As regards the brick wall, I have gone for a simple box with a more complex
texture.
I have also made a piece of "paper" from a bicubic_patch, I have used rand for
the first time to wrinkle the paper and place it randomly with a while loop. It
took some time, but I have found rand really helpful.
For my light in the lamp I have used a frame. This is causing far too harsh
shadows, even with radiosity. I don't want to use an area light if possible, are
there any other options?
About the macros used to build bricks, how do they work? I have read the files
but don't really understand them. Also I keep reading posts where people say to
use macros to build a mesh, but I have no idea of how to do this.
D103
Am 23.01.2011 03:20, schrieb D103:
Don't be afraid of area lights.
harsh
possible, are
Give the lamp shade no_shadow and use two spot lights (one up and one
down) with soft edges that more or less match the shade. Also use a
basic dim light source to simulate the light that filters through the shade.
But as clipka said, don't be afraid of area lights. Although this trick
can help you avoid lots of area light calculations from the lamp shade,
soft shadowing on all of your objects will look way better than hard
shadows, and if you use 'adaptive' properly, it really won't hurt your
render times that much.
> texture.
> D103
Why don't use area_light?
An area_light ,even with a high density, with the adaptive option can be
relatively fast.
Try this, rather extreme, one:
light_source{<40, 80, -40> rgb 1 area_light 8*x, 8*z, 257, 257 adaptive
0 circular orient}
No real need to use jitter with that density.
And compare it to the proposed one from the insert menu.
light_source {<0,0,0> color rgb 1.0
area_light <8, 0, 0> <0, 0, 8> 4, 4
jitter circular orient translate <40, 80, -40>
Both cover the same area.
I have now completed a full test render @ 1024x768 pixels, this took 21 1/2
hours.
I'm very satisfied with the results, and am now two days into rendering a 12.5
mega-pixel image. If the current rate of progress is anything to go by, it
should be finished in another week and a half.
Just one very small problem, while I am happy with the crackle patterned texture
for the street paving, it looks just a little _too_ irregular, as opposed to the
brick pattern, which looked to straight and clean cut.
Is there any pattern/macro/anything which can resemble a cobbled street or
something similar?
Many thanks everyone for the help,
D103
> something similar?
You might like to try the CobbledStreetMacro or CurvedPaving macros from
the PovRay library collections.
http://lib.povray.org/searchcollection/index.php
Regards
>> street or
>> something similar?
Also, take a look at the Irregular_Bricks_Ptrn() macro from textures.inc.
There is a description of the macro and it's parameters in the inc file,
just before the macro itself.
"D103" <nomail@nomail> wrote:
> This is something that has been bothering me for some time. My scene files are
> all very 'clinical', that is they are too perfect. For example, I have rendered
> a scene with a paved street, a brick wall and a lamp post, but everything looks
> perfectly 'clean'; the wall is perfectly straight, there is no dirt, no rubbish,
> no anything other than what I have already mentioned. What do I have to do to
> get natural looking scenes?
> Also, in over a year of using POV-Ray, I have not progressed much beyond the
> basic solid primitives, and blob has gone almost unused. Is there any kind of
> maths I need to study, or do I need to use a modeler, or what?
> If anyone could give me a hand with these questions, I would be much obliged.
> D103
Since posting this, I have discovered that I am quite short-sighted, and now
that I have glasses, I have found that most of what I thought was too perfect
actually is just fine detail that I couldn't see naturally before.
So now there's nothing I can't fix with textures. :-)
D103
good for you that you now have glasses! An alternative
solution would have been to use strong focal blur ;)
I know the feeling. Before you get your eyes tested, you don't even realize
that you are missing anything. Getting glasses is quite a pleasant shock.
