POV-Ray : Newsgroups : povray.newusers : Coordinates of an object Server Time
18 Nov 2025 18:37:05 EST (-0500)
  Coordinates of an object (Message 1 to 6 of 6)
Subject: Coordinates of an object
Date: 25 Feb 2012 12:30:06
Message: <web.4f491a128a22bea25643b5860@news.povray.org>
Hello!
I have made an object, say dodecahedron. I defined vertices, then faces and
finally the cell. Then I transform the cell to an object. And then I scaled and
rotated it. Is there a possibility to transform back changed object for
achieving its coordinates of vertices? If no, how I could do this
mathematically? Thanks.
Subject: Re: Coordinates of an object
Date: 25 Feb 2012 12:55:23
Message: <4f49208b@news.povray.org>
On 02/25/2012 12:27 PM, sniper wrote:
> Hello!
there are some functions that you can use: vtransform (i think) take a
look at descriptions in the docs AND in the distribution include file
(transform.inc) ... there's some good stuff in there ;-)
http://wiki.povray.org/content/Documentation:Reference_Section_7.5#transforms.inc
but usually most folks (not all) do scaling, rotating with the object at
<0,0,0> the place it ...
Date: 25 Feb 2012 13:28:22
Message: <4f492846@news.povray.org>
  You can #declare a 'transform' block identifier and then apply that
transformation to both an object and a point (using vtransform()).
Date: 25 Feb 2012 13:30:01
Message: <web.4f4927cf189521bc5643b5860@news.povray.org>
> > Hello!
Thank you for the answer. I have studied these references but it seems no
possibility to achieve the coordinates of vertices of an object.
I have another idea, but also need help in its realization. I have coordinates
of a dodecahedron and its centroid, say <x,y,z>, so i could calculate the
distance from a given point to the centroid. I want to scale the dodecahedron
twice and achieve new coordinates of the vertices of dodecahedron. So the
distance between centroid in <x,y,z> and a given new point increases also twice.
How I could specify the direction?
Date: 25 Feb 2012 14:05:00
Message: <web.4f49305b189521bc5643b5860@news.povray.org>
It works! Thank you all!
Date: 27 Feb 2012 18:52:56
Message: <4f4c1758@news.povray.org>
>>> Hello!
> of a dodecahedron and its centroid, say<x,y,z>, so i could calculate the
> distance between centroid in<x,y,z>  and a given new point increases also twice.
Whenever you scale any object, the distance between any 2 points will
change proportionately. So, if you do know the initial distance, then,
you can apply the same scaling to the distance.
If you know the original location of any point of any object that you
then scale, rotate or translate, you only need to apply the same
transformations to that point to get the new coordinates of that point.
