POV-Ray : Newsgroups : povray.newusers : caterpillar/cam belt Server Time
18 Nov 2025 20:04:55 EST (-0500)
  caterpillar/cam belt (Message 1 to 10 of 15)
Subject: caterpillar/cam belt
Date: 3 Jun 2011 03:50:00
Message: <web.4de8918cca2e9f0ac0abfa3e0@news.povray.org>
Hi all
I am trying to draw a simple small-to-large gear mechanism, driven by a cam
belt.
I have trawled the web, modified what I found and got so far with the gear:
#version 3.6;
global_settings {  assumed_gamma 1.3 }
global_settings { max_trace_level 10 }//(1...20) [default = 5]
#include "textures.inc"
#include "golds.inc"
#include "metals.inc"
// camera ------------------------------------------------------------------
        location <-5, 7, -10>
    look_at <0, -0, 0>
    angle 30
// sun ---------------------------------------------------------------------
light_source{< 1500,2500,- 3500> color White}
// sky ---------------------------------------------------------------------
sky_sphere { pigment {
                       color  rgb <1.0,1.0,1.0>
                     } // end of pigment
           } //end of skysphere
// fog ---------------------------------------------------------------------
fog{fog_type   2
    distance   50
    color      White
    fog_offset 0.1
    fog_alt    2.0
    turbulence 0.8}
//---------------------------- objects in scene ----------------------------
#macro Gear (Cog_Number, Cog_Distance, Gear_Z) // around the y axis
#local D = 0.0001;
#local Gear_Circumference = Cog_Distance*Cog_Number;
#local Gear_Radius_ = Gear_Circumference/(2*pi);
union{
 // kernel of the gear minus notches
difference{
 cylinder { <0,0,0>,<0,Gear_Z,0>,Gear_Radius_
           scale <1,1,1> rotate<0,0,0> translate<0,0,0>
         } // end of cylinder
cylinder { <0,-0.05,0>,<0,Gear_Z+0.05,0>,Gear_Radius_/5
 #local Nr = 0;     // start
 #local EndNr = Cog_Number; // end
 #while (Nr< EndNr)
    cylinder { <0,0-D,0>,<0,Gear_Z+D,0>,Cog_Distance/4
               scale<1.5,1,1>
               translate<Gear_Radius_,0,0>
               rotate<0,(Nr+0.5) * 360/EndNr,0>
               } // end of cylinder -----------------------------------
 #local Nr = Nr + 1;    // next Nr
 #end // ---------------  end of loop
          } // end of difference ---------------
 // adding the cogs
 #while (Nr< EndNr)
    cylinder { <0,0,0>,<0,Gear_Z,0>,Cog_Distance/4
               scale<1.3,1,1>
               rotate<0,Nr * 360/EndNr,0>
difference {
cylinder { <0,0,0>,<0,Gear_Z*2,0>,Gear_Radius_*0.8
cylinder { <0,-0.05,0>,<0,(Gear_Z*2)+0.05,0>,Gear_Radius_/5
torus { Gear_Radius_*1.595,Gear_Radius_*0.8
         scale <1,0.5,1> translate<0,Gear_Z*2,0>
       } // end of torus  -------------------------------
difference {
cylinder { <0,-0.05,0>,<0,0,0>,Gear_Radius_*1.15
cylinder { <0,-0.05-D,0>,<0,0+D,0>,Gear_Radius_/5
difference {
cylinder { <0,Gear_Z,0>,<0,Gear_Z+0.05,0>,Gear_Radius_*1.15
cylinder { <0,Gear_Z-D,0>,<0,Gear_Z+0.05+D,0>,Gear_Radius_/5
} #end // end of union and end of macro -------------------------------
#macro Gear_Radius (Cog_Number, Cog_Distance)  //----------------------
  Cog_Distance*Cog_Number/(2*pi)
#end //----------------------------------------------------------------
union{
object{ Gear ( 36, 0.15, 0.5)
        texture { T_Silver_4C
                  finish { ambient 0.15 diffuse 0.85 phong 0.5 reflection 0.40}
                } // end of texture
        rotate<0,0,0>
        rotate<0,0,-clock*360/36>
        translate<0,1,0>} // end of cog 1
 rotate<0,0,0>
 rotate<0,0,0>
 translate<0,0,0>
 scale <0, 0, 0>
However, I have no idea how I am going to draw the cam belt which will link this
gear with another larger one. I can sort out distances and sizes of the gears,
no problem, but the belt I have no idea.
To add to this, I need the belt to at least appear to be moving as the gears
move. Is this possible?
Any help would be great!!!!
Subject: Re: caterpillar/cam belt
Date: 3 Jun 2011 20:08:34
Message: <4de97782@news.povray.org>
Regarding the basic geometry, I think you are looking for
the "common tangent for two circles" problem, which is slightly
more tedious to solve than I initially thought, see e.g.
http://www.cut-the-knot.org/Curriculum/Geometry/TangentTwoCirclesI.shtml
http://www.askiitians.com/iit-jee-coordinate-geometry/common-tangents.aspx
http://www.phpfreaks.com/forums/index.php?topic=189971.0
With such points you can make a very simple model using two boxes
for the straight part and two cylinder shells (differences) from which
you cut out an angled wedge (cylinder intersected with 2 planes?).
Once you get that working then you can start worrying how the belt
should be constructed physically and how it fits with cogs.
Date: 4 Jun 2011 05:41:15
Message: <4de9fdbb@news.povray.org>
On 03/06/2011 8:47 AM, Tops wrote:
> Hi all
> belt.
One of the good things about these sorts of animations is that you do
not need to animate a complete cycle of the belt. You can just render
the portion that repeats. For instance the animation below has only 90
frames.
I made it using a modeller (Bishop3D) so there are no macros and I had
to place some of the chain links manually.
The scene splits into two parts:
1.	Links that move in a regular way, either translation or rotation.
2.	Links that move partly in a regular way then change movement from a
translation to a rotation or vice versa.
There were six segments of links. Two moving between the gears, two
moving round the gears, one moving round then coming off and the other
moving to then going round a gear wheel.
I hope this hint helps and I can make the Bishop3D file available.
Gear Chain
http://www.youtube.com/watch?v=urX5kI-5e4E
Used in a longer animation
http://www.youtube.com/watch?v=VfVRnAHu4JI
Regards
Date: 6 Jun 2011 04:05:01
Message: <web.4dec89c25b05cb15c0abfa3e0@news.povray.org>
> > Hi all
> > belt.
> frames.
> Gear Chain
> Regards
>      Stephen
Wow, that looks amazing!!!!!
Yes, please, I would like access to the Bishop3D file (or something similar that
will help me!) as this is far too advanced for me at the moment.
Many many thanks
Tops
Date: 6 Jun 2011 11:40:01
Message: <web.4decf4975b05cb15c0abfa3e0@news.povray.org>
That looks great!
Yes, please, I would like to see your Bishop3D thing, as this is way too
Your short animation is exactly the kind of thing I would like to do!
Many thanks
Tops
Ps. Sorry if this message appears twice, but I tried to post something similar
this morning but it doesn't appear to have worked!
Date: 6 Jun 2011 11:42:48
Message: <4decf578$1@news.povray.org>
Thank you.
I originally uploaded the file to Geocities but since that had joined
the Choir Celestial I will tidy up the scene and upload it to the
Bishop3D site and post the link. Bishop3D is not free (I believe it
costs 50 Euros) but you can download an evaluation copy. IIRC it will
only save scenes with 20 objects so you will not be able to modify the
scene and save it as it has > 600 objects.
> Many many thanks
My pleasure. :-)
Regards
Date: 6 Jun 2011 11:45:00
Message: <web.4decf5385b05cb15c0abfa3e0@news.povray.org>
Hi Stephen
That looks great!
Many thanks
Tops
Ps. Sorry if this message appears three times, but I tried to post something
similar this morning and again just now but it doesn't appear to have worked! (I
think it's because I replied to your individual message and not my thread, but I
don't know)
Date: 6 Jun 2011 12:28:28
Message: <4ded002c$1@news.povray.org>
> don't know)
If you are using the web interface then it takes a little time to appear.
:-P
Regards
Date: 6 Jun 2011 16:57:13
Message: <4ded3f29$1@news.povray.org>
The scene file can be found here:
http://www.bishop3d.com/forum/viewtopic.php?f=12&t=824&p=2816#p2816
and you can download Bishop3D here:
Regards
Date: 10 Jun 2011 06:40:00
Message: <web.4df1f41a5b05cb15c0abfa3e0@news.povray.org>
> Regards
>      Stephen
Hi Stephen
This is great, thanks so much for the time you've spent on this.
However, is there any way to do this animation solely in POVRAY as I have
absolutely no idea how to use Bishop3D and really don't have the time to learn a
new program.
Many thanks again
Tops
