POV-Ray : Newsgroups : povray.newusers : Should Parsing really take that long? How to speed it up? Server Time
16 Jul 2025 03:22:50 EDT (-0400)
  Should Parsing really take that long? How to speed it up? (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Should Parsing really take that long? How to speed it up?
Date: 4 Dec 2015 15:50:00
Message: <web.5661fbadfb84f5bafcb4e70@news.povray.org>
> > Warning_Level=n  Allows you to turn off classes of warnings.
> > +WLn    Same as Warning_Level=n
I really do not know why, but +WL0 does still show the parsing error.
>> Regarding the file
>> 1) It is a nearly 10 MB .pov file.
>That's not a trivial scene, but I've seen .pov files four times that
>size parse in less than a minute. My current guess would be that your
>.pov file loads an excessive number of PNG files -- or, possibly more to
>the point, that it loads a reasonable number of PNG files an excessive
>number of times.
I went a step further and looked into the file.
#declare cube=pigment { image_map { png "povincludes/cube.png"} }
object { M_0
  matrix <
  0.7071472,  -5.718298E-05,  -0.7070668,
  4.944397E-05,  1,  -3.142396E-05,
  0.7070668,  -1.273882E-05,  0.7071472,
  94.1652,  8.476583,  -71.2338>
this Object repeats 30.000 times (!) with different numbers.
So back to the point that I want to speed things up.
Question 1: How should the file (scene?) look like when it contains a object
that is repeated 30.000 times at different locations to minimize parsing time.
Question 2: Rendering directly scales with my cpu cores. Parsing unfortunately
does not. If there is is no chance to change the file format and no chance to
switch to ssd. Is there anything that might help to improve the parsing
performance? (I tried running multiple instances of pov ray. That worked pretty
well!)
Date: 4 Dec 2015 16:04:39
Message: <5661ffe7$1@news.povray.org>
>>> Regarding the file
>> number of times.
> object { M_0
>    matrix <
Are you a developer or a user of the logistics program?
The Pov code need to be changed so that it defines a macro with
different variables.
I am not a programmer but I have been using programs that export Pov
code, for about 15 years. It is a problem with machine written code. :-(
It might use a macro or a loop. I am no coder. So others might be of
more help, here.
> well!)
There is functionality in WinPov to use a file Queue and if your
software exports each frame as a pov file. You could use that.
Help
1.5.7.6 File Queue dialog
But then as you are using less cores for each render it is a trade off
against Parsing and rendering.
Regards
Date: 4 Dec 2015 17:25:32
Message: <566212dc$1@news.povray.org>
Am 04.12.2015 um 21:46 schrieb ILM:
> object { M_0
>   matrix <
Does the "#declare cube=pigment ..." statement repeat as well?
That would be bad, and explain a lot.
As for the object itself, that looks about as good as it gets: The
object description actually references a "template" presumably defined
earlier (named M_0 in this case), with the matrix<...> statement
specifying the location and orientation of the respective copy by means
of a coordinate transformation matrix.
The "#declare cube=pigment ..." statement should be present only once
(for each distinct filename, that is); if that is indeed the case, then
there's not much more to optimize there either. If the statement is
repeated all around the place, then it's an indication that the author
of the generating software /tried/ to optimize the generated .pov file
but made some stupid blunder along the way. (As a matter of fact, the
very purpose of the "#declare" statement is to define templates for
various things to be referenced later, in this case some texture
property. You'll also find some "#declare M_0=..." somewhere, hopefully
in just one single place.)
Date: 4 Dec 2015 21:41:56
Message: <56624ef4$1@news.povray.org>
I'm not a developer, but it looks from the source code like this
particular message conditional calls the parser's PossibleError()
function instead of the Warning() function and so the message is not
controllable with the warning level mechanism.
Likely this is why Christoph said in an earlier post you'd have to
modify the input pov file to get rid of the message.
The parser seems to be set up with three message functions in Warning(),
PossibleError() and Error().
Bill P.
Date: 5 Dec 2015 02:25:01
Message: <web.566290d4fb84f5bafcb4e70@news.povray.org>
I am an user. Do you have any source on how to use/write macros in pov ray?
The complete part that I postet repeats 30.000 times. Including the #declare...
line.
In addition to this at the beginning of the document I can find the more general
definition you mentioned.
#declare M_0=
  mesh2 {
    #include "povincludes/M0c27c969_b190_4ad2_9fb3_0f1f068dc56b_VV.inc"
    #include "povincludes/M0c27c969_b190_4ad2_9fb3_0f1f068dc56b_NV.inc"
    #include "povincludes/M0c27c969_b190_4ad2_9fb3_0f1f068dc56b_UV.inc"
    texture_list { 1,
      texture { cube finish { ambient 1 diffuse 1 reflection 0 } }
    #include "povincludes/M0c27c969_b190_4ad2_9fb3_0f1f068dc56b_FI.inc"
    uv_mapping
object { M_0
  matrix <
  -9.091367E-06,  -3.256779E-05,  0.9999999,
  -3.532349E-06,  1,  3.256775E-05,
  -0.9999999,  -3.532056E-06,  -9.091482E-06,
  -12.64854,  10.48967,  -33.32481>
I edited the pov file in a text editor and removed the extra 30.000 declare
lines. Unfortunately that did not reduce the parsing time.
Furthermore I tried the following:
- Changed the png file to a 1x1 px file. Parsing now only takes 40 seconds.
- Changed the png file to a 1x1 px file AND removed the 30.000 declare lines.
parsing now takes about 15 seconds.
So we found the spot where we have to apply the tweaking.
Something I can do by myself: Use smaller PNG file (even they are not really big
actually).
The big question is: How can we (or better said the developer) optimize the
loading of png files. Only removing the declare line has not changed a lot.
Date: 5 Dec 2015 09:21:22
Message: <5662f2e2$1@news.povray.org>
> actually).
I've not spent much time in the internals of the mesh2 object as these
are usually program generated and I just use them, but one thing which
seems odd is the finish statement being inside the texture_list ->
texture block. I'd expect code more like:
#declare Tcube=texture {
pigment { image_map { png "povincludes/cube.png" } }
#declare M_0=
   mesh2 {
     texture_list { 1,
       texture { Tcube }
     uv_mapping
// Then 30 thousand positioned copies of the object
object { M_0 matrix <...> }
A guess, but wondering if due the finish block being inside the texture
block of the texture list, whether povray isn't creating many internal
textures for each face/vertice of the mesh instead of referencing just one.
As for macros, there is documentation at:
http://www.povray.org/documentation/3.7.0/r3_3.html#r3_3_2_8 for a start.
Bill P.
Date: 5 Dec 2015 11:12:38
Message: <56630cf6$1@news.povray.org>
>> declare
>> seconds.
>> lines.
>> really big
>> actually).
>> optimize the
>> lot.
> Bill P.
There is absolutely nothing wrong with the finish block as it is. In
fact, it could have been included in the #declare as follow for the
exact same end result:
#declare cube=texture { image_map { png "povincludes/cube.png"} finish {
The real problem is that #declare cube=pigment { image_map { png
"povincludes/cube.png"} } is repeated 30000 times. It's probably the
case for all image_map that are used.
As for the parsing time not scalling with multiple cores, it's that the
parsing is strictly linear and only support a single thread. In
contrast, the rendering is multi threaded and can use all the available
cores, up to 256 if I remember correctly.
Date: 6 Dec 2015 07:11:30
Message: <566425f2$1@news.povray.org>
Am 05.12.2015 um 08:23 schrieb ILM:
Are you absolutely, positively sure you removed all the 30.000 "#declare
cube=pigment { ... }" lines (except the first one of course)?
That would be a very odd finding.
Obviously, what bogs down the parsing of your scene has something to do
with the handling of PNG -- more specifically, the handling of the
image's actual data.
One of the most time-consuming operations in handling image file data
would typically be the process of getting it from disk into memory. This
is something POV-Ray does at the very moment it encounters the
"image_map { png ... }" statement. Having a lot fewer of those
statements /should/ have /some/ effect on parsing time.
If that is not the case /at all/, we'd have to conclude that some other
"expensive" stuff happens with the image data further down the line; the
only thing that would make sense there would be that the 30,000-fold
duplication of the declared object might also duplicate the texture list
each time, which in turn might duplicate the texture, which in turn
might duplicate the pigment, which in turn might duplicate the
image_map, which in turn might duplicate the image.
In fact the duplication of a mesh2 object /does/ duplicate the texture
list, which in turn /does/ duplicate the texture, which in turn /does/
duplicate the pigment, which in turn /does/ diplicate the image_map.
But here's where it stops: When an image_map is duplicated, this does
/not/ copy the image data; it simply copies a pointer to the actual
image data.
Thus, the overhead of all the duplication should be constant with
regards to the image size; whether the image is 1x1 pixels or
10,000x10,000 pixels in size should have no effect whatsoever on the
time it takes to duplicate those 30,000 mesh2 objects.
I'll do a few tests to see whether I'm overlooking something about the
mechanism behind image_map duplication, but at the moment the hypothesis
that makes most sense to me is that you made some trivial mistake when
testing with the 30,000 "#declare cube=..." lines removed, such as using
an external editor to make the change and forgetting to save before
rendering.
Date: 6 Dec 2015 07:54:44
Message: <56643014$1@news.povray.org>
>>> declare
>>> seconds.
>>> lines.
>>> really big
>>> actually).
>>> optimize the
>>> lot.
>> one.
>> Bill P.
> Alain
Thanks Alain,
I didn't have a large mesh2 handy with which to test. I again think you
and Christoph are correct in that :
Before posting yesterday I'd created a test scene in my own space with
30K+ lines of declares as ILM posted with a PNG file of 30K bytes in
size I just grabbed. My parse time increased about 25 seconds which put
it more or less in line with what ILM reported at a 35 seconds decrease
for deleting the duplicate declare lines in his 1x1 set of pix test.
This test led me to believe ILM's result that the removing the duplicate
lines changed little even with his original PNGs.
This morning I looked at the PNG I grabbed for my 30K declare experiment
and it turned out to be only 160x120 pixels... I scaled this PNG up to
1600x1600 and re-ran and the parse time jumped to 14 minutes even using
a memory disk. So, the thousands of duplicate declares absolutely can
drive large parse times if the PNG files are larger as you and Christoph
have suggested.
Let's see... 160x120 & 30K declares at 25sec we get 0.013 sec/pixel.
1600x1600 & 30K declares at 820sec we get 0.0003sec/pixel so nothing
wrong in the direction that is scaling with larger PNGs either.
Bill P.
Date: 6 Dec 2015 08:38:12
Message: <56643a44$1@news.povray.org>
Am 06.12.2015 um 13:11 schrieb clipka:
BTW, did you still get spammed with the PNG-related warning message in
the test where you only (thought to have) removed the 30,000 declare
lines and left the image size unchanged?
Because that would indeed indicate that the lines had not been removed.
That message absolutely, positively show /only/ whenever an "image_map
{...}" statement is encountered, /not/ when an image_map is duplicated
internally.
