POV-Ray : Newsgroups : povray.off-topic : ze moon Server Time
10 Jun 2026 00:29:57 EDT (-0400)
  ze moon (Message 3 to 12 of 32)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: ze moon
Date: 28 Aug 2007 07:40:47
Message: <46d409bf$1@news.povray.org>
"Brian Elliott" <NotForSpam@AskIfUWant> wrote in message
news:46d40701@news.povray.org...
> "Tim Cook" <z99### [at] bellsouthnet> wrote in message
> news:46d3f86a@news.povray.org...
>> Tried taking a pic when it was fully in shadow but was too dark to find
>> thru camera.  :(
>> Tim Cook
> I can't get a stable-enough image.  I have a tripod, but it is set on
> grass
> and with no lead for bulb exposure, I still must touch the camera for
> time-lapse photography - and it moves, however careful I am.  My lens only
> extends to 125 mm so I can't zoom very close -- not that a 400 mm would be
> any  good anyway with the mechanical instability I have to deal with.
> And for any exposure longer than a few seconds, I'd need a tracking mount.
> 1 degree Earth rotation per every four minutes -- bah.
BTW, I notice that your image is upside-down compared to mine (fuzzy, but
can still tell).  Shows that you're in the Northern hemisphere and I'm in
the Southern.  Here (Brisbane, Australia) the shadow grew from the
bottom-left corner until the last fingernail vanished top-right.  My pics
here were taken after peak coverage but before direct light has struck the
Moon yet.
Anyway, still disappointed I haven't succeeded in getting a good image.
Date: 28 Aug 2007 08:32:29
Message: <46d415dd$1@news.povray.org>
> grass
Hold a black card infront of the lens (but not touching) as you press the
shutter, then move the card away a split second after you release the
shutter.  That might help.
Date: 28 Aug 2007 09:27:21
Message: <46d422b9@news.povray.org>
"scott" <sco### [at] laptopcom> wrote in message
news:46d415dd$1@news.povray.org...
>> grass
On camera bulb setting, it holds its shutter open as long as the
shutter-release button is held pressed, irrespective of any light hitting
the meters.  Which means unfortunately, I have to keep a finger pressed on
it for the entire length time I want the exposure.  Or get a proper bulb
cord.  Actually I do have one with another old Pentax SLR that I have had
for many years, but its screw thread doesn't fit into THIS modern camera.
Dammit.
Date: 28 Aug 2007 09:47:25
Message: <46d4276d$1@news.povray.org>
> the meters.
Oh I see, I had assumed you were setting the shutter time manually as
anything more than 30 seconds is going to get blurry (as you suggested).
On my camera (Canon 300D) the remote shutter release is just a stereo 2.5mm
jack, easy to pick up from electronics stores and wire up 2 simple switches
if you can solder.
I suppose another alternative would be to use some sort of clamp to hold
down the shutter button, then you can use the black card trick while
attaching it and removing it.
Date: 28 Aug 2007 09:57:23
Message: <46d429c3$1@news.povray.org>
> mount. 1 degree Earth rotation per every four minutes -- bah.
http://strobist.blogspot.com/2006/09/on-assignment-how-to-light-comet.html
They have some nice guides to cheap camera tricks. I think they left out
the required distance from the center of the screw to the center of the
hinge, 11 and 7/16 inches, but it's there in the comments some place.
Date: 28 Aug 2007 10:14:26
Message: <46d42dc2$1@news.povray.org>
> 2.5mm jack, easy to pick up from electronics stores and wire up 2 simple
> switches if you can solder.
Simple way of getting around spending what they want for a remote. Might
want to look for a switch that closes one contact on a half press, and
another on full press to emulate the way the shutter button works. I
don't know how easy or difficult it would be to find a SPDT pushbutton
switch, though.
(Searching...Aha, found one!)
http://tinyurl.com/323qqz
Date: 28 Aug 2007 10:28:42
Message: <46d4311a$1@news.povray.org>
> another on full press to emulate the way the shutter button works. I don't
> know how easy or difficult it would be to find a SPDT pushbutton switch,
> though.
For mine I used two toggle switches.  I found ones where you could flick
them either way, to the left and they stay there (for long exposures) or to
the right and they spring back (for repeated fast shots).  I just mounted
them side-by-side in a small box and another 2.5mm socket, connected them up
with a pre-made 2.5 mm stereo lead (I hate soldering those tiny plugs and
they always come unstuck after a few weeks), and it all worked fine.
Date: 28 Aug 2007 10:31:41
Message: <46d431cd$1@news.povray.org>
Hmm, My guess now is not quite. Not enough information about that
switch, but more info gives that SPDT pushbuttons are usually on-on,
which means they don't have a center position. :/ if anyone can find a
SPDT pushbutton that is off-on-on let me know.
Date: 28 Aug 2007 10:36:56
Message: <46d43308@news.povray.org>
> to the right and they spring back (for repeated fast shots).
RS (rswww.com) part number 448-0810 if you are interested.
Date: 28 Aug 2007 10:57:10
Message: <46d437c6$1@news.povray.org>
> thru camera.  :(
We like the moon
coz it is close to us
we like the moooon!
but not as much as a spoon
'cause that's more use for eating soup
and a fork isn't very useful for that
unless it has got many vegetables
and then you might be better off with a
chop-stick
unlike the moon
it is up in the sky
it's up there very high
but not as high
as maybe
dirigibles or zeppelins
or lightbulbs
and maybe clouds
and puffins also I think maybe
they go quite high too
maybe not as high as the moon
coz the moon is very high
we like the moon
the moon is very useful everyone
everybody like the moon
because it light up the sky at night
and it lovely
and it makes the tide go and we like it
but not as much as cheese
we really like cheese
we like zeppelins
we really like them
and we like kelp and we like moose
and we like deer and we like marmots
and we like all the fluffy animals
we really like the moon
Sorry I can't resist
