POV-Ray : Newsgroups : povray.newusers : transparent backlit colored gels Server Time
11 Oct 2025 05:30:38 EDT (-0400)
  transparent backlit colored gels (Message 1 to 10 of 11)
Subject: transparent backlit colored gels
Date: 21 Nov 2011 00:30:00
Message: <web.4ec9e15f2d98a05646dfc3530@news.povray.org>
I have overlapping blue and yellow transparent "gels". With one blue and the
other yellow I was expecting the overlapped region, when back-lit, to look green
from the front. Instead it is brownish color. I seem to have a reason to use
POV-Ray once every two years or so for the last 6 years but have not used media
or photons before. I made a simplified file that illustrates my scene issue.
I'd appreciate any help in getting two transparent colored gels to work. thanks
--George
_____________________
#include "textures.inc"
#include "shapes.inc"
#include "metals.inc"
#include "skies.inc"
   location <0, 1, -5>
   look_at <.5,.5,0>
light_source {< 0, 10, 10> color White }  //back
//light_source {< 0, 10,-10> color White  }  //front
sky_sphere {
      gradient y
      color_map {
        [ .4  color <.9,.9,.9>  ]
      scale 1000
     translate -1
//wall with opening
#declare wind_width = 3;
#declare wind_height =3;
#declare wind_depth = 1;
#declare wall =box {
                        <-200,-200,wind_depth/3>
                        <200,200,-wind_depth/3> };
#declare window_opening = box {<-5,-.5,wind_depth/2>
<wind_width-.5,wind_height, -wind_depth/2>}
#declare wall      = difference {
                      object {wall pigment {Cherry_Wood}}
                      object {window_opening }
wall
#declare color_filter_blue      =
    pigment { rgbf <0,0,1,.9> }
    finish {
        ambient 0
        diffuse 0
        reflection 0.5
#declare color_filter_yellow =
    pigment { rgbf <1,1,0,.9> }
    finish {
        ambient 0
        diffuse 0
        reflection 0.5
     #declare Blue_gel =
                        box {<0, 0,0 >  <1, 1,-.01 >
                        texture {color_filter_blue}
                          interior {
                                 media {
                                        absorption  Blue
                        photons{
                                target
                                reflection on
                                refraction on
      #declare Yellow_gel =
                        texture {color_filter_yellow}
                          interior {
                                 media {
                                        absorption  Blue
                        photons{
                                target
                                reflection on
                                refraction on
                        translate <.5,.5, -.5>}
Blue_gel
Yellow_gel
Subject: Re: transparent backlit colored gels
Date: 21 Nov 2011 02:50:17
Message: <4eca02b9$1@news.povray.org>
Am 21.11.2011 06:27, schrieb George White:
Is that your complete scene? Because when I render it I don't see
anything brownish where the two gels overlap.
Try giving the blue gel a slightly green-ish hue, say rgbf <0,0.2,1,.9>,
otherwise the combination of the two filters will let no light through
at all (<0,0,1>*<1,1,0> = <0,0,0>).
Date: 21 Nov 2011 03:15:53
Message: <4eca08b9$1@news.povray.org>
The boxes should be *hollow* in order for the media to show. Also, if
you want the media to show the gel's colour, do this, and switch off the
photons and the absorbtion for the time being. I think the brownish
colour comes from the way the light is treated in RL and in POV-Ray:
additive versus substractive?
      #declare Blue_gel =
                         box {<0, 0,0 >  <1, 1, -.01 > hollow
                         texture {pigment {rgbt 1}}
                           interior {
                                  media {
                                         //absorption  Blue
                                         scattering {1, <0,0,1>*1000}
                         /*photons{
                                 target
                                 reflection on
                                 refraction on
                         box {<0, 0,0 >  <1, 1,-.01 > hollow
                         texture {pigment{rgbt 1}}
                           interior {
                                  media {
                                         //absorption  Yellow
                                         scattering {1, <1,1,0>*1000}
                         /*photons{
                                 target
                                 reflection on
                                 refraction on
Blue_gel
Yellow_gel
Date: 21 Nov 2011 03:40:02
Message: <4eca0e62$1@news.povray.org>
...But this does what you want:
#declare Blue_gel =
   interior {
     media {
       scattering {1, <1,0,0>*1000}
   interior {
     media {
Blue_gel
Yellow_gel
Date: 21 Nov 2011 15:50:02
Message: <web.4ecab814f120d22746dfc3530@news.povray.org>
thank you
That looks exactly right when back lit! But to make it also look right when
front lit do I need to reduce the t component in the color vector and put back
some pigment color and reflectivity?
---George
Date: 22 Nov 2011 03:35:59
Message: <4ecb5eef$1@news.povray.org>
On 21-11-2011 21:44, George White wrote:
> thank you
You can try that, but without reflectivity. It does not add anything
here imo.
However, you still need to change media back to blue and yellow,
otherwise the gels will have the wrong colour:
#declare Blue_gel =
box {<0, 0, 0 >  <1, 1, -.01 > hollow
   texture {pigment {rgbt 1}} //make this for instance <0,0,1,0.9>
   interior {
     media {
box {<0, 0, 0 >  <1, 1,-.01 > hollow
   texture {pigment{rgbt 1}} //make this for instance <1,1,0,0.9>
   interior {
     media {
   translate <.5,.5, .5>
Date: 22 Nov 2011 13:55:01
Message: <web.4ecbeefcf120d22746dfc3530@news.povray.org>
I added in the pigment and still have something that looks very strange when
front lit. I am working on an animated sequence where I need the front and back
lit to both work.
_____________
   location <-0, 1, -5>
   look_at <.5,.5,0>
//light_source {< 0, 10, 10> color White }  //back
light_source {< 0, 10,-100> color White  }  //front
sky_sphere {
      gradient y
      color_map {
      scale 1000
     translate -1
//wall with opening
wall
#declare Blue_gel =
   texture {pigment {rgbt <0,0,1,1>
//       finish { reflection rgb 1 }
   interior {
     media {
   texture {pigment{rgbt  <1,1,0,1>
   interior {
     media {
Blue_gel
Yellow_gel
Date: 23 Nov 2011 03:59:55
Message: <4eccb60b$1@news.povray.org>
> lit to both work.
I see what you mean. I have no ready solution for you unfortunately.
This is a bit beyond my own understanding :-(
[calling: Somebody else out there who knows?]
Date: 23 Nov 2011 08:13:45
Message: <4eccf189@news.povray.org>
> lit to both work.
I think the problem is that you are mixing additive and subtractive
colour systems. If you want the overlap to be green try using Cyan
instead of blue.
#declare Cyan_Material0 =
material{
       colour rgbft <0.000,1.000,1.000,0.750,0.200>
     finish {
       ambient     rgb <0.000,0.000,0.000>
       brilliance  1.000
       crand       0.000
       diffuse     0.600
       metallic    0.000
       phong       0.000
       phong_size  40.000
       specular    0.000
       roughness   0.050
       reflection {
         rgb <0.000,0.000,0.000>, rgb <0.000,0.125,0.125>
         fresnel   0
         falloff   0.000
         exponent  1.000
         metallic  0.000
#declare Yellow_Material0 =
material{
       colour rgbft <1.000,1.000,0.100,0.750,0.200>
     finish {
       ambient     rgb <0.133,0.133,0.000>
       brilliance  1.000
       crand       0.000
       diffuse     0.600
       metallic    0.000
       phong       0.000
       phong_size  40.000
       specular    0.000
       roughness   0.050
       reflection {
         rgb <0.000,0.000,0.000>, rgb <0.100,0.100,0.010>
         fresnel   0
         falloff   0.000
         exponent  1.000
         metallic  0.000
Regards
Date: 24 Nov 2011 13:50:01
Message: <web.4ece91b1f120d22746dfc3530@news.povray.org>
Stephen,
Thanks very much. Blue and Yellow gels make black. Cyan and Yellow gels make
green.
--George
