POV-Ray : Newsgroups : povray.newusers : bounded by, clipped by and polyedra Server Time
28 Sep 2024 10:13:33 EDT (-0400)
  bounded by, clipped by and polyedra (Message 1 to 4 of 4)
Subject: bounded by, clipped by and polyedra
Date: 28 Mar 2011 08:55:00
Message: <web.4d9084b828532e7190049e30@news.povray.org>
I need to ray trace a quadric (hyperbola or sphere) clipped by a prism with
arbitrary polygonal base or clipped by e tetraedron. The scene is composed by
several of these patches. What is the best method to do this?
I tried by triangulating the mesh of the prism but it seems that the mesh object
cannot be used inside a bounded_by or clipped_by statement.
Any suggestion?
Thanks,
Sergio
Subject: Re: bounded by, clipped by and polyedra
Date: 28 Mar 2011 14:32:33
Message: <4d90d441@news.povray.org>
> Hi,
> Any suggestion?
> Thanks,
> Sergio
You can use the prism or the tetraedron directly.
It's the only way if you are using version 3.6.
You can try to use the interior_vector on those meshes. (you need to use
version 3.7 to have that feature)
Normaly, a mesh is just an infinitely thin shell with no defined
interior/exterior relationship.
Bounded_by and clipped_by need a clear interior/exterior for the used
object.
Adding an interior_vector to your mesh enable that distinction.
(need version 3.7)
Date: 29 Mar 2011 17:10:01
Message: <web.4d924961a5d30c00734759200@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> > Hi,
> > Any suggestion?
> > Thanks,
> > Sergio
> object.
> (need version 3.7)
> Alain
Using version 3.7 everything is fine.
Many thanks!
Sergio
Date: 3 Apr 2011 03:50:49
Message: <4d9826d9$1@news.povray.org>
Am 28.03.2011 20:32, schrieb Alain:
(BTW, it's inside_vector, not interior_vector)
Note that generally speaking, the inside_vector feature /does/ exist in
3.6. IIRC there were some caveats though, so that in /some/ contexts
meshes still weren't accepted as solid objects, despite inside_vector
being specified.
