POV-Ray : Newsgroups : povray.newusers : Problem with transparency (3D crafter) Server Time
18 Dec 2025 01:14:13 EST (-0500)
  Problem with transparency (3D crafter) (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Problem with transparency (3D crafter)
Date: 11 Sep 2012 05:20:00
Message: <web.504eff7abea76107dcab64f60@news.povray.org>
"StephenS" <nomail@nomail> wrote:
> "Vadim" <nomail@nomail> wrote:
> > Where can I insert a comment? In 3D Crafter using visual basic.
> Are you useing the free version, or Pro version?
> If running the render from POV-Ray is ok, you can create a second file with the
> needed changes, and also call the first (3dcrafter) generated file.
> example:
> #include "My_3dcrafter_file.pov"
> global_settings{ max_trace_level 25 }
> Stephen S
How? 3d Crafter renders a lot of shots one after the other, when it records the
animation. This occurs in the 3d Crafter interface.
Is it possible to set this option from the command line in the render settings?
And another: 3d Crafter does not use a lot of opportunities Pov-ray. Do not tell
me how to set the parameters in 3D Crafter for rendering using Pov-Ray. Maybe
with VB-scripts ...
Date: 11 Sep 2012 05:55:01
Message: <web.504f0a21bea761076cfdcbd50@news.povray.org>
> with VB-scripts ...
I'm not familiar with the plugin system of 3dCrafter or VB-scripts, sorry.
Stephen S
Date: 11 Sep 2012 06:54:17
Message: <504f1859@news.povray.org>
> records the animation. This occurs in the 3d Crafter interface. Is it
> settings?
> Do not tell me how to set the parameters in 3D Crafter for rendering
> using Pov-Ray. Maybe with VB-scripts ...
   I guess you should be asking this on 3DCrafter forums or support:
figuring out a solution for your problems may require some knowledge on
how 3DCrafter works. After a quick reading of a tutorial I found on the
web, I'm guessing the process is totally blind when you raytrace
directly from within 3DCrafter, but perhaps there are some internal
templates that you can modify... look into your 3DCrafter program files
to see if you can locate these (with some luck, the will be .pov or .inc
files).
Jaime
Date: 11 Sep 2012 07:10:00
Message: <web.504f1b0ebea76107dcab64f60@news.povray.org>
> > with VB-scripts ...
> Stephen S
It's okay. Thanks for everything. It is bad that 3D Crafter does not support own
forum.
Date: 11 Sep 2012 07:22:17
Message: <504f1ee9$1@news.povray.org>
>>> with VB-scripts ...
>> Stephen S
> forum.
   Then I got wrong which 3DCrafter you are referring to?
   http://amabilis.com/?forum=3dc3dcrafter
Jaime
Date: 11 Sep 2012 07:45:01
Message: <web.504f2350bea76107dcab64f60@news.povray.org>
> >>> with VB-scripts ...
> >> Stephen S
> > forum.
> Jaime
I searched here:http://amabilis.com/forum/
Date: 11 Sep 2012 07:50:00
Message: <web.504f24afbea76107dcab64f60@news.povray.org>
> > settings?
> files).
> Jaime
You are right. But it uses a dll file type to export. I do not know how to
change them ...
Date: 11 Sep 2012 08:45:46
Message: <504f327a$1@news.povray.org>
>> files).
> change them ...
In the worst situation, assuming the generated pov-scene does include at
least one standard include from the povray distribution, (and assuming
that the max_trace_level is not redefine later in the generated files),
you could :
 1. identify one such include file (as "colors.inc" for instance ?)
 2. Blasphemy: edit the colors.inc file to add the "global_setting{
max_trace_level .... "
Date: 11 Sep 2012 08:51:59
Message: <504f33ef$1@news.povray.org>
   Brilliant workaround, even if it's a bit of a heresy... ;)
Jaime
Date: 11 Sep 2012 09:15:01
Message: <web.504f384fbea76107dcab64f60@news.povray.org>
> >> files).
> > change them ...
> you could :
Thank you. This is good advice.
