POV-Ray : Newsgroups : povray.newusers : Gamma Settings Server Time
18 Nov 2025 18:51:12 EST (-0500)
  Gamma Settings (Message 1 to 10 of 22)
Subject: Gamma Settings
Date: 29 Feb 2012 22:15:00
Message: <web.4f4ee94b37a403b5345179960@news.povray.org>
Hello,
I am new to POV-Ray and have just upgraded from POV-Ray 6 to POV-Ray 7. I notice
now that all my renders seem too bright. As an extreme example: if I render a
simple sphere over a flat plane in a scene that has no light sources, I can
clearly see both the sphere and the plane (although somewhat dimmed). With
version 6 I believe a scene with no light sources would render completely black,
which I think is correct for a scene with no lights. <-(is this a correct
assumption?)
I read that there were some changes made to Gamma settings in version 7? How do
I get it back to normal?
Thanks!
-James
Subject: Re: Gamma Settings
Date: 29 Feb 2012 22:25:00
Message: <web.4f4eeb30e3adea41345179960@news.povray.org>
Sorry, I meant version 3.6 to 3.7
"JamesB7271" <nomail@nomail> wrote:
> Hello,
> assumption?)
> Thanks!
> -James
Date: 1 Mar 2012 01:20:39
Message: <4f4f1537@news.povray.org>
JamesB7271 <nomail@nomail> wrote:
> With
> assumption?)
  No, because the default ambient term of lighting is not zero. (If you set
it to zero then it would be so.)
  Are you explicitly specifying "#version 3.7"? Because that turns on the
new gamma correction scheme, but you should also get a warning that you
should also explicitly specify an "assumed_gamma" in your global settings.
  If you don't explicitly specify "#version 3.7" then the old gamma scheme
is assumed by default.
Date: 1 Mar 2012 10:56:24
Message: <4f4f9c28@news.povray.org>
Am 01.03.2012 04:13, schrieb JamesB7271:
> Hello,
> which I think is correct for a scene with no lights.<-(is this a correct
> assumption?)
(Just for the records: I tend to become somewhat itchy when people refer
to the 3.6 or even 3.5 gamma handling as "normal", because it isn't -
it's obsolete, with POV-Ray 3.7's default gamma handling being far
superior.)
There are multiple ways of achieving what you're asking for, the
simplest being to tell POV-Ray that your scene was designed for POV-Ray
3.6; just insert the following line at the beginning of your scene file:
     #version 3.6;
POV-Ray 3.7 will then (among other things) automatically switch to a
gamma handling mode that is backward compatible with POV-Ray 3.6 (with
minor exceptions relating to PNG input images).
In addition, if you explicitly specify "Display_Gamma" somwehere in your
.ini files, you also need to set "File_Gamma" to the same value (unless
you're using PNG, OpenEXR or Radiance HDR as output format).
If you do not specify "Display_Gamma", you may still see slight
differences in dark image regions; if you consider that a problem,
explicitly specify "Display_Gamma=2.2" and "File_Gamma=2.2" to iron
those out.
Alternatively, specifying "assumed_gamma srgb" will give you essentially
the same gamma-related behaviour as POV-Ray 3.5 (or POV-Ray 3.6 without
any "assumed_gamma" statement), except for gamma handling of any input
images.
If your scenes already contain an "assumed_gamma" statement, gamma
handling in 3.7 /should/ automatically be essentially the same (again
except for input images), and your observed changes should be a no-issue.
In both cases, the aforementioned advice for "Display_Gamma" and
"File_Gamma" also applies.
I hope this helps. For future scenes, if realism is of any concern to
you I strongly recommend using "#version 3.7" and "assumed_gamma 1.0",
leaving "File_Gamma" at its default, and using the new "srgb" family of
color keywords instead of "rgb" to specify colors taken from external
applications.
Date: 4 Mar 2012 18:30:01
Message: <web.4f53fa01e3adea41345179960@news.povray.org>
> > Hello,
> > assumption?)
> superior.)
>      #version 3.6;
> those out.
> images.
> applications.
Thank you so much for the detailed response. I of course want the most realism,
so I do want to make sure I'm getting started right.
Below is a simple sample scene (partly from the tutorials). If I render it as
shown below, it looks too bright and washed out to me. However, if I change the
"#version" statement to 3.6, or change the "assumed_gamma" statement from 1.0 to
srgb, the scene seems to look more realistic. Can you try it and give me your
opinion? If the new 3.7 gamma handling is the correct and more accurate method,
then I think I may be doing something else wrong?
#version 3.7
global_settings {
 assumed_gamma 1.0
#include "stones.inc"
  location <0, 3, -4>
  look_at <0, 1, 2>
sphere {
  <0, 1, 2>, 2
    pigment {color Yellow}
plane { <0, 1, 0>, -1
  texture {T_Stone25
light_source {
 <2, 10, -3>
 color White
 area_light <5, 0, 0>, <0, 0, 5>, 5, 5
   adaptive 1
   jitter
Date: 4 Mar 2012 20:41:25
Message: <4f5419c5@news.povray.org>
Am 05.03.2012 00:25, schrieb JamesB7271:
In that case, assumed_gamma 1.0 is /definitely/ the thing you want.
I personally find nothing wrong with the scene you provided, when
rendered with POV-Ray 3.7 and "assumed_gamma 1.0"; to the contrary, I
find the result of "assumed_gamma srgb" unrealistically (and
undesirably) dark.
Essentially, there are three possible reasons why you might think the
image is too bright:
(1) The image as computed by POV-Ray might be fine, but what you see is
not what POV-Ray computed, because your system's display pipeline (i.e.
Windows color management settings, graphics driver settings, graphics
card and display hardware properties) and/or the image viewing software
might introduce some "color distortions" that POV-Ray isn't aware of.
POV-Ray 3.7 comes with a sample scene named
"scenes/gamma/gamma_showcase.pov" which is specially tailored for
identifying this type of problem.
Make sure your Windows screen settings are configured to use your
display's native resolution. Render the scene at 640x480 resolution and
display it at 1:1 zoom; from a distance, the left and right hemispheres
of each sphere in the image should look uniform in color, saturation and
brightness. (Close inspection of the image however will reveal that most
of them are not: The right hemispheres are actually striped
horizontally; that's perfectly intentional.)
If on your system the left hemisphere of each sphere appears
significantly brighter and/or more washed-out, fixing your display
settings (black-/whitepoint and gamma) might solve your problems; you
can find plenty of sites on the Interwebs to help you with this.
(2) The colors in the scene might simply /be/ brighter and more washed
out than you'd like them to be. In that case, try...
... choosing more saturated colors (might be difficult for the yellow
ball, but you can probably do something about the marble floor; a good
bet might be using "srgb" wherever the material currently uses "rgb";
you might need to copy the materials from the default .ini files for this);
... reducing the global_settings { ambient_light ... } parameter
(default is 1.0) and/or your materials' finish { ambient ... } setting;
especially the latter is typically quite high in old materials, as they
were designed to look good with the de-facto too dark image results as
computed by POV-Ray 3.5 (or 3.6 with default settings); better yet, use
radiosity (with 3.7, this will automatically turn off the ambient
mechanism);
... using fade_distance and fade_power for a realistic distance-based
fading of the light. (Rule of thumb: Set fade_power to 2, set
fade_distance to the size of your area light, and increase (or in rare
cases decrease) light intensity to achieve the desired overall
brightness level. (Don't be surprised if you need to set the nominal
brightness of the light source to some pretty high value.)
(3) You might have become so accustomed to 3.5's rather dark results
with deep shadows that the old look feels more realistic to you than it
actually is. In that case you'll need to either get used to realistic
renders again, or abandon realism and go for artistic freedom instead.
 From a distance I can't tell which of the three is the case (and I
wouldn't be surprised if it's actually a combination of all three of
them), so - as I already mentioned - you should first check your display
settings.
Date: 5 Mar 2012 12:44:45
Message: <4f54fb8d@news.povray.org>
  The thing about assumed_gamma 1.0 is that while it may produce more
physically correct results in terms of lighting calculations, it's
unintuitive with respect to defining colors. For instance, with that
assumed_gamma something like "color 0.5" will *not* be 50% gray (instead
being something like 73% gray IIRC). The reasons for this are complicated.
(Basically, it's the difference between radiant energy and the brightness
perceived by the human eye.)
  If you want to, for example, specify 50% gray, you have to indeed use
the 'srgb' keyword (in other words, define your color as "srgb 0.5").
  It becomes a bit more problematic when you are not defining the colors
yourself, but are using a pre-defined texture (eg. from an include file).
Now, I don't remember if something was added to POV-Ray 3.7 to "convert"
such a pre-defined texture into 'srgb' on the fly.
  Another problem is that currently there's no way to define linear
gradients that would remain linear regardless of assumed_gamma (in other
words, if you define assumed_gamma 1.0, your gradients will not look
linear). Some work will be done in the future to remedy these shortcomings.
Date: 5 Mar 2012 14:32:28
Message: <4f5514cc$1@news.povray.org>
Am 05.03.2012 18:44, schrieb Warp:
That's only true if you define colors the old way, using "rgb" rather
than the new "srgb". With POV-Ray 3.7, it's not a matter of which
assumed_gamma setting gives you a more intuitive way to specify colors,
but a matter of choosing between intuitive ("srgb") and physical ("rgb")
colors.
Fun fact: "srgb" does take into account what assumed_gamma you choose,
so e.g. "srgb <0.1,0.5,1.0>" gives the same hue regardless of that setting.
You remember correctly. Though I'd phrase it differently: What is
/perceived/ as (and frequently labelled) "73% gray" actually corresponds
to a physical brightness of 50% (=0.5).
Which is exactly the reason why the "srgb" keyword was introduced.
No, indeed not. I guess the proper solution there is to overhaul the
standard include files to use "srgb" throughout.
I strongly disagree with you about the use of the term "linear gradient"
here. "linear-/looking/" would be a better choice of words, as from a
/physical/ perspective it's the "assumed_gamma 1.0" gradient that is linear.
It should also be noted that while "assumed_gamma 2.2" does give
superior-looking /brightness/ gradients, it gives poor results for
/color/ gradients ("assumed_gamma 1.0" gives very good results there),
so the issue of gradients does /not/ generally speak in favor of any
particular "assumed_gamma" setting. Instead, the results simply indicate
that what we really need is a much smarter handling of gradients.
Date: 5 Mar 2012 17:44:17
Message: <4f5541c1@news.povray.org>
> colors, but a matter of choosing between intuitive ("srgb") and
> physical ("rgb") colors.
Actually this now made me wonder if 3.7 should redefine the rgb
keyword to mean "intuitive colors" (srgb) and introduce a new keyword
for "physical colors" (prgb).
Color arithmetic could still be done in linear prgb space (unless the
user actually used vector arithmetic before converting to color).
The change in gamma handling would then come simultaneously with
a change in rgb interpretation that mostly cancels out for existing
scenes that already used assumed_gamma 1.0, reducing all the whining
about "my image is too washed out", and the new gamma handling could
be used without having to adapt all existing textures at once.
Or else (quite possibly) I completely misunderstood everything ;)
Date: 5 Mar 2012 18:11:17
Message: <4f554815$1@news.povray.org>
Am 05.03.2012 23:43, schrieb Christian Froeschlin:
It might make /some/ sense to add a kind of "prgb" keyword; the rgb
keyword actually means "physical colors" /only/ if assumed_gamma is set
to 1.0. This interpretation of "rgb" is backward compatible with 3.6.
Strictly speaking, POV-Ray 3.7 doesn't introduce a fully new gamma
handling concept at all; it just (1) obsoletes the 3.6 default of not
performing any gamma handling at all (in favor of "assumed_gamma 1.0"
mode; you can still get the 3.5 handling by specifying "assumed_gamma
srgb"), and (2) complements the 3.6 assumed_gamma-based handling with
some tools that were lacking in 3.6, especially to work with colors from
external sources - whether they are images (except for PNG, 3.6 provided
no way of gamma-adjusting input images that didn't happen to match the
assumed_gamma) or explicit color values.
Also note that if you don't explicitly specify a "#version" statement,
POV-Ray 3.7 /does/ warn you, so it's not like POV-Ray isn't giving
people any hints at all. (And with "#version 3.6" you do get the old
behaviour.)
