Subject: Re: Problem with transparency (3D crafter)
Date: 11 Sep 2012 06:54:17
Message: <504f1859@news.povray.org>
On 11/09/12 11:08, Vadim wrote:
> How? 3d Crafter renders a lot of shots one after the other, when it
> records the animation. This occurs in the 3d Crafter interface. Is it
> possible to set this option from the command line in the render
> settings?
> And another: 3d Crafter does not use a lot of opportunities Pov-ray.
> Do not tell me how to set the parameters in 3D Crafter for rendering
> using Pov-Ray. Maybe with VB-scripts ...
I guess you should be asking this on 3DCrafter forums or support:
figuring out a solution for your problems may require some knowledge on
how 3DCrafter works. After a quick reading of a tutorial I found on the
web, I'm guessing the process is totally blind when you raytrace
directly from within 3DCrafter, but perhaps there are some internal
templates that you can modify... look into your 3DCrafter program files
to see if you can locate these (with some luck, the will be .pov or .inc
files).
Jaime
"StephenS" <nomail@nomail> wrote:
> "Vadim" <nomail@nomail> wrote:
> > How? 3d Crafter renders a lot of shots one after the other, when it records the
> > Is it possible to set this option from the command line in the render settings?
> > And another: 3d Crafter does not use a lot of opportunities Pov-ray. Do not tell
> > me how to set the parameters in 3D Crafter for rendering using Pov-Ray. Maybe
> > with VB-scripts ...
> I'm not familiar with the plugin system of 3dCrafter or VB-scripts, sorry.
> Stephen S
It's okay. Thanks for everything. It is bad that 3D Crafter does not support own
forum.
Date: 11 Sep 2012 07:22:17
Message: <504f1ee9$1@news.povray.org>
>>> with VB-scripts ...
>> Stephen S
> forum.
Then I got wrong which 3DCrafter you are referring to?
http://amabilis.com/?forum=3dc3dcrafter
Jaime
> >>> with VB-scripts ...
> >> Stephen S
> > forum.
> Jaime
I searched here:http://amabilis.com/forum/
> > settings?
> files).
> Jaime
You are right. But it uses a dll file type to export. I do not know how to
change them ...
>> files).
> change them ...
In the worst situation, assuming the generated pov-scene does include at
least one standard include from the povray distribution, (and assuming
that the max_trace_level is not redefine later in the generated files),
you could :
1. identify one such include file (as "colors.inc" for instance ?)
2. Blasphemy: edit the colors.inc file to add the "global_setting{
max_trace_level .... "
Date: 11 Sep 2012 08:51:59
Message: <504f33ef$1@news.povray.org>
Brilliant workaround, even if it's a bit of a heresy... ;)
Jaime
> >> files).
> > change them ...
> you could :
Thank you. This is good advice.
