltage can be used to drive them?  I've never heard
> that before.
Yes.
> anything like 200 W for home use.  IME 15 W per channel is plenty to
> fill a medium sized room very loudly, perhaps if you live in a very
> large house and like listening to music very loud you'd want 200 W.
Hmm, I think my amplifier (nothing special) is rated at 60 W per
channel. (IIRC, into 8 ohms at 1 kHz.)
That's 60 W RMS by the way. Not like the "100 W" portable thing I once
owned that was actually 0.5 W RMS. ;-)
> measuring the voltage at different times of the day...
Wait... the *voltage* changes depending on how much you use it? That's
odd. I thought that potential difference was always constant, and it's
only *current* that changes...
>> all those clocks that use it". The frequency waivers all over the place!)
Actually, the instruction book (which is oddly large for such a simple
device) states the accuracy for all readings. I forget what it says for
the frequency...
Subject: Re: Power
Date: 3 Sep 2007 14:10:45
Message: <46dc4e25$1@news.povray.org>
> energy. How long do you spend boiling water vs how long is the washer
> running?
Well, that's the other part. The fridge doesn't use much power, but it's
permanently switched on. (Altough obviously it only draws any current
now and then.) So far it's clocked up a fair number of kWh...
