POV-Ray : Newsgroups : povray.off-topic : A small puzzle Server Time
7 Sep 2024 19:13:03 EDT (-0400)
  A small puzzle (Message 1 to 10 of 198)
Subject: A small puzzle
Date: 16 May 2008 11:59:28
Message: <482daf60$1@news.povray.org>
OK, so here's one for you...
If I put my car into top gear and set the engine to 3,500 revolutions
per minute, my car travels forward at almost exactly 75 miles per hour.
So... how far forward does it travel for a single revolution of the engine??
Similarly, at that speed my car achieves roughly 50 miles per gallon of
fuel. So how much fuel does it inject into each cylinder??
[My car has a four-cylinder, four-stroke internal compustion engine, and
is normally-asperated. And runs on petrol, in case that wasn't obvious.
Presumably the timing is therefore set so that exactly one cylinder
fires for every revolution of the engine.]
http://blog.orphi.me.uk/
Subject: Re: A small puzzle
Date: 16 May 2008 13:33:54
Message: <482dc582$1@news.povray.org>
> engine??
Nope. Each cylinder fires once for every two revolutions. You have a 4
cyl engine therefore two cylinders fire for each rev.
John
I will be brief but not nearly so brief as Salvador Dali, who gave the
world's shortest speech. He said, "I will be so brief I am already
finished," then he sat down.
Date: 16 May 2008 13:39:48
Message: <482dc6e4@news.povray.org>
> engine??
574643.
the "almost" you told, neither tires wearing nor possible sliding.
None.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 16 May 2008 15:31:30
Message: <482de112$1@news.povray.org>
On Fri, 16 May 2008 20:40:04 +0300, Eero Ahonen wrote:
> Ah, you want the unit? µm, naturally. This of course doesn't take count
Or the effects of momentum. ;-)
Jim
Date: 16 May 2008 16:00:01
Message: <web.482de740477c8c6261d9700@news.povray.org>
Is this a math puzzle, or a real question?
If it's a real question, it's almost impossible to answer from the information
given.  You have to take into account acceleration, momentum, friction, etc.
....Chambers
Date: 16 May 2008 16:11:15
Message: <482dea63$1@news.povray.org>
How so?
The engine is directly coupled to the wheels. Unless the car looses
traction, the forward motion of the car and the rotational speed of the
wheels and engine all have a simple linear relationship.
Date: 16 May 2008 16:20:58
Message: <482decaa$1@news.povray.org>
>>> hour. So... how far forward does it travel for a single revolution of
>>> the engine??
>> information given.  You have to take into account acceleration,
> How so?
There isn't a linear relationship between the rotational speed of the
wheels and the speed of the engine.
If I take my foot off the gas, the engine revs drop.  The car may or may
not slow down (depending on the road and the landscape).
Similarly, if I apply the brakes to a full stop, the engine doesn't die,
it idles.
Then of course if you put the car in neutral, you've completely
disengaged the engine from the wheels.
Jim
Date: 16 May 2008 16:26:56
Message: <482dee10@news.povray.org>
  Isn't this laughably simple to calculate?
  3500 rpm = 3500*60 rph, and in 1 hour it travels 75 miles. Thus divide
75 miles by 3500*60 revolutions, and you have the amount of miles per one
revolution, which would be approximately 0.0003571428 miles.
  Given that I'm not sure which whacky units miles are divided into,
I'll just convert those to more understandable units, so 75/(3500*60)
miles is approximately 57.5 centimeters.
Date: 16 May 2008 16:27:03
Message: <482dee17$1@news.povray.org>
Well that's news.
Not true. The engine revs depend on the speed of the vehicle.
If you don't believe me, try rolling down a hill at 30, and then stick
the car into 1st gear. Watch the revs go through the roof, even though
you haven't touched the gas.
> it idles.
Um, yes it does. Unless...
...you disenguage the engine from the wheels. Then there really isn't
any relationship. But as long as the car stays in the same gear, there
is a fixed relationship.
Date: 16 May 2008 16:30:35
Message: <482deeeb$1@news.povray.org>
Yes - *if* you can do things like compute 60/75 *mentally*. :-P And also
if you know how many yards there are in a mile, and all kinds of other
random stuff.
[I found myself wondering about this in the car on the way home.]
Now, if you have access to a *computer* - or even better, Google - then
yes, it becomes quite easy.
That's the number I arrived at too.
Google also tells me that 75 mph = 33 m/s. Which frankly seems really
damned fast. (!) I mean, my car is only, like, 4 m long or something...
That means the car covers almost 10x its own length in 1 second! o_O
No wonder hitting anything is an instant fatality...
