POV-Ray : Newsgroups : povray.newusers : Light diffusion through prism Server Time
14 Dec 2025 16:43:59 EST (-0500)
  Light diffusion through prism (Message 1 to 7 of 7)
Subject: Light diffusion through prism
Date: 18 Apr 2011 14:45:01
Message: <web.4dac859365674b1469fb356b0@news.povray.org>
I am trying to create a simple scene that has a semi-transparent triangular
prism with a white light entering on one side and a rainbow exiting on the
other, similar to
http://en.wikipedia.org/wiki/File:Dispersive_Prism_Illustration_by_Spigget.jpg
I was thinking about just using a gradient and a color map to build the rainbow
but every time I tried the gradient would be small and repeat, so it was like 5
or 6 repeating rainbows. I then tried the actual rainbow structure but couldn't
get it straight and triangular like the dispersion from a prism. Any idea on how
to go about this?
Subject: Re: Light diffusion through prism
Date: 18 Apr 2011 19:45:58
Message: <4daccd36@news.povray.org>
> other, similar to
> to go about this?
You need to enable photons maping.
global_settings{photons{spacing 0.01 autostop 0}}
or
global_settings{photons{count 1000000 autostop 0}}
This turns on photons emission for all lights except for shadowless ones.
Then, you need to add the followings to your prism:
      "interior{ior 1.5 dispersion 1.03}"
"ior"1.5 make the prism actualy refract light, here, with a median value
for glass.
dispersion 1.03 turn on the chromatic dispersion. The given value is
relatively strong.
In the interior block, you can add dispersion_samples 12 (or more) to
get smoother results.
      "photons{target refraction on reflection on}"
This enable shooting photons at the object.
"reflection on" is optional in this particular case.
"refraction on" is needed to enable the prism to bend light.
To get exactly the same result, you also need to add some reflection to
your prism:
      "finish{reflection{0.01 1 fresnel}conserve_energy}"
With "reflection on" in the photons block of the prism.
If you look the documentations about photons, there is mention of a
photons block for light_source. This block is optional and have the
following default values:
photons{refraction on reflection on area_light off}
Date: 18 Apr 2011 22:05:00
Message: <web.4daced33dcf29308f9cdbc410@news.povray.org>
Maybe I'm not fully understanding photons and the light source, this is my first
pov ray program.
What I came up with after your post was
global_settings{
    photons{
        spacing 0.05 autostop 0
light_source {
    <-5, -3, -8>
    color rgb <1, 1, 1>
    translate <-5, 5, -5>
    spotlight
    point_at <0,0,0>
    radius 10
    photons {
       refraction on
       reflection on
    location <-15,10,-40>
    look_at <3,-2,0>
    angle 60
difference {
    box {
        <-4,-2,-8>,<4,2,8>
    plane {
        <0,-1,0>,-1 rotate <0,0,60>
    plane {
        <0,-1,0>,-1 rotate <0,0,-60>
    hollow on
        color rgbt <.8,1,.9,.7>
    finish{
        reflection{
            0.01 1 fresnel
        conserve_energy
    interior {
    photons{
This makes a good triangular prism and the photons make it look good, but there
is still no visible light entering the prism/rainbow exiting. Am I doing
something wrong with the light source?
Date: 19 Apr 2011 08:19:11
Message: <4dad7dbf$1@news.povray.org>
> pov ray program.
> global_settings{
>      photons{
> light_source {
>      <-5, -3, -8>
>      color rgb<1, 1, 1>
>      translate<-5, 5, -5>
>      spotlight
>      point_at<0,0,0>
>      radius 10
>      photons {
>         refraction on
>         reflection on
> camera {
>      location<-15,10,-40>
>      look_at<3,-2,0>
>      angle 60
> difference {
>      box {
>          <-4,-2,-8>,<4,2,8>
>      plane {
>          <0,-1,0>,-1 rotate<0,0,60>
>      plane {
>          <0,-1,0>,-1 rotate<0,0,-60>
>      hollow on
>      pigment {
>          color rgbt<.8,1,.9,.7>
>      finish{
>          reflection{
>              0.01 1 fresnel
>          conserve_energy
>      interior {
>      photons{
The simple media tutorial beginning here:
http://wiki.povray.org/content/Documentation:Tutorial_Section_3.6#Simple_Media_Tutorial
will get you going with the media that you need to make the light
visible ;-)
Date: 19 Apr 2011 16:24:40
Message: <4dadef88@news.povray.org>
You don't anything wrong with the light. It only needs something more to
interact with. It can be a media or some surface.
You may do as Jim said and use some media, but there are other way to
make the light visible:
You can place a white plane just behind the prism, placing so that the
back side of the prism intersect it. That way, you'll be able to see the
path of the light inside the prism.
I added this:
plane{-z,-7.9 pigment{rgb 1}finish{ambient 0 diffuse 1}}
This plane acts like a projector's screen.
I changed your light to a light and a slit like this:
union{
	light_source {
	    <-50, 0, -3>
	    color rgb 100 // Much brighter
	    parallel // instead of a spotlight
	    point_at <0,0,0>
	    photons { // Optional
	       refraction on
	       reflection on
	    } // OK even if not needed.
// those 2 boxes make a nice slit
	box{<-40,  0.1, -1000><-41,  1000, 10>}
	box{<-40, -0.1, -1000><-41, -1000, 10>}
	rotate 49*z
	translate -6.3*x
I reduced the photon's spacing down to 0.0045.
I increased the ior to get closer to the image you refered.
It needs something like 1.88.
In the original image, the dispersion seems exagerated. Increased
dispersion to 1.06. You can try some larger values.
I bumped up the dispersion_samples to 50 and got very smooth results.
You will see more reflections in the prism. Those are correct.
You need a strong light as the incident angle to the plane is shallow
and the dispersion spreads it's brightness over a much larger area.
Advantage compared to the use of media: Much faster.
Date: 25 Apr 2011 19:25:00
Message: <web.4db60273dcf29308b642fbb20@news.povray.org>
> other, similar to
> to go about this?
To awestover:
Alain and Jim gave you really good advice. I really hope you accomplished your
goal writing your script. There is nothing more rewarding than to see the
physics of nature perfectly simulated by povray. I would go with Alain's
suggestion to project the light onto a screen rather than using media. Good
luck!
Date: 26 Apr 2011 13:19:01
Message: <4db6fe85@news.povray.org>
>> other, similar to
>> to go about this?
> To awestover:
> luck!
Yes, a screen can be over 100, to 1000 times faster.
With media, you need to deposit your photons in the media. That realy
causes your photons count to shoot up dramaticaly.
More photons means heavier RAM useage, quite possibly exceding the
amount of available RAM and forcing the use to the page file.
Disk access is extremely Slooooooooooooow comapred to RAM access.
