POV-Ray : Newsgroups : povray.off-topic : Power Server Time
11 Jul 2026 04:10:25 EDT (-0400)
  Power (Message 31 to 40 of 133)
Subject: Re: Power
Date: 2 Sep 2007 18:03:38
Message: <op.tx1rkc0ucs6ysw@e6600>
On Sun, 02 Sep 2007 22:05:17 +0200, Orchid XP v3 <voi### [at] devnull> wrote:
>>> PS. 230 V? I thought it was 250 V...
>>  IIRC the spec was changed from 240 +/- 10% to 230 +15% -5% (or
>> something equally stupid) to get us inline with Europe.  Doesn't your
>> meter tell you the voltage too?
> The mater claims 249.98 V.
Still within tolerance.
http://en.wikipedia.org/wiki/Mains_electricity#Voltage_levels
> Also, 49.97 Hz. (So much for "they keep it to exactly 50 Hz to help all
> those clocks that use it". The frequency waivers all over the place!)
http://en.wikipedia.org/wiki/Mains_electricity#Frequency_stability
http://www.dynamicdemand.co.uk/grid.htm
FE
Subject: Re: Power
Date: 2 Sep 2007 22:48:49
Message: <46db7611@news.povray.org>
Orchid XP v3 wrote:
>>> Can anybody suggest why this might be?
>> It's because heat represents a huge amount of energy.
>> For instance, the humble calorie, the amount of energy required to
>> raise a single gram of water by one degree celsius, is the same amount
>> of energy required to lift that same gram of water about 387 meters in
>> Earth's gravity, or accelerate it from zero to 87 meters per second.
> Damn... pitty we can't use heat to do *useful* stuff!
Heat already does useful things.  For instance, it causes cute girls to
wear skimpy clothing.
John
Subject: Re: Power
Date: 2 Sep 2007 23:42:17
Message: <46db8299$1@news.povray.org>
On Sun, 02 Sep 2007 20:58:04 +0100, Orchid XP v3 wrote:
>  I really, *really* hope I have that
> disabled though... (It's hard to tell!)
BIOS settings.  But it's not exactly easy to learn the wake-up code from
outside a NATted connection.  You've got to know the MAC address of the
system, IIRC.
Yep, according to http://en.wikipedia.org/wiki/Wake-on-LAN the magic
packet is set over a connectionless protocol (UDP, IPX) with "FF FF FF FF
FF FF FF" (in hex, hopefully obviously) plus 16 repetitions of the target
machine's MAC address, plus a 4-6 byte password.
So I don't think you have to worry about me turning your machine on from
half a world away.
Jim
Subject: Re: Power
Date: 2 Sep 2007 23:50:29
Message: <46db8485$1@news.povray.org>
Orchid XP v3 wrote:
> Can anybody suggest why this might be? I mean, huge powerful electric
	They just are.
	I find it interesting that you're focusing on power rather than energy.
How long do you spend boiling water vs how long is the washer running?
Atheism is a non-prophet organization.
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Subject: Re: Power
Date: 3 Sep 2007 02:45:39
Message: <46dbad93$1@news.povray.org>
>> Yes, but 4 W!!!!  4 mW should be enough.
> Perhaps, depends on what other features the kit has, though.
How about running an LCD panel, transmitting and receiving data from a
base-station 10s of miles away, interpreting incoming data packets, waiting
for key presses?  All for 10 mW.
> I know, for example, that the system I have here at my feet has an ATX
> board, which means the "power" switch is solid state rather than a
> physical switch.  That means the board is powered all the time (when the
> power supply switch is on at the back of the system).
The main point is that mainboard and PSU makers have no incentive to make a
low power and efficient "off" state.  Really, such a small fraction of
people/companies will make a decision based on the efficiency of the off
state it is not worth it at all.
Subject: Re: Power
Date: 3 Sep 2007 02:46:56
Message: <46dbade0@news.povray.org>
> Even so... that takes it up to, what, 19 mW? I don't know what the other
> 3,981 W is for...
Heat.
> Convesly, the PC uses *less* power than I was expecting when turned on,
> so...
Is that with or without POV rendering? ;-)  Go on then, tell us how much it
would cost to do a 9 month render...
Subject: Re: Power
Date: 3 Sep 2007 03:04:20
Message: <46dbb1f4$1@news.povray.org>
> Oh... no, not really. I mean, sound vibrations are really, *really* tiny.
> (Think about it; even when the sound is turned up painfully loud, the
> speaker cones move by such a tiny amount you can't even see them move at
> all!)
Huh?  Even at normal listening volumes I can see the bass cones move on
mine...  Try feeding a 20 Hz sine wave in and watch the cone...  These are
only perhaps 6" drivers, nothing spectacular.  Mind you, I have never
noticed the tiny 2" cones move on my PC speakers.
> AFAIK, the reason we have 200 W amplifiers and speakers isn't so much
> because it takes that much electricity to move air around, but to reduce
> RF pickup in the speaker wire... (Or rather, to reduce the *signifigance*
> of such pickup.)
Huh?  You are saying that they deliberately make speakers less efficient so
that a higher voltage can be used to drive them?  I've never heard that
before.  Also I have never seen much "serious" hi-fi rated at anything like
200 W for home use.  IME 15 W per channel is plenty to fill a medium sized
room very loudly, perhaps if you live in a very large house and like
listening to music very loud you'd want 200 W.
Sounds ok to me, the voltage will fluctuate a lot depending on lots of
factors, like how much power people are using around you etc.  Try measuring
the voltage at different times of the day...
And you think your meter is accurate to +/- 0.03 Hz?  It's worth noting that
the national grid in the UK keeps all power stations interconnected so all
generators *must* make power at the same frequency.  If everyone in the
country turned on their kettles then the frequency and voltage would
probably drop significantly...
Subject: Re: Power
Date: 3 Sep 2007 04:09:52
Message: <46dbc150$1@news.povray.org>
> waiting for key presses?  All for 10 mW.
Well, the distance to the base station doesn't matter unless it's
wireless, then it's just the transmitter power.
>> the power supply switch is on at the back of the system).
> make a low power and efficient "off" state.  Really, such a small
> fraction of people/companies will make a decision based on the
> efficiency of the off state it is not worth it at all.
Very true.
Jim
Subject: Re: Power
Date: 3 Sep 2007 04:31:34
Message: <46dbc666$1@news.povray.org>
I was just illustrating that a normal mobile phone can do all that stuff
(both transmitting and receiving to the base station) for around 10 mW.
Subject: Re: Power
Date: 3 Sep 2007 14:03:05
Message: <46dc4c59$1@news.povray.org>
>> other 3,981 W is for...
> Heat.
>> on, so...
Without *anything* happening, it uses 110 W.
With my stonking-great video card with a fan the size of a plannet, it
uses 190 W. (Roughly. It waivers a lot.) During the boot sequence it
tops 280 W. (Presumably when all those electric motors all start up at
once...)
Actually, what the heck...
http://blog.orphi.me.uk/about/power
(Table of my work so far.)
