POV-Ray : Newsgroups : povray.newusers : Strange halo on reflections Server Time
2 Jul 2024 02:43:46 EDT (-0400)
  Strange halo on reflections (Message 11 to 16 of 16)
Subject: Re: Strange halo on reflections
Date: 13 Jul 2012 12:25:00
Message: <web.50004bb358f7bdbc130037650@news.povray.org>
I tried to use media but cant get it to work properly. Still when my xscan
paramter = 4 the reflection is too bright, it should be much weaker than when
xscan = 3. Here is how i modified the absorber object. The only other change I
made was to the photons global setting where i added "media 100". Am i doing
something wrong?
object{
box
   <-extent,-extent,t_st> <extent,extent,t_st+t_abs>
   hollow
   pigment{rgbt 1}
   finish
     reflection{0,1 fresnel}
     conserve_energy
   interior{ior cmt_ior fade_distance cmt_abs fade_power 1000
       media{
        absorption <1,1,1>
        intervals 3
        samples 1,1         }
   PhotonTarget(no, yes, yes, yes)
> > Thanks for looking in to this clipka,
> > can you explain a little more about how i could use media as a workaround?
> > also, is the bug regarding TIR easy to explain? I will be relying on TIR in my
> > scenes which will have different angles than those in the code I included in my
> > earlier message. If it might go wrong its useful to know before so I can keep an
> > eye out for problems
> > stu
> > clipka <ano### [at] anonymousorg> wrote:
> >> Examining your problem, I did indeed find a bug in the handling of the
> >> interior fade feature (wrong interior being applied under certain
> >> circumstances), which I suspect to be relevant in your case. (I also
> >> found a flaw regarding total internal reflections, but so far I did not
> >> manage to come up with a situation where it would manifest as a bug, so
> >> that one can probably be ruled out.)
> >> The interior fade bug is also present in POV-Ray 3.6.2, so I don't think
> >> it will be fixed in POV-Ray 3.7.0 release proper.
> >> One possible workaround might be to use media instead.
> You add "hollow" to the object. This enable the object to contain a media.
> Next, in the interior block, you add
> media{absorbtion Colour}
> If you want to let the red pass but absorb the green and blue, you need
> {absorbtion <0,1,1>}
> If you also use fade_dolor Colour, use <1,1,1>-Colour for the media.
> Alain
Date: 13 Jul 2012 14:33:32
Message: <500069fc$1@news.povray.org>
Am 13.07.2012 18:24, schrieb Crippso:
> something wrong?
The "media" keyword in the global photons block is irrelevant for your
case; it is intended for scattering media.
> object{
(BTW, while wrapping your "box" in an "object" statement doesn't hurt,
it's totally unnecessary; you need "object" only when you have
#declare'd an object and want to add it to the scene.)
> box
>     hollow
>     pigment{rgbt 1}
>     finish
>       conserve_energy
Remove the "fade_distance" and "fade_power" statements; after all,
you're trying to replace them with media.
>         media{
>          absorption <1,1,1>
You may need to increase absorption; note that its parameter is not
limited to the range [0..1].
Theoretically, you should set:
     absorption = <1,1,1> / cmt_abs
to get the same results as you'd get with properly computed fade.
>          intervals 3
>          samples 1,1         }
Remove the "intervals" and "samples" statements; the default values
should be perfectly fine for uniform media as in your case.
Date: 13 Jul 2012 18:40:01
Message: <web.5000a30658f7bdbc130037650@news.povray.org>
I tried to include these changes but didn't get the right results.
if i put xscan=0, i have the simple case of photons travelling through the
absorber and reflected back through it, always in the z direction. Using your
media approach i dont seem to be able to change the brightness of the reflected
scene by changing cmt_abs paramter. I also noticed if i set cmt_abs = 0 there is
no error flagged up because of the divide by zero!
> > something wrong?
> > object{
> > box
> >     hollow
> >     pigment{rgbt 1}
> >     finish
> >       conserve_energy
> >         media{
> >          absorption <1,1,1>
> >          intervals 3
> >          samples 1,1         }
Date: 13 Jul 2012 18:55:01
Message: <web.5000a6e858f7bdbc130037650@news.povray.org>
ah, it looks like i need to make other objects hollow too
> > > something wrong?
> > > object{
> > > box
> > >     hollow
> > >     pigment{rgbt 1}
> > >     finish
> > >       conserve_energy
> > >         media{
> > >          absorption <1,1,1>
> > >          intervals 3
> > >          samples 1,1         }
Date: 13 Jul 2012 21:04:53
Message: <5000c5b5$1@news.povray.org>
> something wrong?
> object{
> box
>     hollow
>     pigment{rgbt 1}
>     finish
>       conserve_energy
>         media{
>          absorption <1,1,1>
>          intervals 3
With the default sampling method, intervals MUST stay at it's default of
1. Changing it only make the render MUCH slower.
If you need more samples, increase the samples count.
>          samples 1,1         }
Also, with the default sampling method, samples should be at least 3
defaulting to 10.
There is only a single samples value used, the second is always silently
ignored.
This is a NOP statement. It set NOT a photons target, the default state.
The refraction and reflection switches are only relevent IF the object
is a target. Collect on is the default.
ANY reflective or refractive object that receive secondary photons WILL
reflect or refract them.
Date: 13 Jul 2012 22:10:14
Message: <5000d506@news.povray.org>
Am 14.07.2012 03:05, schrieb Alain:
>>         media{
>>          absorption <1,1,1>
>>          intervals 3
You make it sound like any non-default value would cause the computer to
explode :-)
Then again, yes - it /does/ cause /rendering times/ to explode :-P
